Old 11-07-2013, 12:59 PM   #211
cnk
Drives: '13 DGM BRZ Limited
Originally Posted by Boofneenee View Post
How does pressing and releasing the gas pedal when the car is off help the ecu to learn? I was under the impression the car uses an analysis of exhaust fumes to determine calibration. What am i overlooking?
The car is Drive-by-wire so the ECU just needs to relearn what the range of motion is on the gas pedal after an ECU reset/flash. No idea where you got exhaust gas analysis from.
Originally Posted by Norkoastal View Post
What is the time sequence of all these steps? I know some cars have time requirements with throttle relearn procedures.. The steps above didnt work for me this go around when I flashed (my throttle already corrected so this would be good to test for the next flash)..
No time sequence.
cnk is offline   Reply With Quote
Old 11-07-2013, 03:22 PM   #212
brn12345
brn12345's Avatar
What is the impact of Sportmode/Traction off on engine mapping? Are the tuned maps adjusted for both sportmode and normal mode?
brn12345 is offline   Reply With Quote
Old 11-07-2013, 04:32 PM   #213
jeebus
Drives: 2015 Mustang GT (on order)
I'm not trying to be a squeaky wheel, but I had some issues with 1.33b as well. I flashed the same way I normally do. Turned car "on" and did the gas pedal trick 15 times, then started the car and let it idle for a minute before driving.
The first thing I noticed was VVT was definitely disabled. It never happened to me before with any of the flashes. It came back on after 10 miles or so. But after another 10 miles and two drive cycles, I can say that I was getting a lot of knock in the 2500-3000 range on tip-in and a ridiculous amount of knock after each shift. My wife was in the car and she was like what is that?
So I flashed 1.31 back on, did the same song and dance, and everything seems just fine now.
Any ideas?
jeebus is offline   Reply With Quote
Old 11-07-2013, 05:41 PM   #214
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Any ideas?
How many days/miles are you making these observations after the flash? For every flash i've made, the car wakes up around day 3 which is usually when I would have driven 50ish miles with 6+ start/stop cycles. I wish OFT included additional steps to help the ecu learn the throttle faster before driving around.. Nothing more than a nag but it could always be a feature down the road if possible to code in.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 11-07-2013, 06:16 PM   #215
jeebus
I drive 80+ miles per day. That said, the map has IAM set to 1 already, so other than fuel trims I don't think there's a lot of learning to do. My issues with 1.33 had to do with knock though, not performance (except during the initial VVT disabling)
Old 11-07-2013, 06:32 PM   #216
BRZ Fanboi
Drives: WRB Limited BRZ
What map does your car take? A00, A01, etc?
ZA1JA01C
BRZ Fanboi is offline   Reply With Quote
Old 11-07-2013, 06:50 PM   #217
sierra
Drives: Skoda Yeti DSG diesel 4x4
Subscribe.
sierra is offline   Reply With Quote
Old 11-07-2013, 07:17 PM   #218
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
VVT disabling after start up has nothing do with the map. It is caused by the flashing process. Specifially not by not letting the car idle for a short period of time after the flash process (as instructed). And this applies to any flashing system (ecutek, brzedit, ecuflash, oft, etc).
Old 11-07-2013, 07:38 PM   #219
jeebus
any idea why the latest 1.33b on my A00C car would have me knocking all over the place at tip-in, in the 2500-3k range, and post shift but going back to 1.31 fixes it?
Old 11-07-2013, 07:39 PM   #220
Shiv@Openflash
Drives: 2013 FRS
What map are you running? What modifications?
Old 11-07-2013, 08:11 PM   #221
jeebus
stage 1 AOOC map. Only mods are a drop-in and a catless front pipe. Didn't have any issues with 1.2. 1.31 felt a tad less punchy in the low revs, but felt smoother overall than 1.2. No issues there. With 1.33 the knock was really noticeable going up hills and after shifting during mid throttle application. Went back to 1.31 and drove the same circuit without issues.
Running Chevron 91 (cali piss).
Old 11-07-2013, 08:13 PM   #222
jeebus
BTW, I'd really like to give @shiv@vishnu props for following these threads and answering questions.
The Following 2 Users Say Thank You to jeebus For This Useful Post:
autobrz (12-03-2013), VR46 (11-13-2013)
Old 11-07-2013, 08:20 PM   #223
Shiv@Openflash
Drives: 2013 FRS
The only mapping change between the latest Stg1 map and the earlier Stg1 map is the transient ignition retard table. The latest Stg 1 map uses stock TIR table data. The earlier Stg1 version was retarded an extra 20 degrees. So yes the earlier map was more conservative during throttle transients. But that's it. Under sustained load it will perform identically. If for some reason your car is the only car I've ever seen, tested or has been reported to knock with any of these maps, perhaps something else is going on. I'm just reporting what I know to be the difference. If you want to go back to the earlier map version, you can do it. Nothing wrong with that more conservative approach.
Lastly, let's not forget that the all the maps are actually A01C maps. They are just given 700C, 900C, A00C and A01C designation for the sake of the OFT software since it is only allows you to upload ROMs with the same cal ID as your original ROM. It is not aware that the FA20 ECU allows you to use ROMs with different cal IDs (just as long as they are in the same family).
Shiv
Old 11-07-2013, 08:26 PM   #224
jeebus
Shiv
That's why I thought it was weird. Even doing diffs all I can see are TIR changes, which I realize are just to get the scaling correct. The only other changes appear as "table not defined"...I assume you added some new tables to the definition.
Just reporting what I saw. Maybe I'll give the 1.33 another shot after this weekend's autoX. I don't want to chance anything before then.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
