#211 | ||
Drives: 23 BRZ
Not to worry. We already have a date set on August 30th. Should be plenty hot enough outside ;-) |
#212 |
Drives: Silver BRZ
Umm this seems like an easy fix, robispec radiatir/oilcooled com er with pure distilled water/water wetter. Vented hood (siebon has a good one) and bAm.. No more heat issues.... I don't get it..
#213 |
in orbe terrum non visi
Drives: violent
I keep posting remove the cowl but no one listens
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#214 |
Sorry, proven not to work with some turbo setups. It doesn't address the melting fan issue.
#215 |
Drives: violent
@CSG Mike try it and log for us so everyone can see how much of a huge difference it makes at speed so someone ends up making an aftermarket one.
#216 |
#217 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
quoted below
#218 | |
Drives: Silver BRZ
"some turbo set ups.." I have all my stuff true ceramic coated from swaintech, plus the turbo blanket... i'm sure heat will be a non issue for such a set up.. just doesn't feel like you have exhausted all your avenues |
#219 |
Drives: violent
That pressure plot contradicts the one ft86factory has. And like I said the area of the cowl, not the base of the windshield is a low pressure area. Vcmc proved it works and I put mine back in because in the winter I couldn't get up to temp quick enough to get ample heat before I got to work.
| The Following User Says Thank You to Reaper For This Useful Post: | OjiGeorge (05-14-2014) |
#220 | |
Great White
Drives: 2013 Whiteout FRS
Good Luck...Wait till you get out there. I have a Full Blown Radiator, Full Blown Fan Shroud, two 12" Spal Fans, Ceramic Coated, Turbo Blanket, Full Blown Oil Cooler. Coolant still reached 228F .
Sterz' Great White 86 http://www.ft86club.com/forums/showthread.php?t=54533 Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe |
| The Following User Says Thank You to Sterz For This Useful Post: | OjiGeorge (05-14-2014) |
#221 |
Drives: violent
And i bet your cowl is in.
#222 | |
I've done that. Datalogs indicate that cooling was slowed on the CSG BRZ. The low pressure zone is a result of a trailing gap, which ultimately disappears when the cowl is removed. |
#223 | |
We've done both of those, as well as wrapping ALL exhaust components. Fans still melted. |
#224 |
Drives: violent
I wonder what speed it becomes non functional. Vcmc cut theirs so i can see that at tripple digit speeds. I really wish we could get a modifed cowl that kept it a trailing edge but added a vent below the trail edge of the hood.
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
