Old 06-25-2016, 11:51 PM   #197
keen as
keen as's Avatar
Drives: 86 GT MT
Originally Posted by Sojhinn View Post
So basically even after recalibrating the throttle it never actually reads the last column
NO, that post describes an an UNcalibrated throttle. In the zero rpm row, I populated the 80 and 85 column cells with "100". That was the only change in the map and I attached the picture showing only these 2 changes. This enabled full signal voltage of 4.95V while the 80 column cell was active.
I will make a procede map up to 80 column. And make sure there is one more column to the right, that the active throttle won't reach and appears redundant, populated with "100", to enabled me to get full voltage signal from the 80 column.
After calibrating the throttle, the last column is reached/read by the active throttle. This is the problem. There is no "100" cell to the right, and I the previous results I posted showed this gave a lower voltage of 4.06V. However, if there was a "100" cell to the right of the active cell, then I would get full signal voltage of 4.95V.
keen as is offline   Reply With Quote
Old 06-26-2016, 12:20 AM   #198
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
That's just odd... Strictly from a programing sense either it's reading to the right of wherever the blue square is.... Or there's a major glitch in regards to what 100 is defined as. Try putting in 99 and see if that fixes the issue.
Installed Mods:
Old 06-26-2016, 03:10 AM   #199
KoolBRZ
KoolBRZ's Avatar
So, since the last row has no cells to the right, then it should drop when it gets to full throttle. Now everyone needs to recalibrate their throttles so the max ends up in the 90 load column, that way full throttle gives full boost. It's tricky, but do-able. I'll do it tomorrow.
I already have a great tune, I just bumped up my boost by moving all the columns in my map one column to the left. It was a fun trip to the store and back, though my average mpg took a hit.
There is still a slight voltage drop between the switch and the Procede, 5.21 versus 4.95, but that's close enough for me. @keen as, what is your cal id? I'll send you a copy of my tune for you to experiment with.
If I say yes, will that make you think I understand?
Old 06-26-2016, 03:28 AM   #200
keen as
keen as's Avatar
Drives: 86 GT MT
That all makes sense. @KoolBRZ
I don't expect any difference between 5.21v and 4.95V. After I get my dump pack back in, I'll log boost to see if there is any change when I switch from procede to throttle switch.
My Cal id is A01G, currently on E85 (it's really good when full boost working). I had help with a local guy to fix the lean AFR at low revs. He also helped with cold start. It's winter and in Sydney, Australia, 3degress Celcius low feels like an ice age!! So, don't go out of your way for E85 tune, thanks.
Old 06-26-2016, 03:31 AM   #201
KoolBRZ
KoolBRZ's Avatar
That's just odd... Strictly from a programming sense either it's reading to the right of wherever the blue square is.... Or there's a major glitch in regards to what 100 is defined as. Try putting in 99 and see if that fixes the issue.
It's averaging to the right. If there is no cell to the right, the average drops. Lots of automotive tables use averaging. The trick is to make the last two columns on the right the same, then calibrate your throttle, adjusting the full throttle calibration up until full throttle ends up in the 90% column. That's it. I'll get pics tomorrow showing a table with the last two columns the same. Also showing the throttle calibration upper limit raised so that full throttle ends up in the 90% column. For instance, my calibrated upper limit is 808 at full throttle. I would probably need to raise it to 925 to bring full throttle back to the 90% column.
P.S. @keen as, if you simply don't calibrate, it won't engage as soon because the lower throttle limit is too low.
Old 06-26-2016, 11:17 AM   #202
Sojhinn
Sojhinn's Avatar
Good to know. Thanks.
But why didn't Shiv just tell us this in the first place?
Also why is this springing up after the fact for some of us?
Installed Mods:
Old 06-26-2016, 11:28 AM   #203
KoolBRZ
KoolBRZ's Avatar
How many of us actually measure voltage at full throttle? The rest of us just took it on faith. Kudo's to @keen as for questioning it enough to test it.
Old 06-26-2016, 11:34 AM   #204
Sojhinn
Sojhinn's Avatar
Hah me. I had my procede replaced for the same reason.
But nice job you two on figuring it out.
Installed Mods:
Old 06-26-2016, 01:10 PM   #205
KoolBRZ
KoolBRZ's Avatar
Calibration walk through
Here is how to do it. Turn on your car without starting it. Plug the Procede cable into your laptop. Open Procede software, click on the red connect button to connect. Wait for current map to load. If you are going to continue using this map, proceed to next step, otherwise, click open to load the map you want to use. Wait for map to load. Click on the Analogue Inputs link on the left-hand column to open it. Click and drag it to the left, so you can see the readouts on the right, as shown in the pic. Calibrate the throttle by clicking on the "Set Throttle" button once, step on the throttle several times, take your foot off the throttle, click the "Set Throttle" button once again, step on the throttle several times, WHILE HOLDING THE PEDAL TO THE FLOOR, click the "Set Throttle" button once again, release the throttle.
Now add about 40,+-5, to the Max Throttle field and click on the "Apply" button. Notice the Engine Load In % field changes with the throttle. Make sure that you add enough so that the "Engine Load In %" is between 92 and 93% when the throttle is pushed to the floor. Over 95% is too much, it jumps to the 100% column, under 85% is too little, it drops to the 80% column. 92.5% allows for some variance in the throttle calibration, but ensures full throttle is in the 90% column.
Notice this Procede map is rescaled, and the last two columns are identical. Also the first two columns and the bottom two rows are the same to allow for Throttle calibration variance. It kicks in very early and strong.
Old 07-15-2017, 04:11 PM   #206
j_Zer0
Drives: Asphalt FRS 2014
No boost up top
I'm seeing an issue where I have no boost at throttle >= ~70%. @Sojhinn pointed me here, so I recalibrated my throttle as per @KoolBRZ's above instructions. My throttle is now 170 - 890 and with the pedal all the way down load is 92% and I'm in the 90 column on my map. But unfortunately I still have no boost up high (partial boost is working fine). Does my map look ok?
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 07-15-2017, 04:12 PM   #207
Sojhinn
Sojhinn's Avatar
I'm assuming the box is moving to the right and up correct?
Installed Mods:
Old 07-15-2017, 04:14 PM   #208
j_Zer0
Ya, it seems to be tracking both RPM and throttle input accurately.
Old 07-15-2017, 04:16 PM   #209
Sojhinn
Sojhinn's Avatar
Next step sucks... You need to measure voltage leaving the procede while the car is on and someone is pushing down on the throttle. You should be reading approximately 5v on full throttle.
Installed Mods:
Old 07-15-2017, 04:18 PM   #210
j_Zer0
Does the engine need to be started, or is accessory mode enough? I have a multimeter, but how/where do I put the leads?
What does your user name mean? Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 355 05-01-2016 08:52 AM
OFT: New firmware and new user software Shiv@Openflash Software Tuning 9 10-15-2014 02:45 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
user tags scottmcphee Site Announcements / Questions / Issues 3 04-11-2013 03:15 PM
User name trueno86power Site Announcements / Questions / Issues 7 11-28-2012 12:48 AM
