Sam Strano
Old 02-06-2015, 11:29 AM   #2185
vroom4
Just wait for hancook, they didn't release until after Dixie last year either.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
SeanRTR (02-06-2015)
Old 02-06-2015, 11:44 AM   #2186
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by SeanRTR View Post
Well for you guys subscribing to the heavy wheel theory, I have a real fast set of 22lbs rims that look at a lot like the OEM wheels, I'd let go for just 200/wheel. So you let me know. I'd also be willing to trade straight up for Enkei RPF1's.
Do they come with extra heavy counter-weights?
The Following User Says Thank You to 7thgear For This Useful Post:
afoust50 (02-09-2015)
Old 02-06-2015, 12:39 PM   #2187
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I was initially interested in the rotating mass discussion based on tire weights, not wheel weights so much. Generally the wheels we all use in CS don't change size, but they do get lighter. Tires on the other hand are a greater variable. As we seek to increase traction with wider tires, weight increases as well. Is a 225 faster then a 215 even if it's 3lbs more? Is a 245 faster than a 235?
What's interesting to me is that the 215s vs 225s brought up in previous posts have a 3lb difference and only a minor change in tread width. Is the carcass that much stiffer? Would stiffer side walls (higher tire load rating) decrease autoX run times?
I have to order tires in a few days and am leaning towards 235 RS3s and I can't stop speculating!
Briankbot is offline   Reply With Quote
Old 02-06-2015, 12:47 PM   #2188
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
stiffer sidewalls are generally a better thing to have, mainly for transient response.
grip is nice but if the tire needs more time to change direction then you're at the track designer's mercy.
Old 02-06-2015, 01:09 PM   #2189
vroom4
Well 235 40 17 rs3 probably isn't in stock hah
Old 02-06-2015, 01:16 PM   #2190
qoncept
qoncept's Avatar
Most of the penalty for extra width has to be coming from being pinched, not the extra weight. And I would put exactly 0 faith in per size tire weights being accurate anyway.
Bottom line, to me, is that we're all still talking about them, so there is no clear cut tire and size. 10 years ago the answer (when I was in STX) was Azenis in whatever size fit. This is more fun.
qoncept is offline   Reply With Quote
Old 02-06-2015, 02:03 PM   #2191
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Looks like it's gonna be 245/40 ZII* for me!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 02-06-2015, 02:05 PM   #2192
TrqlessWonder
Drives: 2014 FR-S
It was the answer in Stock 2 years ago as well. "I want a real shot at the win." Okay then, put the widest hoosier on there that will fit. Not cheap, but it was simple.
Now we've gone nuts trying to do both formal and armchair testing to see what size of what compounds work in what environments, tossed in with the variables (if you're doing mostly internet watch-and-wait) of whether or not the guy who loves a certain tire:
a - is driving a similar car
b - in a similar climate
c - is consistently fast
d - and actually knows what the heck they are talking about
It'll be nicer, though, when the tire companies stop introducing 3+ new/updated tire models every season.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 02-09-2015, 10:37 PM   #2193
u/Josh
Drives: GBS Limited 6MT
Any alignment tips for a simple (camber bolts, rs3 v2) c street car? Of course as much camber as I can get up front, but what should I be trying for with toe? The car is daily driven, but not on the RS3s and I'm not too concerned about wear.
u/Josh is offline   Reply With Quote
Old 02-09-2015, 10:55 PM   #2194
renfield90
The Stig's German cousin
I went with 0 toe up front and factory spec toe in the rear. Some toe out up front would be nice - you don't realize how lazy your car's turn in is until you try this, but that can make highway driving tricky. I've never felt a need to change rear toe.
Old 02-10-2015, 08:16 AM   #2195
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
My 1/32 toe out up front (each side) isn't TOO darty but you do notice it a little.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-10-2015, 11:16 AM   #2196
qoncept
qoncept's Avatar
There's a post somewhere that shows leaving the tie rods alone and maxing out front camber with crash bolts adds something like 1/32" toe in (from a factory alignment), but I can't find it. I did just that and left haven't touched the toe yet. Probably will this spring.
Old 02-10-2015, 11:18 AM   #2197
engee
Drives: Subaru
Anyone else notice that Hankook is no longer offering contingency for Pro Solo or Solo national tours?
I just checked today on SCCA site and didn't see it. Not saying I was going to win an event, but it would've been nice to get something in the offchance that I did.
engee is offline   Reply With Quote
Old 02-10-2015, 11:19 AM   #2198
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Many are expecting it to be added later, probably when the tire is actually available.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
