Old 10-03-2014, 05:19 PM   #2087
Racecomp Engineering
Originally Posted by digital_assassin View Post
Thanks. I did soften both compression and rebound. They were previously set nearly at full firm by GC so I moved them right into the midrange on each setting. I can't do the rears because I can't see the adjuster. The instructions show doing it out of the car with the shock in a vice. Ain't gonna happen today. If I'm missing something about how to adjust the rears please tell.
Cool. Let me know how it feels with the changes you've made.
Gotcha on the rears...that's a bummer.
- Andy
Old 10-03-2014, 05:51 PM   #2088
Coaster
Coaster's Avatar
Drives: Civic
What are the advantages of swift spec r over swift sports for street driving? ( both w/koni yellows)
Thanks for all the great info in this topic.
Coaster is offline   Reply With Quote
Old 10-03-2014, 05:52 PM   #2089
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Originally Posted by Racecomp Engineering View Post
IMO an STX build is more fun since you aren't as restricted. You can dial in the handling quite a bit more to the way you like it. So if your focus is fun and your track days are more frequent than auto-x days I'd go with an STX type build.
RCE T0 are a great choice and work well for track and auto-x. If you know they're in the plans then I would start with them as that will be the most dramatic change. You may like them without changing bars at all.
One note, a hardcore, dedicated, nationals level STX car may not be ideal on the track. BUT a well set-up track car will still be pretty quick for auto-x.
- Andy
Great observation! Yet some of the oil and engine coolant issues that work for track are not permitted in an STX spec'd car. An oil cooler, radiator upgrade or vented hood places one into a prepared class.
I wish to run a reliable track fun machine without whacking high temps and play for fun in an occasional local autox. So maybe I can trade my STX letters to someone with a P something.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 10-03-2014, 07:10 PM   #2090
gramicci101
Off Topic
If you're not looking to be competitive in an autoX class, and the car is primarily a track machine, I'd build it for your needs at the track and just have fun in whatever autoX class you end up in.
Old 10-04-2014, 04:40 AM   #2091
Brzzee
Brzzee's Avatar
My thoughts exactly, Sir!
Old 10-04-2014, 11:39 AM   #2092
- andy
Old 10-07-2014, 10:47 PM   #2093
gonzo
Drives: frs
Did 8 laps of autocross this weekend and my Michelin PSS are chunking and look like shit. They only have 6k miles with 0 autox or track days. They're 225s mounted on the stock wheels and TRD springs (only suspension mod). Is the tire wear from a lack of negative camber on the front? Can that cause a tire to fall apart in chunks?
Will camber bolts give me enough negative camber or should I just spend the extra money for plates?
I also ended up with a flat after 8 runs There was no nail in the tire just a puncture hole.
gonzo is offline   Reply With Quote
Old 10-08-2014, 03:40 AM   #2094
P@ul
Apostle
P@ul's Avatar
Drives: Fast Microwave
Have you guys gotten your hands on a 2015 FRS or BRZ? I'm very curious to hear about the differences in shock tuning and spring rates. Thanks!
P@ul is offline   Reply With Quote
Old 10-08-2014, 08:49 AM   #2095
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
A buddy of mine used to run PSS on his VW GTI (a front wheel drive without adjustable camber, and minimal camber).
Granted, he autocrossed those tires and daily drove them for nearly 6 months or so, but after an autocross school, he had chunking also.
I'm wondering if the PSS just can't handle extended autocross runs in a day (you had 8, he had 20-ish, but they were chunked before that). Maybe they need some spray-cooling?
bimmer635csi is offline   Reply With Quote
Old 10-08-2014, 11:58 AM   #2096
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I bought a decent 2 gallon spray bottle at Lowe's for about 10 or 20 bucks. After 4 runs on a high speed (had to go into 3rd a couple times) autocross course with 90+ second times, I had no signs of chunking on my MPSSes with using the sprayer.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 10-08-2014, 01:04 PM   #2097
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
is he a fast driver or mid-pack?
most FWD autocrossers abuse their fronts like no tomorrow, using too much steering input and really putting lots of heat into their fronts by scrubbing speed before hammering down and glazing them with acceleration.
it's a very fine line, and easy to cross in a FWD car, esp a nose heavy one like a VW (I had one)
Old 10-08-2014, 01:59 PM   #2098
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So the B16 fits our cars, does the B16 ride control? I'd love a button to go from DD comfort to back road afficienado...
Old 10-08-2014, 02:42 PM   #2099
bimmer635csi
That's good info. I wonder how you would answer the question below though...
He is consistently FTD for GS and top 20 on PAX (out of 150ish). That's probably mid-pack on a National event though.
Old 10-08-2014, 06:00 PM   #2100
Gillams
Gillams's Avatar
Drives: 1987 toyota supra, 2013 scion FR-S
any thoughts on a dual caliper system for a hydraulic hand brake?
Gillams is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
