Old 08-05-2015, 01:52 PM   #197
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by Hyper4mance2k View Post
T-minus 6 months until PLM knock off...
Support artists and masters of the art and ye shall receive art and appreciation.
CounterSpace Garage is offline   Reply With Quote
Old 08-05-2015, 02:15 PM   #198
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Originally Posted by CounterSpace Garage View Post
Better than 91 octane but not as good as E85.
Sorry no e85 close by the closest is 1 hour away but will see what happens
Carlysh is offline   Reply With Quote
Old 08-05-2015, 02:34 PM   #199
CounterSpace Garage
We have data to show that 100 octane on a completely stock factory OEM BRZ/FRS yielded 6hp better than 91 octane doing back to back baselines. Please contact us if you have any other questions regarding the ACE headers.
Old 08-05-2015, 03:05 PM   #200
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
You mean no tune ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-05-2015, 03:23 PM   #201
Originally Posted by MaximeT View Post
You mean no tune ?
No further tuning.
Old 08-05-2015, 03:24 PM   #202
Captain obvious
Old 08-06-2015, 04:26 AM   #203
Superstar
Drives: Honda
Originally Posted by AceHeader-MT View Post
350= max torque (202.4NM), lowest peak HP (175.1HP)
250= torque (approx 200NM), HP (approx 178)
150= lowest torque (approx 195NM), HP (approx 182)
These numbers are approximated off percentages of the 350 when we did a stock dyno run with OEM frontpipe
The numbers are for N/A. What about for supercharged applications?
Superstar is offline   Reply With Quote
Old 08-06-2015, 05:32 AM   #204
steve99
Yes you will get around that gain with a completly stock car switching from 91 or other low octane fuels to a fuel with at least the octane rating the stock tune was designed for.
Reason is the stock tune needs at least 93 or equlivant octane to run full timing and have the IAM at 1. On lower octane fuels the ecu detects knock and reduces timing to limit knock resulting in an IAM arround 0.6 on 91 fuel in untujed cars
below is a log of a south africain stock 86 on their rubbish 95 ron fuel which is worse than usa 91.
IAM is 0.2 and its still pulling 3 degrees timing when you get on throttle total timing reduction probably 5 or 6 degrees,
Put good fuel in your car even stock and it will perform better
http://datazap.me/u/steve99/south-af...ata=2-20-27-28
Old 09-03-2015, 07:02 PM   #205
lmabee
Drives: FRS 1.0
ACE Header (CSG) Counter Space Garage
Received 2nd ACE 4:2:1 header....1st arrived after initial offering with tight 02 sensor fitting clearance....David at CSG (Counter Space Garage) was able to get 2nd header sent out....told that subequent headers will not have this problem....DIY only trick is lifting engine to get overpipe clearance....the fitting are all spot on
Really a piece of art....welds are unbelieveable.
No dyno data.
again shout out to David at CSG (ACE Headers)
Really pleased with service from David CSG
somehow unable to loade images will forward to see if can be inserted
Lee Mabee
lmabee is offline   Reply With Quote
Old 09-03-2015, 08:13 PM   #206
sw20kosh
Drives: 2013 Black FR-S
Dynapack Dyno:
(no stock baseline stock 86 on this dyno yet, but the tuners tuned JDL UEL made 164 whp)
ACE 169 whp 91
ACE 187 whp E85
Virtual Dyno:
155-160 whp bone stock right before dyno tuning
217-223 whp after tuning session.
Old 09-03-2015, 09:49 PM   #207
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by sw20kosh View Post
Dynapack Dyno:
169 whp 91
187 whp E85
Virtual Dyno:
Dayum! That's some high quality Taiwanese made shit, right there!
What are all the mods you did aside from the headers to get to 220WHP?
Intent > Content
Old 09-03-2015, 09:53 PM   #208
CSG David
CSG David's Avatar
No dyno data.
Lee Mabee
Good luck at the Nats. Go get 'em!!
Old 09-03-2015, 09:57 PM   #209
Flex Fuel, Ecutek Tune, Ace front pipe.
Zero other drivetrain mods.
Old 09-03-2015, 11:10 PM   #210
Traktor
Drives: Subaru BRZ Limited
Ace 4-2-1 Header
I wonder if the unique ACE header design would lend itself to making more power above 7000 rpm with some aggressive cams. All the combinations of tunes and bolt ons seem to max out at around 200 whp at 7000 rpm or thereabouts. Even the new piper cams in another thread increased power, but it still came in at 7000rpm with a traditional EL header design. 100 whp/liter @ 7000 rpm peak is very efficient, just need to move that powerband!
You just feel that there is a NA secret waiting to be unlocked with these cars!
Traktor is offline   Reply With Quote
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
