View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 08-27-2016, 03:09 PM   #197
Blood
Drives: 2018 STI
Anyone have any luck with their dealer flashing the TCM logic update to a 2013 or 2014 car? My local dealer said the only TCM update available is for 2015 cars and wouldn't advise flashing that to a non-2015. They didn't hook the computer up to my car and run an update check though so they may have just searched the TSBs... Not too sure if they are able to see all available ECU and TCM revisions without the VIN or being connected to the car.
I don't have any hard shifting or idle hunt issues, but I figured it couldn't hurt to have the updated logic.
Blood is offline   Reply With Quote
Old 08-27-2016, 03:10 PM   #198
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Originally Posted by Blood View Post
Anyone have any luck with their dealer flashing the TCM logic update to a 2013 or 2014 car? My local dealer said the only TCM update available is for 2015 cars and wouldn't advise flashing that to a non-2015. I don't have any hard shifting or idle hunt issues, but I figured it couldn't hurt to have the updated logic.
Try a different dealer
Sent from my A0001 using Tapatalk
KalbiCool88 is offline   Reply With Quote
Old 08-27-2016, 03:24 PM   #199
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
"If it ain't broke, don't fix it"
Or as above, try a different dealer
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
humfrz (08-27-2016)
Old 08-27-2016, 03:47 PM   #200
humfrz
Yep....the young-en has it right ......
humfrz
Old 08-29-2016, 02:27 PM   #201
Astral Abyss
Drives: 2016 Halo FR-S
It also applies to early 2016's, like mine.
Astral Abyss is offline   Reply With Quote
Old 08-29-2016, 04:35 PM   #202
Borrowed Time
Drives: 2015 Ultramarine FRS
I had this TSB done about a week and a half ago and the hard shifting appears to be gone. Didn't even notice whether I had the fluctuating idle issue but definitely had the hard shifting after going to "sport" mode after driving in normal mode for a while.
I told them that I had the fluctuating idle problem along with the hard shifting. Of course, they couldn't figure out how to reproduce the shifting issue but did they did the TSB reflash and it appears to take care of the problem. I consider this fixed for now unless I come back and edit my message. Thanks again to all on this site.
Borrowed Time is offline   Reply With Quote
Old 09-01-2016, 12:45 AM   #203
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Originally Posted by rjgough95 View Post
Would anyone know what the labor cost would be roughly? That's the route I want to take and just get it done with.
I think the TSB said it was 20 minutes of labor
V_86 is offline   Reply With Quote
Old 09-01-2016, 12:49 AM   #204
KalbiCool88
For a dealer to do a campaign or tsb, I don't think they can charge you...? Voluntary campaign or not.
Old 09-01-2016, 07:52 AM   #205
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Only thing is that mine is a 2013 not a 2015-2016.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 09-01-2016, 11:32 AM   #206
Blood
Drives: 2018 STI
I didn't have any luck at my local dealer, see post above. TLDR: Dealer said there is no TCM logic update for 2013 and 2014 cars.
Let me know if you're able to get it done.
Old 09-01-2016, 08:11 PM   #207
HondaCBR08RR
Drives: Frs
I got a 2013 AT my car has a sluggish/delay/won't down shift. Dealer said I got no tsb for my year also. Someone from a frs car meet told me to change my transmission fluid to motul300. Hope this work will update once i change the fluid
HondaCBR08RR is offline   Reply With Quote
Old 09-01-2016, 09:39 PM   #208
KalbiCool88
The symptoms are very specific, so I am not sure if changing the trans fluid will do much - not to say that it won't help it either.
I would just print out the TSB and try to get your car to re-produce the shifting issue before you bring it to the dealership. Kindly explain to the service advisor that although the TSB states a specific year, it is also occurring in your vehicle as well.
Old 09-01-2016, 09:57 PM   #209
Blood
Drives: 2018 STI
Motul Gear 300 is for the differential and manual transmissions. You need to use automatic transmission fluid (ATF) instead. I am changing mine to Amsoil ATF in the near future.
The Following User Says Thank You to Blood For This Useful Post:
soulreapersteve (09-01-2016)
Old 09-02-2016, 12:39 AM   #210
Reamer
Drives: 2015 FRS
Please don't involve the ATF with cars, they already restrict enough guns as it is.
I feel the shame of being OT.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 12:54 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 07:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 04:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
