#211 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Major weight reduction breakthrough!
Got all the Tar and under carpet foam out of the interior today No need for dry ace a few seconds with torch and it turns to goo. Easily scraped up. Also allows you to get the horizontal areas Tar locations: Trunk Behind Rear Speaker Under Rear passenger foot Under front seat feet Side or Radio console Behind the rear speakers first ![]() rear seats floor and you can see the heavy under carpet foam ![]() side of stereo console ![]() More heavy rubber backed foam ![]() Passenger side done ![]() Foam weight ![]() Tar weight ![]() Heavy chunks ![]() Back together like nothing happened ![]() Final Weight Tally Under foam = 6.25lbs Tar = 6.5lbs New Car weight 2453lbs |
| The Following 3 Users Say Thank You to SuperTom For This Useful Post: |
#212 |
Drives: 2016 White Pearl BRZ Premium
Just think of all you can save if you ditch the plastic trim, carpet, speakers, radio, headliner, AC, Airbags, AC ventilation ducting, air bag computer, seat belt and airbag wiring, windows, regulators etc
The cage? Oh it doesn't weight thaaaaaaatttttt much
#213 |
Drives: 2013 frs red
How much do ear plugs weigh lol? Honestly though, I wish I had the time and money to do a build like yours.
#214 |
Drives: 2017 BRZ
#215 | |
I have calculated file above 134.25 Front 91.25 Middle 95.5 Rear removed Ive got a few more goodies hitting in the next month then I will at least go to a truck stop to get weighted
#216 |
Drives: 2017 toyota 86
@SuperTom
That rear seat is looking clean. It looks like it’s extended/flat all the way to the back of front seats? Can it hold any weight, like groceries or a gym bag? You update your DIY with what you got now? That’s one of the next things I plan on doing real soon. |
#217 | |
Weight Weenie
Drives: 15 FR-S
Do you have any idea what you car weighs? |
#218 | |
| The Following User Says Thank You to SuperTom For This Useful Post: | chaoskaze (10-06-2018) |
#219 |
Also cut off the Japanese tie downs hooks. Not a lot of weight and a PIA to cut off but incase anyone was wondering the weight. 1.5lbs for both
Had to cut in pieces to get off easier ![]() Painted everything after cutting the welds ![]() only 1.5lbs
#220 |
Last time it was on scales was pre cage and fire suppression, and it sat at 2460 ish with an almost empty tank. It's gained the cage tubing, padding, paint, and all the lifeline Zero360 parts. But it also lost the windows, door guts, a bunch of wiring, and has a much lighter exhaust with ace headers, etc now. So to answer your question - right this minute, nope
| The Following 2 Users Say Thank You to Joesurf79 For This Useful Post: | JeremyR (09-21-2018), new2subaru (09-21-2018) |
#221 |
started a post got Seibon Dry carbon doors and trunk. Just installed trunk today, doors will be next!
http://www.ft86club.com/forums/showthread.php?t=130616 |
#222 |
Finally had nice weather on a day off to complete one of the doors. Took me most of the day to transfer everything over. I believe I can cut a lot of time out when I do the passenger side.
Had a few holes for clips I had to open a bit with a Dremel. But most important was the overall fitment was perfect!! Bolted up the first time no adjustments made ![]() ![]() Getting close to sunset finished in time ![]() Stock door was heavy as fk. Not 50lbs I had heard, my scale says 43lbs stripped ![]() So after I get the passenger side done this will be good for 64.5lbs weight reduction off the car. Side note one of the bottom window stoppers is a big heavy piece of steel. I could easily make it out of aluminum and chop another pound off each door. New car weight should be ~2375.25!
| The Following 5 Users Say Thank You to SuperTom For This Useful Post: | gtengr (10-17-2018), Joesurf79 (10-19-2018), Leonardo (10-17-2018), new2subaru (10-17-2018), StraightOuttaCanadaEh (10-17-2018) |
#223 |
Finished passenger side a few pics of the inside. Also removed these black heavy chunks of steel from inside the door. I thought they may be a window stopper but after moving the windows up and down they do nothing that I can see -1 Free pound!
Everything swapped ![]() Finished! ![]() Heavy chunks of steel 1/2 lb each
#224 |
Also have a new weight loss mod im going to be working on will take my time. This sucker is heavier than I expected. Got a used Dash bar for $100, it weights 17lbs. Going to swiss cheese the FK out this thing!
| Understanding Fuel Trims | ShadowReaper | Software Tuning | 13 | 04-01-2018 12:34 PM |
| Understanding Compressor Maps | arthur93 | Forced Induction | 31 | 05-25-2017 09:49 AM |
| Understanding Oil | tofurun | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 06-10-2016 03:06 PM |
| BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 06:32 PM |
| Understanding/clarifying vendor qualifications | mav1178 | Site Announcements / Questions / Issues | 21 | 03-18-2014 02:25 PM |
