Old 04-26-2015, 01:35 PM   #2185
sidesleeper
Drives: BRZ series blue
Anything open source, you're pretty much on your own. The only support you get is the "support" you find online. That picture is hilarious.
sidesleeper is offline   Reply With Quote
Old 04-26-2015, 01:47 PM   #2186
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
If you get a tune from a tuner with OFT I'm pretty sure they'll give you support. If not, that's a tuner problem, not an open source problem.
That picture is hilarious because it implies something that doesn't even make sense based on that picture.
Old 04-26-2015, 04:48 PM   #2187
bfrank1972
Drives: 2013 FR-S Argento
FYI there's nothing 'open source' about OFT, it's just another tuning platform. And they do support/stand behind their product 100%.
bfrank1972 is offline   Reply With Quote
Old 04-26-2015, 04:52 PM   #2188
bfrank1972
Originally Posted by Thorpedo View Post
Wrong. I've personally done it, it went fine.
Wrong again, see above. The end user can also edit the tunes themselves, so this is WAY off.
@DeliciousTuning sums it up perfectly.
With a device that the end user does the vast majority of the work, people are bound to get confused. 99.9% of problems are user error. It is extremely rare to see a "problem" that has anything to do with the device, or tunes themselves. Grow up, pull your head out of the hole that is in the sand and have a good look around. You should perhaps do a little reading before you make these hilarious claims that make you look a tad....silly. You didn't answer my question, care to try again?[/QUOTE]
Hah - I suspect Mike is pretty aware of what he's talking about - doesn't mean it's unbiased fact though. As much awe I have for his driving skills, I have even more awe for ability to crank out BS
The Following User Says Thank You to bfrank1972 For This Useful Post:
Boofneenee (04-26-2015)
Old 04-26-2015, 09:19 PM   #2189
Raven240
Drives: 2015 Release Series 1.0 FRS
Do I need to upgrade my stock radiator for my JR supercharger + oil cooler? Koyo? Skunk2? Mishimoto? I've heard bad reviews for Koyo?
Thanks
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
Raven240 is offline   Reply With Quote
Old 04-26-2015, 09:23 PM   #2190
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Thanks
In probably 90+% of the cases, it's not necessary. Stock radiator is good enough.
ApolloSki is offline   Reply With Quote
The Following User Says Thank You to ApolloSki For This Useful Post:
Raven240 (04-27-2015)
Old 04-26-2015, 09:24 PM   #2191
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
I never changed mine or needed one. Stock does a good job keeping it cool
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following 2 Users Say Thank You to *LongFella For This Useful Post:
0351USMC (04-27-2015), Raven240 (04-27-2015)
Old 04-27-2015, 02:15 AM   #2192
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Yup, Jenny is running great!
0351USMC is offline   Reply With Quote
The Following User Says Thank You to 0351USMC For This Useful Post:
*LongFella (04-27-2015)
Old 04-27-2015, 03:03 AM   #2193
Thanks
Are you having heat problems?
I've never seen anyone NEED an upgraded radiator, without having significantly increased output beyond CARB levels.
Old 04-27-2015, 02:28 PM   #2194
Raven240
Thank you all for your help. My JR kit comes in the mail tomorrow. I'm excited. I just like to maximize purchases up front if I need to.
Thank you all!
Old 04-27-2015, 08:51 PM   #2195
Thank you all!
Here's the common upgrade paths.
- Oil cooler (if you canyon or track, you should have this)
- Flex fuel, injectors, fuel pump, and flex fuel tune (if you crave more power, and have e85 available readily)
- Headers, overpipe, front pipe, custom tune (if you want more power, without ethanol)
- Radiator + fans (if you track AND run E85 AND have headers/front pipe)
Old 04-27-2015, 09:19 PM   #2196
dp1
driving smoother faster
Drives: Sold
And BBK to slow it all down
dp1 is offline   Reply With Quote
Old 04-27-2015, 11:12 PM   #2197
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Order placed today, can't wait
Jmonty is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmonty For This Useful Post:
CSG Mike (04-28-2015), ScionOfHorus (04-27-2015)
Old 04-27-2015, 11:31 PM   #2198
dj2020
Owners: how often do you guys clean the air filter? And particular way I should do this? There are a few videos on YouTube that I can follow for cleaning /oiling K&N air filters.
dj2020 is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
