#197 |
Drives: Toyota 86 GTS
Tables were renamed to be consistent with the few US MT defs that had those tables.
#198 | |
Fast enough
Drives: 2013 Subaru BRZ AT
I was comparing AT to AT. Before and After. (The logs you posted). I'm questing where the power difference comes in. I'm sure some is from the different front pipe, but some must be from the leaner AFR's as well. My other question is why is timing reduced/flat from 7000 RPM to redline? As RPM increases you generally need slightly more timing. I would think you should gain at least a full degree from 7k to 7.5k. I plan on making this change with my car. Now I WILL keep the soft rev limit, so from 7500-7600 I'll rapidly decrease timing. |
#199 | |
Drives: FR-S 10 #103 AT
I'm finding Engine load limit (maximum) Engine load limit B maximum (rpm) Engine load limit C maximum (rpm) Are two of these the ones I'm looking for? Running a comparison shows a lot more tables as different than what you listed. Are those additional tables just the difference between U.S. and European?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#200 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Yes I think so. When I ran a comparison in RomRaider, there were many items listed as different, when it turned out to be individual CELs either ON/OFF
#201 |
The best things to do is compare the two roms with the TARGET in the first field and the SOURCE in the second field. If a table is red AND it appears in the list or the spreadsheets on the first page then copy it.
If it's red but not in the list its region/cal specific and shouldn't be modified. There are specific reasons for all the table changes, if you learn what each one is then which tables to copy will make more sense. |
#202 |
( ͡° ͜ʖ ͡°)
After 2 days of driving to and from work, some observations:
- Didn't update TEMPLATE file on OFT, my log got all effed up - The first millimeters of throttle appear "lighter" than before, which I actually like to modulate easier - The RPM climb and throttle response is much smoother in daily driving. I was actually surprised! - WOT runs feel the same, except much smoother. - VVT rasp at 4k RPMs isn't as pronounced - Cold starts now less obnoxious - I have not experienced the "rubber band" upshift - Idling doesn't sound as rough This is copying all v79 tables over, running Canada 94 Octane |
| The Following User Says Thank You to drewbot For This Useful Post: | Wayno (07-24-2015) |
#203 | |
#204 | |
( ͡° ͜ʖ ͡°)
Anyhow, my IAM on 94 is 1.00 24/7....was with 91 OTS and "Wayno" 91 v79 KC learned is around 2-3 during moderate throttle. To monitor FLKC I need to actually get this stupid OFT to log to look at exact RPM ranges |
#205 |
You won't knock on 94. I hope you're using the 93 base timing.
#206 |
( ͡° ͜ʖ ͡°)
#207 |
Drives: '15 Halo FR-S
#208 |
( ͡° ͜ʖ ͡°)
#209 |
#210 | ||
Fast enough
You said not to adjust timing without a dyno. Did you dyno to verify this increase in timing resulted in a corresponding increase in torque. I'm not sure why you would've said you did not increase timing at WOT when you did (from what I can see on the UEL E85 tune) Thanks |
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 10:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 11:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 01:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 06:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 05:26 PM |
