Old 01-09-2015, 12:19 AM   #2171
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Originally Posted by cuddefred View Post
I'm pretty sure it is much nearer to 105mph in the manual than the figures you mention here
Correct 107 mph is where I feel the dip then about 2 seconds later starts picking up again
el-92 is offline   Reply With Quote
Old 01-09-2015, 12:25 AM   #2172
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by themajesticone View Post
I don't feel like writing a lot right now but I would suggest reading/searching for past conversations between jamesm and shiv as well as some of the recent 'software tuning' threads that are active right now at the top of the list. Do some research. I have had my OFT for a year now and as time progressed I became more and more disappointed, mostly in the responses read as well as their fail business model
In fairness, you really should elaborate since you are suggesting our engines will fail. I have read most of the tuning threads and come to the conclusion that you can't please everyone. Some peoples expectations of what a tuner or of tuning platform can do are unrealistic based on a dyno graph or without data.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-09-2015, 12:27 AM   #2173
el-92
el-92's Avatar
If you can log it. would be helpful in diagnosing any issue.
Suggest
rpm
load
flkc
Knock Correction
IAM
AFR
Commanded AFR
Throttle plate
IAT
LTFT
STFT
MAF
speed
Black engine speed .blue maf .green Afr.
Old 01-09-2015, 12:38 AM   #2174
steve99
looks like something caused throttle plate to close Mass Air flow drops considerably. That kind of thing can happen if traction/stability kicks in
do you have a staggered wheel setup ie different diameter wheels/tyres size front/back ?
Probably need injector pulse widths for port/direct to see if its fuel cutting as well.
Your considerably richer than OL Fuel table do you have standard intake ?
or was that first tank of E85 with a fair bit of petrol left in tank.
would be good to see raw data with all parameters
Old 01-09-2015, 12:52 AM   #2175
el-92
el-92's Avatar
Nope stock wheels stock tires probably been on e85 for over a month now . so not my first tank . k&n drop in filter perrin inlet hose .and a cat and muffler delete but that shouldn't affect the car like that should it ?
Old 01-09-2015, 01:07 AM   #2176
steve99
nope as long as no intake leaks or exhaust gasket leaks near 02 sensors. those will upset either MAF reading or 02 sensor readings. This can cause problems. If that K&N is oiled filter , sometimes oil can get on maf sensor if over oiled and cause issues, probably worth cleaning maf sensor.
It usually seen in logs as high fuel trims and large differences in commanded afr and actual afr.
I cannot remember off hand what the front o2 sensor is scaled to but I think its rich max is about 11.3 afr and your afr is flatlining which makes me think that it may actually be richer than 11.3 as the sensor has hit its limit.
This may be the issue, anyhow shiv is going to look at it I believe.
check out your LTFT if its 10% or more indicates problems like exhaust intake leaks dirty maf sensor ect. and your running at least 11.3 or richer when the OL fuel table is about 12.2 to 12.5 from memory.
That tune was actually intended for cat-less header , so the combination of catted header and other exhaust mods may also be contributing.
el-92 (01-09-2015)
Old 01-09-2015, 01:29 AM   #2177
el-92
el-92's Avatar
Yeah its the drop In its oiled . and the Afr the lowest it goes is 11.6
Old 01-09-2015, 12:55 PM   #2178
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Shiv@Openflash View Post
I'll be in LA on Saturday. If you can reproduce what you are describing and show it to me, I'd love to see/log it.
I have it logged. Seems it's not just in 6th for me. Will do it in 4th-6th right around 4000-4500. I'll find it and post it.
Edit: RPM Hang
This is on the 1.60. I have updated to the latest file and it doesn't happen as much, but it does still do it. 93 and e85.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
el-92 (01-09-2015)
Old 01-09-2015, 01:16 PM   #2179
el-92
el-92's Avatar
Edit: RPM Hang
Yeah my friend that tunes Hondas said if I ave it in 6th I'm going to have it in other gears as well .
Old 01-09-2015, 02:10 PM   #2180
phrosty
Edit: RPM Hang
Judging by your KC Learned, you've experienced some knock right at that point so it's pulling timing.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 01-09-2015, 02:56 PM   #2181
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not necessarily. Look at the MAFv and load, it drops a fair bit. That could mean a different advance value which would be depicted by the KC learn value drop. Without logging FLKC it's unclear.
What I would be concerned with is why the change is occurring. The throttle doesn't seem to be shutting so it's got to be cam or MAF sensor related.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-09-2015, 04:07 PM   #2182
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Here's my thread on the issue too:
http://www.ft86club.com/forums/showthread.php?t=80260
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
el-92 (01-09-2015)
Old 01-09-2015, 07:34 PM   #2183
steve99
http://datazap.me/u/steve99/e85-200k-learn-155?log=0&data=1-2-3-9&solo=2&zoom=390-720
above is log of my car running oft E85 tune, unmodified and completly stock car , so it does not occurr on all cars
i am now running with catless uel header still no issue on standard oft tune E85.
currently running modified oft E85 tune to suit our high grade guaranteed 85% ethanol pump fuel here , still dont get that issue.
not saying it does not happen but must be some combination of fuel car mods ect that causes it.
DustinS (01-10-2015)
Old 01-10-2015, 03:51 PM   #2184
DustinS
DustinS's Avatar
At that point the car only had a filter. Everything else was stock, and on a unmodified e85 tune( it did it once or twice on the 93 tune, but I wasn't on it long enough to record it as a concern) I can't imagine just a filter causing issues? It happens a lot less on the current map. I need to check for updates and try logging a couple more to see if it comes back.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
