Old 09-02-2014, 06:29 AM   #211
steve99
There is a new version of Ecuflash out 1.44.4347 also new firmware will be downloaded to Tactrix adapter dongle .
http://www.tactrix.com/index.php?opt...d=36&Itemid=58
also updated 32bitbase and updated definitions
see first post for more info.
Old 09-02-2014, 07:36 PM   #212
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I am confused on which file to put in the the SD card? Do i add the C Rom txt file our the b00c-b01c txt file? Also has anyone tried to log ecutek with this? I order a 2GB card but it hasn't come in yet. I have an 8GB card but not sure if it will work.
Toyota John is offline   Reply With Quote
Old 09-02-2014, 10:34 PM   #213
steve99
If you useing a A00C or A01C then just put the c series logcfg.txt file in the root directory of the SD card.
if you have a b00c or b01c then you will have to substitute the ram addresses for the b00c rom into the logcfg.txt file for the older rom as each rom has different ram address locations for the parameters you want to log.
Old 09-04-2014, 01:57 PM   #214
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Has anyone else noticed that logging shows direct fueling only regardless if you have port fueling set in specified areas? Will the new version of Ecuflash correct it? Thanks.
D-VO is offline   Reply With Quote
Old 09-04-2014, 02:50 PM   #215
steve99
I dont think that will be an "ecuflash" issue.
The logging just pulls the contents on the RAM address you specify in the logcfg.txt file then applies the scaling you set and writes it to the log.
If you getting incorrect log results its probably because the RAM address is incorrect the number type is wrong eg isfloat or databits 1 4 8 ect. or scaling is wrong for what you are trying to log.
Old 09-04-2014, 04:04 PM   #216
D-VO
That's what I was thinking. It's a bit strange that I'm the only one seeing it though. The AFR is seemingly effected by the port injectors coming on as well. So it may not be an incorrect logging address instance. It's not the biggest deal in the world and I can live with it, I'm more curious than anything else.
Old 09-05-2014, 02:28 AM   #217
Kodename47
Kodename47's Avatar
Drives: UK GT86
@D-VO are you on about the fuelling not matching the PI Ratio tables?
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-05-2014, 09:17 PM   #218
D-VO
Correct. Its been doing this for quite some time now.
Old 09-05-2014, 09:36 PM   #219
steve99
Thats weird i assume you changed all three di/pi tables ?
Old 09-05-2014, 11:31 PM   #220
D-VO
Yessir. All three tables are copied over each other. I tried DL'ing the new RomRaider then saved the same ROM there then reflashed using EcuFlash to no avail.
The Following User Says Thank You to D-VO For This Useful Post:
steve99 (09-05-2014)
Old 09-05-2014, 11:33 PM   #221
steve99
Hmmmm well that me out of ideas
Old 09-05-2014, 11:37 PM   #222
D-VO
Me too. LOL! It's really not a big deal since I was able to tune around it. I wondered if it was an error in the addressing for the B01C ROM. I asked @Td-d but he said it was good.
Old 09-06-2014, 12:39 PM   #223
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I did? Chuckle... I'm surprised, since the fuel injection parameters are the ones I've not really developed since I pulled these roms apart.
I'll see if I can get you a whole set of injection related parameters, that way we can id the correction ones - will also help with defining it for other roms.
Which parameters are you using now (post all of the fuel injection related ones).
Td-d is offline   Reply With Quote
Old 09-07-2014, 12:48 AM   #224
D-VO
I may have just made a mess of my question. Oh well. LOL!
For the B01C and from what I can log, all of these seem to operate properly:
Primary Open Loop Fueling: 112cc8
Primary Open Loop Fueling Additive: 112e98
Front Oxygen Sensor Scaling: 11fefc
CL Fueling Target Compensation A (Load): 11533c
Injector Latency_: 113e28
Injector Flow Scaling: 10ddc8
Injector Flow Scaling BRZ: 10dd94
(Not quite sure which one of these is being used)
Rev Limit (Fuel Cut): 10e5d0
GDI Flow Rate: 115e5c
GDI Pressure Multiplier A: 1121fc
Port Injection MRP Compensation: 110f88
These are the addy's I have for the Port ratio tables:
Total Injection Ratio Port Cold: 11258c
Total Injection Ratio Port Warm: 11272c
Total Injection Ratio Port Hot: 11265c
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
