Old 07-19-2013, 08:35 PM   #211
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Here is a link for a large collection of compressor maps. Great for researching which compressor to select.
http://www.not2fast.com/turbo/maps/all.html
Old 07-19-2013, 08:47 PM   #212
neutron256
neutron256's Avatar
My Aquastar T20 arrived today. It's massive compared to the tiny SK3 8S 1500KV.
It will be interesting to see which of these will work better, or if either will end up meeting my needs.
Here are the two together for comparison. The Aquastar's. cooling jacket is removed and sitting behind it.
Old 07-20-2013, 07:59 AM   #213
neutron256
neutron256's Avatar
Another potentially good line of motors. I'm especially interested in the Toro X8PT 2D. It seems to be very close in specs to those being used in the Phantom design.
http://www.skyrc.com/index.php?route...product_id=152
They don't seem to sell them in the US, but you can get them off eBay.
I need to figure out a more universal motor mount so I can test different motors more easily.
The Following User Says Thank You to neutron256 For This Useful Post:
DAEMANO (07-21-2013)
Old 07-20-2013, 10:35 PM   #214
neutron256
neutron256's Avatar
I tinkered with my design a little more this evening. I was really unhappy with how far away the motor sat from the mounting plate. This was even worse when I swapped in the larger motor.
I redesigned it eliminating the separate shaft and mounted the compressor wheel directly to the motor shaft. Overall I think it's a much cleaner simpler design.
This does require machining the motor shaft which is tricky but I have a couple of ideas about how to do that.
Thoughts/Comments?
Small Motor
Large Motor
Old 07-21-2013, 01:23 AM   #215
nonicname
Drives: it has 4 wheels and a motor
what exactly are you rapid prototyping and what type of plastic are you using?
nonicname is offline   Reply With Quote
Old 07-21-2013, 08:49 AM   #216
neutron256
neutron256's Avatar
At this point I'm pretty much done with 3D printing. I was just to testing my dimensions for the backplate of the compressor. Once I'm happy with my design in CAD I might do one more print to test fit the whole assembly before I machine the backplate.
I'm using PLA in with a MakerBot Replicator 2.
Old 07-21-2013, 09:54 AM   #217
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Awesome progress!
SloS14 is offline   Reply With Quote
The Following User Says Thank You to SloS14 For This Useful Post:
neutron256 (07-21-2013)
Old 07-21-2013, 10:42 AM   #218
djdnz
1337
Drives: 2013 BRZ WRB S/C
Why are you machining the motor shaft, is it too long, or just to add a thread inside? Is the bolt and washer you are showing in the image the method of securing the compressor wheel?
djdnz is offline   Reply With Quote
Old 07-21-2013, 11:10 AM   #219
neutron256
neutron256's Avatar
The motor shaft has an 8mm diameter, and the the hole in the compressor wheel is 6.5mm. I'll turn most of the shaft down two 6.5mm to fit the wheel leaving a shoulder for the bottom of the wheel to land on. I'll be tapping the end of the shaft so the bolt can clamp the wheel between the shoulder and the washer.
I may machine the spacer/washer so it will also have a shoulder and fit part way into the hole in the wheel.
Here is an better view of the shaft/wheel assembly.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (07-24-2013), SloS14 (07-23-2013)
Old 07-23-2013, 05:53 AM   #220
amird
Drives: seat ibiza sport Coupé
I thought couple month ago to start build Electric supercharger same like you.
When I saw this thread I registered to this forum and started to follow after it everyday.
I learn from your knowledge and I wish to help you (if i can) to make this project to success.
Great progress!
amird is offline   Reply With Quote
The Following User Says Thank You to amird For This Useful Post:
neutron256 (07-23-2013)
Old 07-23-2013, 08:16 AM   #221
nonicname
is your goal to use the prototyped parts just for test fitting or as the actual part? I don't trust those parts holding up to any stress.
Old 07-23-2013, 08:31 AM   #222
neutron256
neutron256's Avatar
Correct the 3D printed parts are just to test the fit and get an overall feel of the design. There will be far too much heat and stress on the backplate to make it out of plastic.
I'll be making the actual backplate out of aluminum on a CNC mill.
Old 07-23-2013, 05:49 PM   #223
neutron256
neutron256's Avatar
So I'm getting close to ready to machine my first backplate. I went ahead and did another 3D printed back plate to test the fit of the large motor and everything is looking great so I had to share.
This motor looks/is huge, but since this is a proof of concept I'm starting big and will see if it can be scaled down later.
The Following 3 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (07-24-2013), jamesm (07-23-2013), SloS14 (07-23-2013)
Old 07-23-2013, 06:30 PM   #224
BRS
Drives: Black
[ame="http://www.youtube.com/watch?v=U81_0waqEWA"]Leaf-Blower Supercharging a 1978 Chevrolet Monza Spyder! - Roadkill Episode 16 - YouTube[/ame]
BLACK BRZ SPORTEC
BRS is offline   Reply With Quote
The Following User Says Thank You to BRS For This Useful Post:
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
