#2199 |
Drives: T
#2200 | |
That Guy
Drives: 2013 asphalt FRS MT
The question of sound quality isn't as easy as good vs bad. The stock HU has a ton of DSP happening in the background to correct for issues with the stock speakers, their location, and cabin reflections. All in all, that helps a lot. But, it also removes a shit ton of low end, and if you're going to do anything more than the stock speakers all of the DSP is a huge hindrance. The sound quality of the Dashlinq 4 is great, I don't get any discernible noise from the amp, the front end sounds clean... It's a great place to start making a system. With the stock speaks I've got about 4 dB removed at IIRC 3K Hz. And about 3 dB removed from the lowest adjustment as the stock speakers can't reproduce those frequencies anyway. To flatten out the result of the -3 dB I also have about 1.5 dB increase on the next adjustment. (That's all going from memory, I might be off a bit.) All that said, I really need to get a condenser mic to see what's really happening before I get my DSP setup this winter. So far I'm just tuning by ear. |
#2201 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I feel my speakers may be shot and that is why I don't think it sounds that good haha!! I was moving the balance around and only 1 speaker sounds clean the rest are crap.
#2202 |
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Since you're talking about the speakers, I feel I should once again voice my very strong recommendation for the OEMAudio+ speaker kits for the FT86—in particular the Reference 400CF.
It replaces the factory tweeters in the dash and the 6.5"-ers in the doors, adds a new fitted subwoofer enclosure in the trunk which includes new amps, and bypasses the factory amp and the stock dashboard mids. The new main DSP amp will be specifically programmed for whatever HU you're using (they ask you when you order what HU you plan to use), and they can program the subwoofer at 3 different levels ("balanced", "full", or "robust" IIRC; I picked the middle level, as I like some thump, but not too much). A bit pricey, yes, but well worth it if you want a great sound system in your 86. |
#2203 |
Drives: 2015 FR-S
I'm having trouble updating to adjust the default volume level from 14. My bluetooth version is 20150126 and there is no updates in the download section in the ca-fi site for that. The topmost one is "Ca-Fi Dashlinq4 firmware update DVR support March 18 2015" so I assume that is the latest one. When I download that, it doesn't come with a MCU file. The other updates do come with a MCU file. Do I just use that MCU file from the older updates?
After that, you must upgrade MCU: 1) Delete all dta from the sd-card; 2) Copy the file "letou_mcu.bin" from the downloaded archive to the root of the memory card (memory card must include only the file "letou_mcu.bin" and nothing more); 3) Turn on the head unit in the normal mode and wait when it is fully loaded. Insert a memory card into the slot. Click on the "Settings" on the desktop android interface and go to the "About system", then go to "Update MCU" (section also may be called "Updating the microcontroller"). Confirm the MCU update start. The device will reboot. Again, go to the "Settings" section of "About system" and click on "Update MCU", confirm the upgrade. Wait until the flashing MCU. At the end of the device will reboot again. All I'm looking to do here is just change that default volume level from 14 to 0 so it doesn't blast on when I turn the car on. I took that topmost update and used notepad to edit the file so the volume is 0. So can I just update the on the firmware and not on the MCU? In the update directions it says you must update the MCU but is that not necessary as the MCU hasn't been updated since the old firmware updates? Last edited by Impureclient; 11-10-2015 at 12:51 AM. |
#2204 |
Complete Newbie
Drives: 2016 Toyota GT86(FRS)
Can someone tell me what the experience is like with kitkat, super old processor and 1 gig of ram for someone with a newer phone?
My only introduction to android is lolipop, a 1080p screen, octacore processor and 4 gigs of ram. I feel like this is Insanly outdated tech for what this thing is.. |
#2205 |
Drives: FR-S: Firestorm
Well as much as it pains me to say this...I'm not happy with the purchase. After having it for a few months I found the interface to be sluggish and the ipod controls to be lacking, but worst of all, none of the 3 powered amps I bought work properly with it. I will attempt to try a firmware update but I think I have a dud.
#2206 | |
Drives: 2015 FR-S
It's nowhere as fast as a newer android phone but if you're just using it to listen to music and a few things, it's fine. I did watch a cartoon while waiting for pizza, which looked fine, but don't use it to do much other than play music while i drive and pop addresses in to use as a GPS device when I do estimates. I also searched a little on Google and that ran fine also. I put the app "HERE" in it, downloaded all the maps for Florida with home wifi in my garage and now have permanent maps ready to go. It is most definitely better sounding and louder than the stock unit. Do they even sell android had units similar to this that are have updated android for even close to the price of this? New phones are running around $600-700. This thing was $468 shipped. If I was going to want something faster, I'd probably just wire up a lap top inside if I wanted faster/better. Unless you are sitting in your car and using the stereo as a workstation and need a speedy device, I think it's fine for what it does at the price point. |
#2207 | |
Drives: camry
Android auto latest version does work for headunits. Try downloading it from play store. Bitspice has taken off automate from playstore. |
#2208 |
Anyone who has successfully mounted their Dashlinq CT want to tell me which holes they used? Using the holes I've circled feels the most "natural" to the bracket, but using those means that the front panel will not snap in. I've seen that on the Dashlinq4 there was space to move the bracket forward by cutting off the tabs or sanding them down, but then I only get one bolt hole instead of a full 4.
#2209 | |
Not Bаnned Anymore
#2210 |
Drives: 2014 Scion FR-S
Ok so I've been out of the loop a while. I want to re flash my unit but heard the latest update although rooted does not allow edits to the system partition. Is this accurate?
Sent from my SM-N920T using Tapatalk |
#2211 | |
#2212 |
Many thanks.
Anyone got a good setup using viper and subwoofer? For some reason xfhifi is the only viper working for me. Anemic when using sub out. Barely moves speaker. Regular speaker RCA out works. Sent from my SM-N920T using Tapatalk |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 07:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 04:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 05:58 AM |
