Old 04-19-2015, 10:11 PM   #211
steve99
Originally Posted by 6-Shift View Post
@Shiv@Openflash I need help!
At some point over the weekend, one of my passengers slid my seat back into the tablet, cracking the screen and killing more than half of the LCD's. When it's plugged in I can only see a white screen with a bunch of black "dead" spots. This wouldn't necessarily be a problem except for I've been running E85, and my only close station, without warning, stopped carrying E85. I filled up with a quarter tank of 93 to get me home but I need to be able to switch the tune somehow. Can I order a replacement screen from y'all? I don't own a windows computer, and don't have my stock files saved anywhere but the tablet. What are my options?
Mate use the old fassioned telephone and ring the openflash guys you will get faster response.
the oft guys will hopefully give you a discount for a new tablet, i dont think they are economicly repairable.
you can download tunes from the openflash site for petrol .
Old 04-20-2015, 12:32 AM   #212
gonzo
Drives: frs
Holy shit that is an unfortunate chain of events. Hope everything works out!
gonzo is offline   Reply With Quote
Old 04-21-2015, 11:30 PM   #213
JDsThatGuy
Drives: Subaru BRZ Limited
I downloaded OFM on my girlfriends PC and noticed there is a file called _MACOSX, does OFM now work on a Mac?
JDsThatGuy is offline   Reply With Quote
Old 04-21-2015, 11:54 PM   #214
steve99
That file is cause shiv uses a mac
You can run openflash manager on a mac using parallels or vmware, not sure of all the detaila as use windoze :-)
Old 04-22-2015, 12:09 AM   #215
JDsThatGuy
Wine Bottler is a free app you can use to load Windows apps, struggling a bit to get it to work
Old 04-22-2015, 08:45 AM   #216
Wyattkb
Drives: 2014 Whiteout FRS
Anyone having trouble loading saved Logs? When I try to open it in OFM it just freezes. It was a 20 minute run.
Wyattkb is offline   Reply With Quote
Old 04-22-2015, 11:09 AM   #217
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yep, I had the same issue... Not sure what changed but it seems to be working fine now, even for logs a bit longer than 20 minutes.
Old 04-24-2015, 05:34 PM   #218
P5yk0t1c
Drives: 2014 FR-S
Hey guys,
I am very new to this whole tuning thing. I have ordered an OFT and I have the following installed:
- UEL header
- EVO 3 Catback
- Injen CAI
Which map should I be using? I am assuming the stage 2 93oct? Also I am from Canada and I am 3,500ft above sea level will this require tweaking my AFR (or other settings)? or should I just install everything and then capture a log? Who would I send that too in order to check if everything is running ok. This is my only car and I am very worried I am going to f something up and destroy the engine.
P5yk0t1c is offline   Reply With Quote
Old 04-24-2015, 06:46 PM   #219
steve99
Originally Posted by P5yk0t1c View Post
Hey guys,
- UEL header
- EVO 3 Catback
- Injen CAI
The only thing that may cause issues is you intake, injens and many other intakes alter the calibration of the mass air flow sensor MAF, this can effect fueling to you engine and cause hesitation or rich\lean conditions. Unlikely to blow anything up but may not run smooth or efficiently. If your concerned put stock intake back on, then once you are comfortable with logging and maf scaling put your intake back and rescale maf sensor see links below
ecu will compensate for altitude changes it has pressure sensor
The Following 2 Users Say Thank You to steve99 For This Useful Post:
P5yk0t1c (04-27-2015), Teseo (04-24-2015)
Old 04-24-2015, 08:18 PM   #220
Fricke
Drives: Toyota GT86
Djust got my OFT this week and flashd a euro stage 2 EL map in too the car
Runing an ACE 4-2-1 header and 2,5" exhast whit vibrant 200cel catt and cosworth panel filter.
My question is, what typ of Fuel ar the euro stage 2 mapps for?
Looked att the US mapps and those hade 91 or 93 oktane to schoose from.
Her in Sweden i run 98ron or 98+ron, but as i understand that is equal to yor 93?
Fricke is offline   Reply With Quote
Old 04-24-2015, 08:34 PM   #221
steve99
With the G or I series rom ie europe australia south africa the oft guys only offer one map the map they use is the usa 91 map.
in general the usa 93 fuel is superior to our 98 ron fuel.
if your getting no knock over 5000 rpm then you could try copying the base timing B map from the usa equlivant tune. The only difference between 91\93 maps is base timing B table ie timing over 5000 rpm is reduced about 1.5 degrees in the 91 maps and hence our maps
Old 04-24-2015, 10:07 PM   #222
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Would like a review on ACE 4-2-1 header! Thanks haha.
The Following User Says Thank You to chaoskaze For This Useful Post:
Fricke (04-26-2015)
Old 04-24-2015, 10:22 PM   #223
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
so I have possibly a real dumb question but I searched all through the forum for the answer. I flashed to stage 1 93 when I first received the oft a few months back. I ordered uel headers and then flashed over to stage 2 uel 93. I drove roughly 60 miles since flashing but I swear my butt dyno says it pulled a little harder between 3-4k on the stage 1 tune. I've been driving and letting it do its closed loop cycle for 90 percent of those 60 miles. Just wondering if anyone else feels this way?
cdq85 is offline   Reply With Quote
Old 04-24-2015, 11:01 PM   #224
steve99
Butt dyno needs recalibration :-)
Butt dyno probably mistaking the agressive vvt sound in stage 1 tunes between 3000-4500 rpm as power.
due to uel header that agressive vvt timing is not used so its smoother and you dont get the raspy noise,
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
