#211 |
Drives: 2013 FRS, Whiteout, 6spd
#212 |
Drives: 2013 FRS- Hot Lava
#213 |
im running the ofh, invidia over \front pipe and jdm trd axle back. theres a bit of rasp if i rev from a stand still. but once i get moving it sounds really good
#214 | |
Poor College Kid
Drives: ~.~
And does the OFH give the car the nice boxer sound?
#216 |
Drives: Silver Subaru BRZ
I installed the OFH on Saturday and flashed with OFT Stage 2 UEL 91 octane. On Sunday, I got a check engine light with code P2097. I reset it but today it came back on with the same code. Could it be that theres a leak by the O2 sensors? All the bolts I torqued to the required amount so I can't image there would be a leak at any of the gaskets. Except for the OFH, all other intake and exhaust parts are stock. Any ideas?
#217 |
SLO NO MO
How tight are you guys torquing the bolts down? 22 ft-lbs on the engine and 38 ft-lbs on the overpipe?
#218 |
Drives: Hot Lava
Anyone have this header plus an Ark catback exhaust?
#219 |
Drives: '13 BRZ Ltd
#220 | |
Drives: '13 BRZ Ltd
#221 |
#222 | |
log you long term fuel trims , afr, commanded afr and , wideband afr P2097 is fuel trim to rich long term fuel trim should be less than say 7% if its way over that something wrong afr is front o2 sensor measurement wideband afr is rear 02 sensor measurement commanded afr is what ecu is asking for with an OFT these three should read similar under load ie on the throttle. its probably a leak or maybe damaged 02 sensor. penitrating oils ect can damage 02 sensors |
#223 | |
#224 | |
- Exhaust leak near rear O2 sensor - Faulty rear O2 sensor - Fuel contamination Check the connection to the rear o2 sensor the plug may not have been pushed all the way in. Last edited by steve99; 10-30-2014 at 12:42 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | tomaszjanczak (10-30-2014) |
| Open Flash Header - Sound and Performance Comparison | nlowell | Engine, Exhaust, Transmission | 41 | 05-19-2014 06:29 PM |
| FS: Open Flash Header - SoCal Pickup | nlowell | Engine, Exhaust, Bolt-Ons | 9 | 05-12-2014 06:29 PM |
| Open Flash Tablet | Andrew025 | Engine, Exhaust, Bolt-Ons | 3 | 04-26-2014 05:03 PM |
| Open Flash Header Catless Clip | Vmax911 | Engine, Exhaust, Transmission | 25 | 03-08-2014 06:51 AM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
