04-14-2017, 09:29 PM | #2171 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Depends what offset you're looking at. 18x9.5" +45 don't rub there with 255 or 265. If you're going +38 it is likely you will.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
04-15-2017, 10:40 AM | #2172 |
Drives: 2015 Scion frz
04-16-2017, 12:50 AM | #2173 |
Drives: 2013 Subaru BRZ, AVO Stage 2 Turbo
18x8.75 XXR 257s Bronze Plasti Dipped
255/35/18 Firehawk Indy 500 square |
04-16-2017, 08:39 AM | #2174 |
Drives: Subaru BRZ 2017 (almost)
Anyone know whether stock brakes will clear a 18x9.5-30 L13P Work rim? Looking to get stancenation x aimgain type 2 kit.
Thanks Sent from my Nexus 6P using Tapatalk |
04-16-2017, 10:41 AM | #2175 |
The mix of blue on that gold is cool looking!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
04-17-2017, 12:29 AM | #2176 |
Drives: 2015 BRZ Limited
05-14-2017, 12:12 AM | #2178 |
Lowered more. Was rubbing and still is rubbing front inner chassis lol. Printer for shop wasnt working not sure what specs but brought rear out to +36 with LCA.
05-14-2017, 05:53 AM | #2179 |
Drives: 2017 Toyota 86
new pic, same setup
05-14-2017, 06:02 AM | #2180 |
Sick. I'm getting Bronze TE37's in 18x9.5+38 when i sell mine
05-14-2017, 02:27 PM | #2181 |
Drives: '14 WRB BRZ | '17 CB STi
Finally got mine installed. 18x9.5 +45 squared with MPSS 265/35/18s. Only rubbing so far is when turning at full lock. I have a set of rack limiters I need to put on, so that should be resolved shortly. I may lower it about 1/3 of an inch more, but it's sitting pretty decently as is.
PR138
IG: @pr.138 2008 LBP Honda S2000 2013 UM Scion FR-S |
05-14-2017, 04:35 PM | #2182 |
@rayhere
The Following 8 Users Say Thank You to rt For This Useful Post: | 15limited (05-16-2017), PR138 (05-15-2017), rookietopro_frs (07-24-2017), slow15frs (05-15-2017), stevesnj (05-16-2017), strat61caster (05-17-2017), swarb (05-14-2017), VMRamos (08-11-2017) |
05-14-2017, 05:26 PM | #2183 |
Drives: 2015 BRZ CWP
Went back to wide set up. CE28SL 18x9.5 +45 255/35-18RE71R Sent from my iPhone using Tapatalk |
05-14-2017, 08:40 PM | #2184 |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
