Old 02-01-2018, 09:15 PM   #211
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Option B
Old 02-01-2018, 09:51 PM   #212
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by VerusEric View Post
I apologize, is this better?
Paul compiled data for the wing! This will be considered our low drag, high-efficiency wing. We have a maximum efficiency, also known as L/D, of 11.5. This was made possible by developing the wing directly in CFD using optimization studies in ANSYS.
Oh, stahp.
Great stuff here!
Option B purely for aesthetics but I seriously doubt anyone would care either way. You have a strong rep for function over form.
Old 02-01-2018, 11:17 PM   #213
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
On option a vs b, I would mock up some cardboard and put it on a full car to get a better idea. Aesthetically, you would want it to match the character of the car, rather than just looking at one piece of it.
I'm guessing those graphs are from CFD as well? Or is that actually wind tunnel data? Was the car body included in that, or just wing by itself?
Any idea what's going on at 110-120? Looks a bit like separation, but I would expect the speed of that to decrease as AOA increases.
Also, what's the data look like around highway speeds? From eyeballing it, looks like drag bottoms out at 5lb?
Old 02-02-2018, 12:54 AM   #214
arthur93
Drives: Toyota 86 GTS
Will there be a difference in the performance of option A to B? as @Ultramaroon mentioned, you guys have a history of going for function over form. I think that differentiates you from the rest of the industry. If I had to choose, I am leaning slightly to option B but I think the majority of your customer base wants your items due to their performance, not the look. My 2 cents
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 02-02-2018, 02:50 PM   #215
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I'm all for whatever gives the most performance. The wing is going to look sick regardless.
pgranberg11 is offline   Reply With Quote
Old 02-02-2018, 04:09 PM   #216
acollite
Drives: 2013 frs whiteout
not a big difference visually but i think option B looks a little better
acollite is offline   Reply With Quote
Old 02-03-2018, 09:17 PM   #217
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Oh, stahp.
Great stuff here!
Option B
I appreciate all the opinions! We're printing out the uprights right now to help us visualize this again. I already printed it out but because I printed one in purple and another in black, some guys feel it biased the mounts. I have more black on order and will print it this coming week.
The mounts do not change function, weight remains roughly the same, and with FEA we can make both styles strong enough to handle the load.
Those graphs are CFD, which is a virtual wind tunnel. These specific data points are of the wing only, not on the car although we have all that data as well.
Are you referring to the downforce or the efficiency? It is not separation in either case.
Drag would reduce further at highway speeds, it does not bottom out as it is dependent on airspeed. The slower you go, the less drag and downforce is produced.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 02-08-2018, 08:39 PM   #218
VerusEric
VerusEric's Avatar
We decided against printing out the upright in black, so here is the purple beauty in all her glory. We have finalized a shape for the upright we thoroughly like as do others that care about the visuals; we're getting those cut shortly out of 6061.
0 degrees AOA
13 degrees AOA
The wing was developed in CFD on and off the car to make sure we hit maximum efficiency. That is how we were able to have a wing that will produce 11.5 lbs of downforce for every 1 lb of drag; which is quite impressive for a wing!
The picture below is part of that CFD. This is an on car wing analysis that was done for optimization of the height of the wing from the trunk lid. The height is critical to verify clean air is interacting with the wing. Too low and we do not achieve proper airflow under the wing and lose efficiency. Too high and we are getting unnecessary drag, reducing efficiency, and a larger moment which will change the aero balance of the car.
Thanks,
Eric
Old 02-09-2018, 06:29 AM   #219
arthur93
Don't know if this is possible, but are you guys able to provide data when all of your products are combined on the one vehicle? Pretty sure you posted some numbers with the rear diffuser, front splitter and end plates but would be interested to see what happens when the canards and wing is added. Really interested to see what the aero balance would look like.
Instagram: artym93
Old 02-09-2018, 12:46 PM   #220
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Wing looks great. Do you have any angles from the rear showing the width? Also is it feasible to mount it further back on the trunk if some sort of reinforcement was made to not distort the trunk?
laextreme5 is offline   Reply With Quote
Old 02-09-2018, 12:57 PM   #221
ichitaka05
Site Moderator
ichitaka05's Avatar
Looking good!
Old 02-09-2018, 01:28 PM   #222
Brayden_23
Drives: Asphalt 2015 FRS
Just an idea: what if instead of those 2 silver bolts on the bottom of the upright there was a flange around the bottom to make it sit flush? Could give an overall cleaner appearance IMO.
Any chance we can see a side view of the CFD analysis?
Brayden_23 is offline   Reply With Quote
Old 02-11-2018, 08:44 PM   #223
VerusEric
VerusEric's Avatar
Yes, we will be making all the data available in the coming months.
See below. It could be I guess, but that type of mounting and reinforcement would be up to you.
With the aluminum uprights we prototyped (months ago), we tested some weight on the wing on the car. This is 160 pounds, which isn't a ton but enough to test how the uprights, mounts, and wing handle that weight at this point. So far so good.
Thanks,
Eric
Old 02-11-2018, 10:57 PM   #224
grichardt
grichardt's Avatar
I have mixed feelings on the way this looks but I’m intrigued to say the least. I’m in southern Indiana... I need to come check you guys out! Love the vents and will be getting the diffuser and splitter next.
grichardt is offline   Reply With Quote
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 712 12-11-2018 10:13 PM
Hancha BRZ/FR-S/GT86 Aero Parts Development Thread Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 57 03-24-2014 05:40 PM
Raceseng | Development FT86 | Build Thread Raceseng Member's Car Journals 17 06-06-2013 09:22 AM
