Old 03-17-2015, 02:31 PM   #211
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
Originally Posted by buckyislucky View Post
Hey guys .... I was just trying to get a better idea about which brand of gas to use... ultra 94. Shell 91,Esso 93. Etc.... obviously the car takes premium gas. .. don't need to read the manual to know thay
For some know it all out there on the forums not everyone is a 86 junkie
I have actually wanted this car for 2 Years and now finally have it and want to make the best of it by getting as much info from everyone here.
I'm gonna stick to the 94... thx for the help...
Also, gas seems to vary place to place, station to station, brand to brand, month to month, etc. Shell 93 here may not be the same Shell 93 in another place. So unless you are going to log data on each fuel in your area, I would just pick a premium fuel that's convenient to you.
TheVoiceOfReason is offline   Reply With Quote
Old 03-17-2015, 02:59 PM   #212
Koa
THIS CAR IS KNOCK EVENT HAPPY. Whether it is actual knock or misattributed, the knock sensing system seems to be dialed in to the 'safe' side and reports even non-knock events.
Even stock, there is common exhibited knock (FBKC, FLKC) from the 2600-3500rpm and low load range, and for some in the upper RPMs and heavy loads as well with users using American 93 octane. Aussies, UK, and places in America with 91 only/shit gas options have it worse.
Run the most QUALITY high octane gas you can.. try to determine a fueling source that limits the amount of reported knock events given you're stock, or know your tune is dialed in well. This is almost impossible to discern without logging tools
The Following User Says Thank You to Koa For This Useful Post:
Shankenstein (05-16-2015)
Old 03-17-2015, 04:32 PM   #213
Originally Posted by HunterGreene View Post
Well, sure, but seeking out anything above 94 is likely to get expensive and for minimal benefit. I know that's probably what you were thinking, but I thought I'd just clarify it for you.
Yes!
and
Yes!
I have had some Shell 91 that rocked my world and some Petro Can 94 that just sucked!
Koa (03-17-2015), Shankenstein (05-16-2015)
Old 03-17-2015, 05:50 PM   #214
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I noticed that i could only get 27-28mpg with the Chevron 94 octane. But with Shell 91 octane i could get up to 31.5mpg. The choice is clear.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
Tcoat (03-18-2015)
Old 03-17-2015, 08:11 PM   #215
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
12.5:1 CR tends to do that!
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
Koa (03-18-2015)
Old 03-18-2015, 01:03 PM   #216
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Hanakuso View Post
To answer your question, yes regular will run but why risk damage to the engine to save a few pennies.
The job of the knock sensor is so that NO damage will occur....
Old 03-18-2015, 01:34 PM   #217
Koa
Not true.. the job of the knock system is to prevent serious damage from occuring, but a significant knock event such as pre-ignition knock can flare and cause damage before the feedback or learned knock systems (FBKC and FLKC) can pull timing. Alternatively, it's possible that the system can hurt you: In the event of the sensor detecting false knock events that end in pulling timing, one's track times could be damaged which can cause loss of position, ego deflation, and sads in general.. so damage is relative to the situation here..
And to finally answer the OP:
None of the above
The Following 2 Users Say Thank You to Koa For This Useful Post:
Choco (03-21-2015), Tcoat (03-21-2015)
Old 03-21-2015, 03:21 AM   #218
buckyislucky
buckyislucky
Drives: 2015 scion frs
Great input koa and everyone else. ..
also if I decided to change from 94 to 91 (for more mileage) is there anything I should do before I do so?
buckyislucky is offline   Reply With Quote
Old 03-21-2015, 03:36 AM   #219
Nope! Just open the cap and pump 'er in. I run 91 most of the time and am very happy with the way it runs. The ECU will take a tank or so to adjust but it will do all the work for you. The only advice I would add is to make sure you get it from a station that sells enough that it is reasonably fresh in their tanks. I had a bad time once when I went to a little neighbourhood station that had it in their tanks for months.
Old 03-24-2015, 01:01 AM   #220
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Premium, no crickets, asks to be driven harder... treat her like a lady.
Packofcrows is offline   Reply With Quote
Old 05-16-2015, 08:21 PM   #221
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Sorry to revive this thread but I couldn't find anything about using 90 octane gas.
It seems that many people believe that using as low as 91 octane is just fine. There's an ethanol free station by my work but they only offer up to 90 octane. I just filled up with the 90 octane ethanol free to give it a try and my car is sooooo much quieter during idle. As far as I can tell from my butt dyno there is no loss in performance either.
Should I just be safe and continue to use the 92 octane gas at shell and try to ignore the crickets? Or would it be ok to use the 90 octane ethanol free? The ethanol free would also cost me about $25 more a month. The crickets really don't bother me that much but it's so nice to have silence while at a stop light...
FatFree is offline   Reply With Quote
Old 05-16-2015, 08:39 PM   #222
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
As others have mentioned, listen to the car (or watch the datalogs). The most knock-free fuel I found in Houston was Chevron Supreme 94. The best I've found in Boston is Sunoco 93.
You can usually tell the fuel quality by listening during cold-start warm-up. When the engine is operating in open loop, bad fuel will cause an audible lope in engine rpm and some timing adjustment. "Puuht" + 100 rpm dip. The frequency this happens at is a good indicator when you're trying a new fuel.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
FatFree (05-16-2015), V_86 (05-17-2015)
Old 05-16-2015, 08:51 PM   #223
FatFree
FatFree's Avatar
Does engine knock sound different than the knock you hear from cooling and heating?
Old 05-16-2015, 10:35 PM   #224
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Cooling and heating meaning when a car is off? Thats the sound of the metals in your car shrinking because they're getting cooler. Knocking in your car with low octane has sounds like someone hammering your engine while your driving. Not the most attractive sounding bit and your car's performance diminishes. You want to use as ethanol free as possible since these engines were originally designed to not have ethanol as part of it's combustion process. Don't ever use anything less than 91 unless your running very low and the next gas stop only has low gas 87,89. But only get enough to get you to the next stop to fill back up properly.
Vincenttam is offline   Reply With Quote
uberstupid, use premium!, you can't fix stupid
Premium gas, or? NotlocTRD Scion FR-S / Toyota 86 GT86 General Forum 151 09-27-2017 03:56 PM
FRS arrival for regular customers question NWIguy Scion FR-S / Toyota 86 GT86 General Forum 20 05-05-2012 09:54 AM
Anyone have a pic of the regular seats? DuMa Scion FR-S / Toyota 86 GT86 General Forum 38 12-14-2011 01:29 AM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 08:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 01:52 AM
