Old 05-13-2014, 03:57 PM   #211
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
This is one of the few reasons I am still considering buying and building another turbo BRZ. I would build it for track only just to go set laptimes and show that it is possible to you and everyone else.
I have no doubt that it can be done. It's just that nobody's actually done it, yet.
Not to worry. We already have a date set on August 30th. Should be plenty hot enough outside ;-)
rb6freak is offline   Reply With Quote
Old 05-13-2014, 03:58 PM   #212
FAER
Drives: Silver BRZ
Umm this seems like an easy fix, robispec radiatir/oilcooled com er with pure distilled water/water wetter. Vented hood (siebon has a good one) and bAm.. No more heat issues.... I don't get it..
FAER is offline   Reply With Quote
Old 05-13-2014, 03:59 PM   #213
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I keep posting remove the cowl but no one listens
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-13-2014, 04:00 PM   #214
CSG Mike
CSG Mike's Avatar
Sorry, proven not to work with some turbo setups. It doesn't address the melting fan issue.
Old 05-13-2014, 04:03 PM   #215
Reaper
Reaper's Avatar
Drives: violent
@CSG Mike try it and log for us so everyone can see how much of a huge difference it makes at speed so someone ends up making an aftermarket one.
Old 05-13-2014, 04:21 PM   #216
CSG Mike
CSG Mike's Avatar
Which cowl?
Old 05-13-2014, 04:32 PM   #217
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Which cowl?
quoted below
Pull the windshield wiper cowl out.
That pressure plot shows a high pressure area on the bottom of windshield.inljne with the hood not the plastic cowl tucked under the hood. That is a low pressure area.
He posted the Hancha group pressure plots from the CFD anaylsis that Driveway Labs had done for their diffuser.
Old 05-13-2014, 04:38 PM   #218
FAER
Drives: Silver BRZ
"some turbo set ups.."
I have all my stuff true ceramic coated from swaintech, plus the turbo blanket... i'm sure heat will be a non issue for such a set up..
just doesn't feel like you have exhausted all your avenues
Old 05-13-2014, 04:52 PM   #219
Reaper
Reaper's Avatar
Drives: violent
That pressure plot contradicts the one ft86factory has. And like I said the area of the cowl, not the base of the windshield is a low pressure area. Vcmc proved it works and I put mine back in because in the winter I couldn't get up to temp quick enough to get ample heat before I got to work.
The Following User Says Thank You to Reaper For This Useful Post:
OjiGeorge (05-14-2014)
Old 05-13-2014, 04:54 PM   #220
Sterz
Great White
Drives: 2013 Whiteout FRS
Good Luck...Wait till you get out there. I have a Full Blown Radiator, Full Blown Fan Shroud, two 12" Spal Fans, Ceramic Coated, Turbo Blanket, Full Blown Oil Cooler. Coolant still reached 228F .
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
The Following User Says Thank You to Sterz For This Useful Post:
Old 05-13-2014, 04:55 PM   #221
Reaper
Reaper's Avatar
Drives: violent
And i bet your cowl is in.
Old 05-13-2014, 04:55 PM   #222
CSG Mike
CSG Mike's Avatar
Originally Posted by ATL BRZ View Post
quoted below
Ah.
I've done that. Datalogs indicate that cooling was slowed on the CSG BRZ. The low pressure zone is a result of a trailing gap, which ultimately disappears when the cowl is removed.
Old 05-13-2014, 04:56 PM   #223
CSG Mike
CSG Mike's Avatar
We've done both of those, as well as wrapping ALL exhaust components. Fans still melted.
Old 05-13-2014, 04:58 PM   #224
Reaper
Reaper's Avatar
Drives: violent
I wonder what speed it becomes non functional. Vcmc cut theirs so i can see that at tripple digit speeds. I really wish we could get a modifed cowl that kept it a trailing edge but added a vent below the trail edge of the hood.
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
