Old 07-22-2014, 03:47 PM   #197
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by WNDSRFR View Post
I just finished my first 10 gallons of E? and thought I would share my impressions/opinions.
First off let me say the conditions were less than ideal for any kind of FI testing, WAY less than ideal. The air temp was about 95 degrees with about 90% humidity with low atmospheric pressure.
My initial impression was that the E-85 tune has less power than the 93 tune. I know that it doesn't but it FEELS less powerful. I think it may be because the E85 tune is sooo smooooth. I actually ran into the rev limiter a few times not realizing my RPM was so high.
And the flat foot shifting really is cool. But you better watch your speed. You get past "go to jail" speed before you know it.
As for MPG/economy goes, my long term MPG with 93 octane is 29.1 MPG according to the MPG meter. On E? my average MPG was 32.4 MPG according to MPG meter. Of course that is impossible. So according to my odometer I got 27 MPG. That's believable.
So, The current price for 93 is $3.69 per gallon. And that's the cheapest it's been in a long time. It's usually closer to $4.00.
The E85 cost $3.11 per gallon.
So according to my calculations it cost .1268 per mile for 93 octane and E85 is .1152 per mile.
Enough reason alone to run alcohol.
But now I am running e>85. I got an alcohol hydrometer to check the purity of my E85 but it says it's about 120% alcohol. So it doesn't work. I'm assuming then that my current fuel tank contains a least E85 after the first tank purging. My first impression now is that yes it has more power.
At less cost.
More to come...
THANKS SHIV YOU ARE THE MAN.
I'm jealous! I had to fill with another third of a tank since I'm an AT waiting for those maps to hit. e85 is around $3.30 in my area, but I don't remember getting mileage that good when I was on e85 before. I feel like it was closer to break even when I was running it due to my higher costs.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-22-2014, 04:33 PM   #198
raven1231
At less cost.
More to come...
I had this same experience and was wondering the same thing? I wonder if it is because it's smoother.
Old 07-22-2014, 04:49 PM   #199
DAEMANO
Time Traveller
@WNDSRFR & @raven1231
I can't help but think that the lack of power you're describing could perhaps be the atmospheric conditions you're speaking of. Both @WRB5titch and I have felt the car pulling noticeably harder everywhere (both on/off boost through the whole rev range). True, the tune also feels smoother, but in no way does the car feel slower. For comparison, in SoCal, it's been about 80F with 50% humidity since Saturday.
Old 07-22-2014, 04:53 PM   #200
enwave
enwave's Avatar
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta]
Also @WNDSRFR and @raven1231 what do your trims and IAM look like? I know with the first E85 tune I ran it took some time before it felt like I was getting most out of my corn. It was like I woke up one morning and was all "ohhhh THIS is how it is with E85." But it wasn't the same day that I flashed.
I wouldn't doubt ambient conditions might be part of the problem too.
The Following User Says Thank You to enwave For This Useful Post:
DAEMANO (07-22-2014)
Old 07-22-2014, 04:58 PM   #201
raven1231
I'll have to pull another log and see. I'll do that today or tomorrow.
It's currently 91F 42% humidity for me. It was cooler the days prior but humidity had been in the 70's those days as well. That being said I do think weather conditions are at least in part at fault.
Old 07-22-2014, 05:11 PM   #202
WRB5titch
Drives: WRBrz
Here's my log from this morning's run to work. Keep in mind I didn't wait till I was below the E...being the eager beaver that I am...I ended up filling up about 10gallons of e85, the rest was a blend of 91 and lots of Torco, so prolly 93-95ish octane.
Like @DAEMANO said, the transition b/w on&off boost is really smooth since e85 closes that gap in power when not in boost, but that doesn't mean it feels slower to me...
Quite the opposite imo! Granted it doesn't feel as strong during than the day than it does at night, but it's a definite kick in the pants across the board.
Couldn't be happier with the car as it is, both @Robftss and @Shiv@Openflash have done GREAT work.
http://datazap.me/u/wrb5titch/phanto...zoom=5490-5591
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following 2 Users Say Thank You to WRB5titch For This Useful Post:
DAEMANO (07-22-2014), Sojhinn (07-23-2014)
Old 07-22-2014, 07:21 PM   #203
raven1231
Any body else think my LFT look way out of wack???
Old 07-22-2014, 08:19 PM   #204
fenton
You didnt post a log?
fenton is offline   Reply With Quote
Old 07-22-2014, 08:20 PM   #205
raven1231
http://www.datazap.me/u/raven1231/e8...ta=1-8-9-10-12
Lol thanks didn't even catch that.
Old 07-22-2014, 08:33 PM   #206
fenton
Anything +-5 is okay to my knowledge. AFR's looks good and thats what really matters.
If there was a problem you would be way out like +-15/
The Following User Says Thank You to fenton For This Useful Post:
raven1231 (07-22-2014)
Old 07-22-2014, 11:58 PM   #207
enwave
enwave's Avatar
Those look like pretty dang solid logs to me.
Old 07-23-2014, 12:04 AM   #208
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
The corn has landed. Repeat the corn has landed.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
enwave (07-23-2014), raven1231 (07-23-2014)
Old 07-23-2014, 08:41 AM   #209
WNDSRFR
Drives: FR-S,GTI
OK
I can feel it now. It is unmistakable.
I have definitely become an alcoholic.
I think what happened is either related to atmospheric conditions or the fact that the first tank of E? had too much gas left in it. Or a combination of the two.
But I am definitely a convert now.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
DAEMANO (07-23-2014), raven1231 (07-23-2014)
Old 07-23-2014, 08:50 AM   #210
raven1231
OK
I was a little above e when I filled up too so maybe that's it.as well lol
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
