#2241 | |
Alignment (more camber roughly -3F/-2R, appropriate toe) Coils (stiffer springs required to control the car with the new amount of grip from the sticky tires) That could cost you $2k or it could cost you $8k depending on how nuts you go, then there's little stuff like sways and weight reduction, biggest advantage is in the three above along with a header and tune, if you have all 4 things dialed in you are 95% of the way there to a nationally competitive car. What makes sense? Keep having fun and do tons of research before you buy, I'd bet you could shave up 5s off with driver improvement without significantly changing the car. Alignment can be hugely beneficial so I'd pursue that first with an emphasis on buying the right stuff so you don't have to sell and buy again. Last edited by strat61caster; 04-11-2016 at 12:50 PM. |
#2242 |
Drives: 2013 Raven FR-S
For those running the Strano bar, are you using the stock or adjustable endlinks?
#2243 |
Drives: Many
#2244 | ||
Drives: Firestorm FR-S
I'm hoping to attend one or two Philly events if i can fit them in. SNJ they are super lax about most things, which i like. Quote:
So on my list of first things is Tires and alignment. After that I'm going to save for some coils. About the tires... Is there any of them that you can recommend for both DD summer tires and Autocross? I dont mind if they are for summer only(i still have my stock wheels i can throw blizacks on), but i dont have a garage so switching them out every month is a pain. |
#2245 |
Drives: 2013 Satin White Pearl BRZ
Bet there's 5seconds to gain in just the tires. Also driveshaft is illegal in STX. And if your not already on coilovers you need to be. 9" wide wheels with 255wide tires would be real helpful. Good that you already have a tune and header.
You should find the rule book and go over it so you don't do anything to put you in the wrong class. Sent from my SAMSUNG-SM-G900A using Tapatalk |
#2246 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#2247 | |
#2248 | |
While some may say 'don't bother using other tires, they're too slow' imo you've got a lot to learn, no reason to burn up >$650 of sticky tires figuring stuff out and you may be done with autox by the end of the year (it's hard work to set up a car to do well, lots of trial and error even if you spend big bucks and it just doesn't hold some people's interest), at least with the RS3/ZII you'll get some useful DD life out of them as well and a more progressive introduction to the level of grip rather than just tossing on the stickiest tire and going from a car that pulls ~0.9g to a car that's capable of >1.3g overnight. Watching the video, autox on those tires once or twice more, and get someone who is fast that you trust to drive the car at least once with those tires on an autox course, it blew my mind when I did that and I'd guess it would be just as revolutionary for you as well. |
#2249 | |
The Stig's German cousin
If you're knocking though, the ECU will pull timing, and could cause you to back away from the limit. This is especially true since things like IAM seem sticky to me (I've seen it go down, but never back up to 1). So if you knock enough to drop IAM it'll hurt you even if you're in a part of the RPM range that isn't seeing knock. If it happens again, strongly recommend you log all the knock parameters. |
#2250 | |
Drives: '22 BRZ
That still doesn't explain the throttle closing. I'm thinking I should log the fuel pressure... or see if it goes away running more fuel in the tank.
#2251 |
What coilovers are you using? Right now I'm using the stock bar and endlinks on my Tarmac 2's with no issues. I think the KW strut works better with stock endlinks than some other designs, but not totally sure.
#2252 |
#2253 |
Drives: Many
#2254 |
Are those shorter than the endlinks that come with the 20mm adjustable front bar? I remember the ones that were included seeming like they were too long even without adjusting them. Maybe that's the culprit.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
