Old 09-21-2015, 10:40 AM   #211
w0wbagger
Drives: GT86
So I was at my shop today and there is nothing like a sign, a PN or any other mark left on the belt. Hence I won't find out which belt it was.
But the mechanic told me that when they installed the belt it was perfectly sitting there and was neither too long nor too short.
For my 2.87" pulley I have ordered the Gates K060960HD. Do you guys can recommend any other belt manufacturer? Since those belts are not on the market here in the EU I want to stock up a bit on them so that I dont have to wait for like 4 weeks for a new belt to arrive from the US.
w0wbagger is offline   Reply With Quote
Old 09-21-2015, 06:57 PM   #212
DJCarbine
Thupercharged
DJCarbine's Avatar
As stated above, I recommend the Good year gatorback/continental belt. There is a chart with the belt sizes depending on which pulley you are running, from there it is trivial to match it up to another manufacturers belt depending on number of ribs/length
2013 FRS
Vortech V3 11psi
Old 09-21-2015, 07:13 PM   #213
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Are those spider web at the end of your engine room power bars?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-22-2015, 03:21 AM   #214
w0wbagger
Drives: GT86
I am not exactly sure what you mean, mate, but the spider web comes from my insulating mat unter the hood which has been abused by the ruptured belt
Old 09-22-2015, 03:46 PM   #215
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I just noticed you wastegated post maf. Are you running speed density only?
bee_are_zee is offline   Reply With Quote
Old 09-23-2015, 08:36 AM   #216
w0wbagger
Drives: GT86
No and yes.
Up to 1 bar boost we are using the maf. Above 1 bar we are using the map and hence run on speed density.
The wastegate you see is just for the electronical boost control and fully closed under normal conditions.
Oh and today we switched from the 3.125" pulley to the 2.87" pulley. So to say there were no gains with the smaller pulley. The dyno now says 396 hp instead of 391 with the 3.125". My intake temperature after the intercooler is roughly around 60°C (dyno room with fans was around 23°C) and hence ignition had to be pulled quite a lot. I guess that the blower (doesn't matter if V-3 or V-2) is not suitable for power leves above 400hp at the crank on pumpgas. That is quite disappointing ...
Old 09-23-2015, 09:03 AM   #217
bee_are_zee
Drives: GBS BRZ
Interesting. I was planing on running the 2.87" wastegated to 11 psi to build boost faster, but now I'm thinking the extra temp is just going to hurt me on the top end compared to just running the 3.125".
Old 09-23-2015, 10:02 AM   #218
nelsmar
There is also a 3.00" pulley. It is an 8 rib but can be used. Yes you will have higher IAT with the 2.87 and lose some top end as 60C is going to make pump fuel unstable. However the dyno room is likely going to most likely have a bit less air flow than your car doing a 4th gear pull on the street, or the short duration of a 2nd gear pull. You are also creating more parasitic loss by adding a wastegate to the system and having to spin the blower faster and just wasting the extra air.
My flickr - Canibeat
Local magazine scout
Old 09-23-2015, 10:55 AM   #219
bee_are_zee
Drives: GBS BRZ
I was thinking regulated for gas. Full boost for e85.
Old 09-23-2015, 03:02 PM   #220
w0wbagger
Drives: GT86
Why should I have a higher parasitic loss with the wastegate when it is fully closed?
This has mainly to do with law regulations over here in Germany.
The TÜV (kind of a technical supervision authority) does not allow more power than 300ish hp at the crank. Thus I use the electrical boost control to limit power to 300ish hp and to still have the ability to go bonkers with close to 400 hp at the crank.
If one planned to use the wastegate to run a smaller pulley to build up boost sooner but still limit it to not like put more stress on a not built engine than it can handle, then yes. One would get less efficiency due to a higher parasitic loss.
I just picked up the car from the shop and did some testing with spirited street driving. I dont know. Even tho power levels are quite equal and the 2.87 pulley builds up boost a bit sooner than the 3.125 but still. It kinda feels like that the 2.87 is the worse setup. Hard to explain with words, but it just does not drive as smooth as with the 3.125" pulley.
I think the 3.125" is the best and I will switch back to it. I als doubt that the 3.00" pulley would significantly enhance the situation. My conclusion to this is that with the Vortech on pumpgas 400ish is the maximum one could reach.
Old 09-27-2015, 03:06 PM   #221
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Anyone looking for a kit I've got one for sale. Both stock pulley and 3.125 along with extra belts and Charger oil.
Jetbill is offline   Reply With Quote
Old 10-13-2015, 11:06 AM   #222
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Looking for some numbers if anyone has any input. Got the kit installed over the weekend hooked up my autometer mechanical boost gauge. the gauge is reading ~20psi of vacuum at idle and my tablet running dash command is reading ~10. Anyone know which is these is more accurate.
I ran a first gen kit a little over a year ago and am pretty sure everything is hooked up properly.
FyeaFRS is offline   Reply With Quote
Old 10-15-2015, 10:58 AM   #223
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Does your gauge show psi or in Hg for vacuum? Usually it's the latter, in which case 18-20 is okay.
alexand3r is offline   Reply With Quote
The Following User Says Thank You to alexand3r For This Useful Post:
FyeaFRS (10-16-2015)
Old 10-15-2015, 11:18 AM   #224
FyeaFRS
PSI, looks like I made a similar post a long time ago in the vortech guages thread with the same question last time I did an install.
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
