#2255 | |
try deleting all 5 tune files in the mod slots (not your stock tune) in the oft. then load up the full tunes you want. if still no go ring the guys at openflash Last edited by steve99; 01-24-2015 at 05:01 PM. |
#2256 | |
Drives: 2014 FR-S
I tried it again and it works as I expected it to the first time. I think in my over diligence with the key off, key on, that I maybe didn't turn the key fully on when trying to write...only thing I can think of. New tune is in the car and it runs fine. Once it learns a bit I'll see if there are improvements with this 93 octane tune over my old one. Thanks again for your help for this determined fool!
| The Following User Says Thank You to cfordart For This Useful Post: | steve99 (01-24-2015) |
#2257 |
Custom User Title
Drives: Spaceship
@Shiv@Openflash
Ever seen this before? It still works fine when connected to the car... EDIT: Was plugged into a USB 3.0 port, switching to USB 2.0 made it work.
#2258 |
Drives: Whiteout FR-S
Recently just purchased a used OFT from another member on the forums. I believe it is unmarried as when I plug it into my car I'm allowed to choose between the stock rom (already the same as what is in the ECU) and the previous rom that was in OFT which is the phantom SC. When I plug into my comp I get the error (0XE1 while communicating with device). I've previously owned an OFT last year and I did not have this issue.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#2259 | |
Drives: 2013 FRS
You are correct, USB 3.0 doesn't work with properly with OpenFlash Manager. Stick to 2.0 and you'll be good to go.
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | alexand3r (01-25-2015) |
#2260 | |
Drives: 2013 FRS
To unmarry it, connect it to OF Manager and go to ERASE DATA. Once it erases, it's as good as new and can be installed (as new) in your vehicle. If it tells you that the ECU must be flashed back to stock before the device can be erased, then the person who sold you the OFT needs to flash his car back to stock before selling it to you. If the ERASE DATA selection is greyed out (unselectable), then email sales@openflashperformance.com the serial number of the OFT and we can fix that remotely. Cheers, shiv |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Tt3Sheppard (01-26-2015) |
#2261 |
Drives: GT86
I have emailed sales about the ERASE DATA selection is greyed out.
Still have the problem, I have emailed again, maybe this time. |
#2262 |
Drives: 2013 FRS
It's still Sunday here in the States so the sales team won't be here for another 15hrs. But if you email me your serial number (shiv@openflashperformance.com) I can take care of this for you myself. I tend to work on weekends.
#2263 |
Drives: GT86
Thanks... email sent
#2264 |
I wanna go fast
Drives: 2013 FR-S 6MT
forgive me if this is a common issue that has been raised before -
I just noticed that Openflash manager reads that my device has firmware 1.29. The device itself reports firmware 1.32. Doesn't seem to be causing any practical issues though. |
#2266 |
Drives: 2013 FRS
The next time you quit and reopen OF Manager it will read 1.32. But you are correct, they are no practical issues with the mismatch.
#2267 |
I wanna go fast
Nope. It's been like this for months. Ive opened closed many times, i've upgraded to 1.15.1, updated device. etc. It's not changing.
#2268 | |
Drives: 2013 FRS
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
