Old 10-28-2014, 05:06 PM   #211
Ctuckfly
Ctuckfly's Avatar
Drives: 2013 FRS, Whiteout, 6spd
Originally Posted by 904FRSlow View Post
Also I have nameless axleback 5" muffler 3" tips with the rest stock, would adding OFH make it sound raspy?
This what I've got and am wondering about.
Ctuckfly is offline   Reply With Quote
Old 10-28-2014, 06:24 PM   #212
sirsol66
Drives: 2013 FRS- Hot Lava
If it helps, I run the OFH with a berk dual exit muffler delete and there's no rasp. So, I wouldn't expect yours will have rasp either.
sirsol66 is offline   Reply With Quote
Old 10-29-2014, 11:37 AM   #213
lucid215
im running the ofh, invidia over \front pipe and jdm trd axle back. theres a bit of rasp if i rev from a stand still. but once i get moving it sounds really good
lucid215 is offline   Reply With Quote
Old 10-29-2014, 12:56 PM   #214
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
How loud is your setup?
And does the OFH give the car the nice boxer sound?
Kelbyat07 is offline   Reply With Quote
Old 10-29-2014, 02:21 PM   #215
lucid215
yes it gives it a good rumble
Old 10-29-2014, 06:31 PM   #216
tomaszjanczak
Drives: Silver Subaru BRZ
I installed the OFH on Saturday and flashed with OFT Stage 2 UEL 91 octane. On Sunday, I got a check engine light with code P2097. I reset it but today it came back on with the same code. Could it be that theres a leak by the O2 sensors? All the bolts I torqued to the required amount so I can't image there would be a leak at any of the gaskets. Except for the OFH, all other intake and exhaust parts are stock. Any ideas?
tomaszjanczak is offline   Reply With Quote
Old 10-29-2014, 08:31 PM   #217
Foobar
SLO NO MO
Foobar's Avatar
How tight are you guys torquing the bolts down? 22 ft-lbs on the engine and 38 ft-lbs on the overpipe?
Old 10-29-2014, 08:46 PM   #218
SimplePortal
Drives: Hot Lava
Anyone have this header plus an Ark catback exhaust?
SimplePortal is offline   Reply With Quote
Old 10-29-2014, 09:40 PM   #219
Wepeel
Drives: '13 BRZ Ltd
22 at the engine, 26 at the overpipe.
Wepeel is offline   Reply With Quote
Old 10-29-2014, 09:41 PM   #220
Wepeel
Drives: '13 BRZ Ltd
Did you use new gaskets?
Old 10-29-2014, 09:43 PM   #221
tomaszjanczak
Yes, brand new gaskets at the header/engine and header/overpipe connections.
Old 10-29-2014, 09:54 PM   #222
steve99
Drives: FT86
as other guy says new gaskets are a must or you will get leak
log you long term fuel trims , afr, commanded afr and , wideband afr
P2097 is fuel trim to rich
long term fuel trim should be less than say 7% if its way over that something wrong
afr is front o2 sensor measurement
wideband afr is rear 02 sensor measurement
commanded afr is what ecu is asking for
with an OFT
these three should read similar under load ie on the throttle.
its probably a leak or maybe damaged 02 sensor. penitrating oils ect can damage 02 sensors
Old 10-29-2014, 10:00 PM   #223
tomaszjanczak
with an OFT
Thank you for the help. I did use brand new gaskets everywhere and did not use any penetrating oils on the O2 sensors. I will get a log tomorrow. Could it be that I just didn't tighten the O2 sensors enough? I thought I tightened them pretty well.
Old 10-30-2014, 12:16 AM   #224
steve99
Drives: FT86
its possible their is leak near 02 sensors.
- Exhaust leak near rear O2 sensor
- Faulty rear O2 sensor
- Fuel contamination
Check the connection to the rear o2 sensor the plug may not have been pushed all the way in.
tomaszjanczak (10-30-2014)
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 06:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 05:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
