#2171 |
Drives: 2014 ASPHALT FR-S MT
#2172 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
#2173 |
Black engine speed .blue maf .green Afr.
#2174 |
Drives: FT86
looks like something caused throttle plate to close Mass Air flow drops considerably. That kind of thing can happen if traction/stability kicks in
do you have a staggered wheel setup ie different diameter wheels/tyres size front/back ? Probably need injector pulse widths for port/direct to see if its fuel cutting as well. Your considerably richer than OL Fuel table do you have standard intake ? or was that first tank of E85 with a fair bit of petrol left in tank. would be good to see raw data with all parameters |
#2175 | |
#2176 | |
Drives: FT86
It usually seen in logs as high fuel trims and large differences in commanded afr and actual afr. I cannot remember off hand what the front o2 sensor is scaled to but I think its rich max is about 11.3 afr and your afr is flatlining which makes me think that it may actually be richer than 11.3 as the sensor has hit its limit. This may be the issue, anyhow shiv is going to look at it I believe. check out your LTFT if its 10% or more indicates problems like exhaust intake leaks dirty maf sensor ect. and your running at least 11.3 or richer when the OL fuel table is about 12.2 to 12.5 from memory. That tune was actually intended for cat-less header , so the combination of catted header and other exhaust mods may also be contributing. |
| The Following User Says Thank You to steve99 For This Useful Post: | el-92 (01-09-2015) |
#2177 | |
#2178 | |
Drives: 2013 Ultramarine FR-S
Edit: RPM Hang This is on the 1.60. I have updated to the latest file and it doesn't happen as much, but it does still do it. 93 and e85.
| The Following User Says Thank You to DustinS For This Useful Post: | el-92 (01-09-2015) |
#2179 | |
#2180 | |
#2181 | |
Drives: UK GT86
What I would be concerned with is why the change is occurring. The throttle doesn't seem to be shutting so it's got to be cam or MAF sensor related.
.: Stealth 86 :.
#2182 |
Drives: '13 Raven FR-S, MT
| The Following User Says Thank You to ck-GT86 For This Useful Post: | el-92 (01-09-2015) |
#2183 |
Drives: FT86
http://datazap.me/u/steve99/e85-200k-learn-155?log=0&data=1-2-3-9&solo=2&zoom=390-720
above is log of my car running oft E85 tune, unmodified and completly stock car , so it does not occurr on all cars i am now running with catless uel header still no issue on standard oft tune E85. currently running modified oft E85 tune to suit our high grade guaranteed 85% ethanol pump fuel here , still dont get that issue. not saying it does not happen but must be some combination of fuel car mods ect that causes it. Last edited by steve99; 01-10-2015 at 02:13 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | DustinS (01-10-2015) |
#2184 |
At that point the car only had a filter. Everything else was stock, and on a unmodified e85 tune( it did it once or twice on the 93 tune, but I wasn't on it long enough to record it as a concern) I can't imagine just a filter causing issues? It happens a lot less on the current map. I need to check for updates and try logging a couple more to see if it comes back.
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
