Old 09-21-2018, 02:28 PM   #211
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Major weight reduction breakthrough!
Got all the Tar and under carpet foam out of the interior today
No need for dry ace a few seconds with torch and it turns to goo. Easily scraped up. Also allows you to get the horizontal areas
Tar locations:
Trunk
Behind Rear Speaker
Under Rear passenger foot
Under front seat feet
Side or Radio console
Behind the rear speakers first
rear seats floor and you can see the heavy under carpet foam
side of stereo console
More heavy rubber backed foam
Passenger side done
Foam weight
Tar weight
Heavy chunks
Back together like nothing happened
Final Weight Tally
Under foam = 6.25lbs
Tar = 6.5lbs
New Car weight 2453lbs
SuperTom is offline   Reply With Quote
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
gtengr (09-21-2018), new2subaru (09-21-2018), Tristor (09-21-2018)
Old 09-21-2018, 02:49 PM   #212
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Just think of all you can save if you ditch the plastic trim, carpet, speakers, radio, headliner, AC, Airbags, AC ventilation ducting, air bag computer, seat belt and airbag wiring, windows, regulators etc
The cage? Oh it doesn't weight thaaaaaaatttttt much
Joesurf79 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joesurf79 For This Useful Post:
chaoskaze (10-06-2018), Tristor (10-24-2018)
Old 09-21-2018, 03:04 PM   #213
Lantanafrs2
Drives: 2013 frs red
How much do ear plugs weigh lol? Honestly though, I wish I had the time and money to do a build like yours.
Lantanafrs2 is online now   Reply With Quote
Old 09-21-2018, 03:13 PM   #214
gtengr
Drives: 2017 BRZ
Originally Posted by SuperTom View Post
Final Weight Tally
Tar = 6.5lbs
Props for sharing all these details. Have you taken any corner weights? I'm interested in how the balance may be shifting (or not).
gtengr is offline   Reply With Quote
Old 09-21-2018, 06:39 PM   #215
SuperTom
SuperTom's Avatar
No I would guess from what ive seen with these cars is the driver front has the most weight. Taking out the A/C condenser,lighter seat/mount, windshield washer removal should balance it out.
I have calculated file above
134.25 Front
91.25 Middle
95.5 Rear
removed
Ive got a few more goodies hitting in the next month then I will at least go to a truck stop to get weighted
Old 09-21-2018, 07:31 PM   #216
86TOYO2k17
Drives: 2017 toyota 86
@SuperTom
That rear seat is looking clean.
It looks like it’s extended/flat all the way to the back of front seats?
Can it hold any weight, like groceries or a gym bag?
You update your DIY with what you got now?
That’s one of the next things I plan on doing real soon.
Old 09-21-2018, 07:51 PM   #217
new2subaru
Weight Weenie
Drives: 15 FR-S
Do you have any idea what you car weighs?
Old 09-21-2018, 07:56 PM   #218
SuperTom
SuperTom's Avatar
Originally Posted by 86TOYO2k17 View Post
@SuperTom
Its flat then bolts down to the stock back seat bolt location. Its the same style as the one in my DIY. I just used only coroplast to make it to save some weight. No it won't support weight unless you brace it. Its really just so I don't have bare metal I Still like the car to look stockish with all this weight reduction since I DD it.
The Following User Says Thank You to SuperTom For This Useful Post:
Old 09-21-2018, 08:30 PM   #219
SuperTom
SuperTom's Avatar
Also cut off the Japanese tie downs hooks. Not a lot of weight and a PIA to cut off but incase anyone was wondering the weight. 1.5lbs for both
Had to cut in pieces to get off easier
Painted everything after cutting the welds
only 1.5lbs
Old 09-21-2018, 08:32 PM   #220
Joesurf79
Joesurf79's Avatar
Last time it was on scales was pre cage and fire suppression, and it sat at 2460 ish with an almost empty tank. It's gained the cage tubing, padding, paint, and all the lifeline Zero360 parts. But it also lost the windows, door guts, a bunch of wiring, and has a much lighter exhaust with ace headers, etc now. So to answer your question - right this minute, nope
JeremyR (09-21-2018), new2subaru (09-21-2018)
Old 10-05-2018, 10:24 PM   #221
SuperTom
SuperTom's Avatar
started a post got Seibon Dry carbon doors and trunk. Just installed trunk today, doors will be next!
http://www.ft86club.com/forums/showthread.php?t=130616
Old 10-17-2018, 06:41 PM   #222
SuperTom
SuperTom's Avatar
Finally had nice weather on a day off to complete one of the doors. Took me most of the day to transfer everything over. I believe I can cut a lot of time out when I do the passenger side.
Had a few holes for clips I had to open a bit with a Dremel. But most important was the overall fitment was perfect!!
Bolted up the first time no adjustments made
Getting close to sunset finished in time
Stock door was heavy as fk. Not 50lbs I had heard, my scale says 43lbs stripped
So after I get the passenger side done this will be good for 64.5lbs weight reduction off the car.
Side note one of the bottom window stoppers is a big heavy piece of steel. I could easily make it out of aluminum and chop another pound off each door.
New car weight should be ~2375.25!
The Following 5 Users Say Thank You to SuperTom For This Useful Post:
gtengr (10-17-2018), Joesurf79 (10-19-2018), Leonardo (10-17-2018), new2subaru (10-17-2018), StraightOuttaCanadaEh (10-17-2018)
Old 10-24-2018, 02:17 PM   #223
SuperTom
SuperTom's Avatar
Finished passenger side a few pics of the inside. Also removed these black heavy chunks of steel from inside the door. I thought they may be a window stopper but after moving the windows up and down they do nothing that I can see -1 Free pound!
Everything swapped
Finished!
Heavy chunks of steel 1/2 lb each
Old 10-24-2018, 02:20 PM   #224
SuperTom
SuperTom's Avatar
Also have a new weight loss mod im going to be working on will take my time. This sucker is heavier than I expected. Got a used Dash bar for $100, it weights 17lbs. Going to swiss cheese the FK out this thing!
Understanding Fuel Trims ShadowReaper Software Tuning 13 04-01-2018 01:34 PM
Understanding Compressor Maps arthur93 Forced Induction 31 05-25-2017 10:49 AM
Understanding Oil tofurun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 06-10-2016 04:06 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 07:32 PM
Understanding/clarifying vendor qualifications mav1178 Site Announcements / Questions / Issues 21 03-18-2014 03:25 PM
