Old 12-21-2018, 01:01 PM   #211
churchx
churchx's Avatar
Drives: 2014 GT86
If you like travel & bite point as is - no. Spring just makes a bit easier to press clutch pedal. Removal of it - just harder to press clutch (but thus also easier to "feel" bite point).
Old 12-23-2018, 10:07 AM   #212
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by churchx View Post
Isn't TOB in contact all the time (just that not pushing against leaf springs, when pedal not pressed)?
It should not be. Permanent contact would ensure premature failure.
As illustrated in the video (and experienced by myself) the spring removal introduces ~1mm of play in the pedal. That play is important because it means there's no force acting against the TOB. Clutches that use a clutch cable have to have their play manually adjusted into them while hydraulic clutches are self adjusting on their play.
This is a pretty stout little spring and it's acting against the pedal (trying to push it in) and without any definitive evidence I surmise that it may be enough to be equivalent to someone resting their foot on the pedal and keeping the TOB in contact. There is NO WAY that removing the spring will have a negative impact on the life of the TOB - in fact it's the other way around. Considering how many people have premature TOB failures it's more likely that leaving it in is a possible culprit of those premature failures. Even if it's not - removing the spring is not a risk to your TOB whatsoever.
PRO86 | STL | LuckyDog
Old 12-23-2018, 10:16 AM   #213
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
For what it;s worth to those of you who are considering this, I removed this spring about 40,000 miles ago. I did no clutch pedal adjustment. TOB with 60,000 miles on it is still dead silent and everything is wonderful.
Old 12-30-2018, 05:19 PM   #214
Legend@wheels
nenber
Any cons by doing that?
As far as i get it -i just remove the spring and thats it?
Sent from my SM-G960F using Tapatalk
Legend@wheels is offline   Reply With Quote
Old 12-30-2018, 05:57 PM   #215
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
No proven cons other than heavier clutch. Apparently this will bother you only if you are a weakling or a child. I am obviously one of these, as I found it a bit heavy for daily use, so got the MTEC spring. Try it without and see. Without a spring there will be bit of loose travel pedal right at the top - if you don't like this (I didn't) just adjust the brake light switch just enough to stop it.
That's good info.
jonboy99 is offline   Reply With Quote
Old 01-06-2019, 12:00 AM   #216
suzyj
Drives: 2018 86 GTS
Just spent the last couple of hours trying to get the pin out, with no success. On my RHD the spring assembly is buried up in a channel, with a metal plate either side. I was able to pop the e-clip off reasonably easily, but the plate prevents the pin from coming out. I suspect I’d have to pull the whole pedal assembly out to get it apart.
suzyj is offline   Reply With Quote
Old 01-06-2019, 02:58 AM   #217
churchx
churchx's Avatar
Drives: 2014 GT86
Yeah, heard that it's harder mod to do on RHD. Then again, RHD cars may have better accel pedal stock placement for heal & toe, if i recall correctly.
Old 01-06-2019, 03:57 AM   #218
suzyj
Drives: 2018 86 GTS
I’ve given up - I’ll order the 19mm slave and try that instead. I’m much too old for this lying on my back with my head under the dash stuff.
Old 01-06-2019, 05:27 AM   #219
Legend@wheels
nenber
Lol
Im also up to that.
Old 01-06-2019, 05:48 AM   #220
86MLR
86MLR's Avatar
RHD
https://www.ft86club.com/forums/showthread.php?t=117628
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 03-10-2019, 10:11 PM   #221
Larphraulen
Drives: 2018 Subaru BRZ 6m; 2012 VW GLI 6m
For those that have done this: any issues regarding the play at the top of the pedal? I'm on the fence as I also had some concerns about it affecting the TOB.
Larphraulen is offline   Reply With Quote
Old 03-11-2019, 04:43 PM   #222
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
Honestly, I don't even notice the play at the top. I was concerned about that as well when I first did this, but after removing the spring I've found it to be basically a non-issue. I really don't think just the weight of the pedal itself is enough to actually affect the TOB in any meaningful way.
qcbaker is offline   Reply With Quote
Old 03-11-2019, 04:49 PM   #223
15limited
15limited's Avatar
This has been done for years, probably by the hundreds. Let's not be neurotic about a 10 minute removal/install DIY.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-21-2019, 12:49 PM   #224
Xerophthalmic
Drives: '17 BRZ Limited PP CWP
In the stock arrangement, I haven't allowed anyone to drive my car, not even my own mother. After removing the spring, I would! The clutch pedal now gives the feedback I was accustomed to in the past. Makes me think that, in stock form, learning to drive a manual on this car would be harder than necessary.
Xerophthalmic is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
