Old 07-08-2012, 10:25 PM   #211
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by rusty959 View Post
Also, what does the hot side look like?
Hotside of the compressor or turbine outlet. Either way, I hadn't posted any pictures of those sections.
Turbine outlet was just getting a redo to 3" for the V band housing anyway.
Don@Accelerated is offline   Reply With Quote
Old 07-08-2012, 11:29 PM   #212
rusty959
Drives: DGM BRZ limited
Well both really, but that question was mainly targeted toward turbine side. Probably just waiting for pics of mounted turbo will answer all of my curiosity. My first thought for placing the turbo is to relocate the battery and put it there. Route exhaust up where you have your ic piping, to turbo, then back down. My main concern with this is getting reasonably fresh air. My brz is still a couple weeks out so I haven't gotten to pull the battery and screw around with placement yet.
Im assuming you had to cut a significant amount for the ic piping down in the front bumper? iirc it is completely blocked off.
rusty959 is offline   Reply With Quote
Old 07-08-2012, 11:53 PM   #213
Don@Accelerated
The mass of persons won't want to relocate the battery. Although I'm not sure you can realistically fit one there. My number 1 concern is the direct injection ecu and the harness. You would be running the inlet and exhaust so tightly up against the main harness I would be severely worried about long term effects.
I'm not sure what you recall about cutting in the front bumper. I have made the entire kit thus far zero cuts. The only thing ive changed in the bumper area is a small plastic fold and its plastic clip was removed. Other than that the horn is relocated with its own bracket.
-Don
The Following User Says Thank You to Don@Accelerated For This Useful Post:
rusty959 (07-09-2012)
Old 07-09-2012, 12:13 AM   #214
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Final redesign of the IC piping routing.
2" Primary into IC
2.5" out into 3" TB
Looks amazing!!
Clean and everything.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 07-09-2012, 12:41 AM   #215
rusty959
-Don
Awesome, I appreciate your reasoning.
As far as the bumper goes, thats good to hear. It might be an important difference in that Ive only been able to scour over a frs... Haven't been any brz's in my area yet, apparently Im getting the first one.
Old 07-09-2012, 12:45 AM   #216
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Just a random guess for the hell of it.
287WHP.
Anticipation, Anticipation... Anticipation
Like what your doing here Don.
Floggin Tires is offline   Reply With Quote
Old 07-09-2012, 12:45 AM   #217
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Loving this build so far! Very tempted to buy once I sell my bike but I dont want to void warranties and then be out of pocket for everything.
Unleashed is offline   Reply With Quote
Old 07-09-2012, 12:47 AM   #218
kidgogeta
Drives: FRS
what's your power output looking like for different psi? and what are your thoughts on turbo vs supercharger (twin-scroll)
kidgogeta is offline   Reply With Quote
Old 07-09-2012, 01:07 AM   #219
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
If the engine can handle the power and this wont be to much money then im all over this.
WolfsFang is offline   Reply With Quote
Old 07-09-2012, 03:01 AM   #220
slow_frs
Drives: turbo scion tc
Ohhh soooooo cleAn this or a screwed blower hmmm.... This lol although I'd like to see a wrinkle black finish for a more OEM look
slow_frs is offline   Reply With Quote
Old 07-09-2012, 03:20 AM   #221
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
I've seriously been tossing around a lysholm charger in my head, now if it ever gets out we may have a problem....
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-09-2012, 03:44 AM   #222
serialk11r
Drives: '06 AM V8V Coupe
Screw Lysholm, try to pluck one of those Eaton TVS units from somewhere. Anything besides ZR1 use it?
Old 07-09-2012, 08:55 AM   #223
Cheddar
Saving them pennies...
I love how ppl ask for HP numbers and no one knows how this engine will react to boost. Let them build their turbo kit, test, adjust, and tune. Then we can ask for HP numbers.
Cheddar is offline   Reply With Quote
Old 07-09-2012, 09:01 AM   #224
slow_frs
considering that the gazoo twin charged concet is on stock internals.....and making 315 hp ~250whp im gonna guess this engine does decent since toyota has confirmed they are in it with gazoo..... also dont think oh man 250whp only from a twin charged... i doubt there goal was big power more just a full power band
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
