07-16-2015, 08:05 PM | #211 |
KCCO
Drives: 2013 Raven Scion FR-S, AT
Should be fine my fronts are 19x8.5 +45 and I have no issues. I am on 1.25" lowering springs. 225/35 19 tires
Sent from my SAMSUNG-SM-N910A using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
07-16-2015, 11:53 PM | #212 |
Drives: 13 BRZ Limited 6MT CBS
I'm on ST coilovers w/ 18x9.5 +40, 255/35 all around. Measured today after settling for a week, I dropped about 1.2" and I have no visible rubbing, although I think my front tires hit the fender once, I hit a shitty bump.
07-17-2015, 06:52 PM | #213 | |
Drives: FR-S Release Series 1.0
I was trying to do some research but found no info on that specific size nor have I even seen pictures of anyone with that size. I really want these rims but I don't want to purchase coilovers; I'm sure I'm not the only one. |
07-20-2015, 06:39 PM | #214 |
Drives: 2014 FR-S Monogram Raven
What would be the ideal tire size if I were to run 18x8.5 +42 all around with a 1 inch drop so they sit flush and no stretch on the tires? Would 245/35/18 fit or would I need to go smaller?
07-21-2015, 01:23 AM | #215 | |
http://www.frsproject.com/tire_size.php |
07-21-2015, 07:30 AM | #216 | |
Drives: BR86
Rears are a non issue as there's plenty clearance. Edit: Have spoken to 3 local Rays wheels suppliers & ALL are 100% confident that there will be NO rubbing on this car with stock struts even 1" lowered using the 18x8.5+42 size, one of them will even guarantee it ! I guess it's fine then. Last edited by ZZT86; 07-28-2015 at 08:08 PM. Reason: more info |
The Following User Says Thank You to ZZT86 For This Useful Post: | Mikey2style (08-01-2015) |
07-27-2015, 11:10 PM | #217 | |
What would be the ideal setup to run 18x9.5 +40 square closest to your setup without rolling fenders. Im considering fortune auto 500 and bilstein b14 coilovers would I need camber plates or LCA's? What brands would you recommend for these? |
07-28-2015, 08:35 PM | #218 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i don't consider fortune auto a good coilover, bilstein will prevail in my book every time over fortune and once you get into their custom built stuff you open up yourself to much better option than that such as AST, MCS, etc etc... it all depends on your budget. consider RCE tarmac zero with upgraded swift springs/stiffer rates, or pick up set of KW v3's for a good price and you can simply use your stock tophats for V3's since the front is notched and you can pull camber that way. i personally do not have camber plates but do have LCA. if your'e on a budget get SPC rear arms. if you want the best of the best get SPL. if you must have tophats vorshlag, MSI, and raceseng are all quality options. avoid whiteline com-c like the plague. |
07-28-2015, 08:36 PM | #219 |
the tuna, no crust.
07-31-2015, 06:12 PM | #220 |
Drives: Raven FR-S 6MT
I'm on the same, ST coilovers, 18x9.5 255/35/18, dropped about 1.5". Only visible rubbing I saw when I jacked it up to change tranny fluid, is a small spot on the inner fenderwell probably from going full lock. No fender issues from what I can tell.
The Following User Says Thank You to Terran For This Useful Post: | Fakk (08-02-2015) |
08-01-2015, 11:49 AM | #221 |
So glad they made 18x8.5 +42 so I don't have to deal with rubbing or getting coil overs. Now just to find the best price for that size...
08-01-2015, 03:13 PM | #222 |
Drives: 2014 Argento FRS
08-01-2015, 04:14 PM | #223 |
The Following User Says Thank You to Scuba86 For This Useful Post: | Mikey2style (08-01-2015) |
08-07-2015, 07:14 PM | #224 |
Drives: frs
I'm having a hard time deciding on whether to go with 18x9.5 +40 or 18x8.5 +42 in the rear. It's hard for me to tell how much the 9.5 +40 wheels stick out from flush (poke?). I've seen plenty of above pics of the fronts, but does anyone have pics taken from above for the rears in 9.5 +40s?
Tags |
gramlights 57xtreme, toyo tyres |
Similar Threads | ||||
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 | jadewbj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 378 | 06-26-2017 05:57 AM |
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 10:56 PM |
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 | MVJ1975 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 10-05-2013 02:29 AM |
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 12:44 PM |
