#2157 |
Drives: WR Blue BRZ, 240Z
It's the part-time nature of the ESC that allows the car to operate as a NA car for the vast majority of the time. For example, if I drive a 70 mile trip @ 70 mph I'm driving for one hour. During that trip I may engage the ESC 6 times, 10 seconds each engagement. That results in 0.016% in boost (1/60th) and 98.3% NA. There is no parasitic loss or partial boost that consume fuel. Turbos do have parasitic loss due to pumping loss (heat and an exhaust system that is less then optimal). SC have significant pumping loss right at the crank.
Fenton is correct, I had my stock ECU tuned shortly after I installed the ESC, so my mileage increases are probably a result of my tune. Since I run 98% of the time NA, the ESC doesn't make a measurable impact on economy on the highway. Around town my last full tank resulted in 28 mpg. That included a lot of engagement of the ESC. Over the last 35 years I've owned several turbocharged cars. So far I prefer the boost on demand nature of the ESC.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#2158 |
Drives: Subaru BRZ 2013
Hey Guys,
Any idea on a potential release date? been following this thread on and off for sometime, just curious. |
#2159 | |
Drives: FR-S 10 #103 AT
When he is satisfied that his creation is ready to go, that is, it makes power, is easy to install, is reliable, and won't blow up somebody's pride and joy, he'll make it available to us.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#2160 |
#2161 | ||
Drives: Passat
As for the increased fuel economy that you are seeing post-ESC and post-tune, consider that many changes to the ECU programming also affect it's mpg calculations. When I turbocharged my Scion XB I installed 20% larger fuel injectors. The ECU reported an increase of 5-10 mpg due solely to the larger fuel injectors. I believe that your tune may very well be responsible for an increase in ECU calculated MPG but also believe that it is very unlikely that the tune or ESC has actually increased your mpg. I've also owned a few turbocharged cars over the past 35 years also and I can't imagine preferring a +30 whp WOT-only ESC shot over a +100 whp always-on turbo setup. |
#2162 | ||||
#2163 | |||
Drives: Passat
As for parasitic losses among FI applications, I think it's obvious that a turbo is the most efficient followed closely by ESC with engine driven superchargers being the least efficient. AFAIK the ECU uses fuel trim and miles driven to calculate MPG. My ECU read about 2-3 mpg high when stock and now reads 1-2 mpg low after mods and a tune. I always check my MPG at the pump and compare to the trip computer. Last edited by Fast_Freddy; 10-07-2013 at 05:09 PM. |
#2164 | |
#2165 | |
[Miles Driven] / [Gallons Consumed] = MPG At least that's the formula I use with a calculator. I'm not just old, I'm old school. Yeah, I keep repeating this, but I'll say it again. I'm not fighting the horsepower wars. I didn't even bother to dyno my car because I really just don't care who is making 223.4 and who is making 224.2...just doesn't matter to me. I was looking for a great way to fill the torque valley. A 50-60 ft/lb increase right at 4200 rpm means everything to me. I considered everything available and not available (like the Nameless headers), but felt that the ESC was the best option. Turns out, I was right.
#2166 |
The way the ESC makes power really reminds me of my turbo cars in the past. A very modest speed increase during DR engagement (negative boost or just into positive for turbo) and then a large increase in power once full throttle is engaged.
Sent from my HTC One using Tapatalk 4 |
#2167 | |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Agreed, on a daily basis the power from 3-5k rpm has been most used. That was the selling point when I got mine from Rob was that you really feel like you have much more than a 2.0L 4cyl under the hood. I got to feel the system in Fenton's car currently, the DR in his setup is really affective, Mine is no where near that engaging but if the final product has DR the way its setup in fenton's im stoked! |
#2168 | |||
Drives: Passat
![]() Quote:
#2169 | |
Thank you for posting your opinions on the kit.As it stands the kit I had before(TQ250) with 93 octane made +60hp(80tq) at 3500-4500rpm and about 40-45hp at 6750. The TQ300 kit that i have now is making about the same 60+hp down low but should now be in the 50-60 between 5500 and 7500 rpm. I believe Rob is working on getting dyno time setup for the TQ300 system to tune and baseline next week ![]() As for the "less hp and torque than all other competition"..... The fact that we are even close is AMAZING. This thing is cheap and install is a breeze. At redline, yes, most turbo and sc kits beat the ESC but damn we are kicking ass at the 1800rpm - 5000rpm range which is very impressive for such a minimal investment. No its not for everyone but whats happening here for BRZ and FRS owners is very exciting
#2170 | |
Drives: Passat
Speaking of average ESC gains, I do wish that you would quote peak or average hp/tq gains instead of always quoting the maximum gain ever seen. While you may have made +60 hp and +80 lbs at 4290rpm on one dyno run, your average and peak hp/tq gains are far less and more representative of what most people refer to when comparing dyno results. Not to split hairs but at 3750 rpm you gained +50 lbs tq, not 80 lbs as you claim. ![]() As for this ESC being close to other FI options, I certainly didn't say that. I said it costs less and is easier to install. ![]() When you say that this ESC is "kicking ass between 1800-5000rpm, what exactly did you mean? It sounded like you meant kicking other FI options asses but that would be a huge falsehood. Did you instead mean vs N/A? I would agree that this ESC makes enormous tq gains in that rpm range compared to N/A builds. Last edited by Fast_Freddy; 10-08-2013 at 01:42 AM. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
