#211 | |
Drives: FRS Silver LS1 swapped.
LS only adds 50 to 60 pounds over the OEM engine, If your like me, going from FI, the turbo, inter cooler, piping, external oil pump etc.etc. that 50 to 60 pounds is negligible.... btw...that boxer weights a ton. Most of the boxer engine weight is concentrated on or in front of the front wheels, the LS sits a full 10" further back than the OEM boxer in my case (and I do believe Weapons Grade kit as well) as it has to for clearance of the throttle body on the intake to clear the hood, ( that is pretty significant ) with most of the increased weight difference between the two powertrains being the transmission for the LS conversion , that moves even more weight aft ( most will use a Tremec T56 I'm using a Magnum XL heavy beefy transmissions). So what your saying is nonsense and the FRS/BRZ will benefit greatly with weight distribution and balance over OEM with an LS conversion at any horsepower. I have the weights and measurements if you need me to post them. Last edited by cf6mech; 07-03-2014 at 04:27 AM. |
#212 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
We're currently weighing up whether to use a lower comp built fa20 for 400whp track duties
or whether to use a 3sge beams. The beams revs better. Doesnt have oiling issues. Not to mention its a true Toyota overbuilt motor, just like a 2jz. If you're tracking a turbo fa20 you need to drysump it. If you want it to last that is. |
#213 |
Drives: 2013 Subaru BRZ
the BEANS is fucking dope, obviously you should do that.
are turbo beans builds common in straya / NZ now? I couldn't find a whole lot of info when I was looking into it previously.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
#214 | |
There are also 2 or 3 others involved in edurance racing. It's certainly not common. But there's an engine builder over here that seems to have 'cracked it' when it comes to beams race motors. |
#215 |
#217 | |||
Drives: '23 BRZ
![]() Understand your point about the massive T56, this could put engine/trans c.g. at a similar place to FA20 engine/trans c.g. location, but given the 2+2 configuration and the relatively forward engine location, the trans is still putting more weight on the front wheels than the rears. Quote:
If you were able to maintain stock weight distribution, or even improve it, congrats! But if there are other mods that help achieve that, please list them. There are FD V8 swaps that have similar weight distribution to the stock 49/51, but like vs. like, with A/C, power steering, etc. weight moves forward about 1.5%. I can't imagine the situation is any better with the FR-S, given how much further forward the firewall is relative to the front and rear wheels. |
#218 |
in orbe terrum non visi
Drives: violent
Look at your engine bay. The fa20 and transmission sit needlessly far forword. You can remove the slave cylinder with a box wrench from the top of the engine compartment for crying out load. The tail section of the transmission ends before the shift linkage which is well forward of the center of the car. And there's enough room between the heads and the firewall to stuff a turbo some sections of 3 inch pipe and a pump in there. Half of my wife can fit in between this engine and the firewall when she works on it.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#219 | |
#220 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Beams 3sge would be awesome..but wouldn't it be not worth the hassle for such a small and weak engine? Meaning...it'd be a fully custom swap (harder than LSx, since it hasn't been done yet), you have to figure out and fab everything..just to end up with a similarly small displacement 4 banger as the FA. Granted, you'd have the advantages you mentioned (tougher built, higher revving, better oil delivery, etc), but the power would be similar to a built FA...and that's only after a lot of work/time/money swapping it in there first.
Sounds much easier to do a fully built low comp FA with strong internals and improved cams/valvetrain...you don't have to figure out and waste time positioning new engine/mounts, drivetrain, cooling, fuel, wiring, ecu, etc etc etc. New built FA will bolt in and you retain factory low COG. LSx, however, seems a lot more worth it for that amount of custom swap work, over a dinky 3sge overstraining to squeeze every little bit of power. LSx can pump 400whp and tq all day and will eat Beams motors for breakfast. |
#221 |
This guy has an LS3.
Anyone know the engine specs and how much power it makes? What kind of ITBs are those and who makes them? [ame]https://m.youtube.com/watch?v=my3ond9vd0U[/ame] |
#222 |
Drives: Sapphire Blue ‘23
To keep in line with what people do with ae86's, anyone have any thoughts about sr20 swaps or f20/2 swap? Both engines have been around for a while now and have tremendous aftermarket support that can offer more than enough power for our chassis.
Just an idea that lingers |
#223 | |
...too similar for the large effort imo
#224 | |
| After the "Ferrari" 86, we now have the "Porsche" BRZ | Nardi330 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-06-2013 11:41 AM |
| Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
| First spotting in the wild! | pr0j | AUSTRALIA | 3 | 07-22-2012 03:48 AM |
| Official: The new Ferrari V12 Ferrari Berlinetta | Levi | Other Vehicles & General Automotive Discussions | 27 | 03-07-2012 11:31 PM |
| First Ferrari, now Porsche??? | zoomzoomers | Other Vehicles & General Automotive Discussions | 33 | 02-26-2012 11:45 AM |
