Old 07-17-2014, 09:50 PM   #197
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
Originally Posted by extrashaky View Post
That's the wrong thread. You want this one:
Engine idle chirping (cricket) noise poll.
Be sure to read all of it.
I appreciate your optimism, but the "new" pump does not improve the crickets. My 2014 has the "new" pump. I have crickets. Most of us do. They are just as loud as the old crickets.
Chevron and 76 do not necessarily get rid of crickets. I have found that Chevron in my area is usually quieter than Shell, but it's not consistent from station to station. The only thing that is consistent is that if I fill up at Sam's Club (Murphy Oil), the crickets will scream like nothing you've ever heard.
I found an ethanol-free station. Ethanol-free gas did not exterminate the crickets. Some people have had good luck with it, but my car is living proof that it's not a reliable solution.
Enjoy your crickets when they come, which they inevitably will. Just relax and imagine yourself out on the porch at dusk with an adult beverage.
LOL ok...I have plenty adult beverages at the ready for when it happens. I believe I am almost at 300 miles now so I'll listen for em.
InspGadgt is offline   Reply With Quote
Old 07-23-2014, 07:14 PM   #198
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Don't recall this being covered in this thread but for those with 10series/monograms/rs, this worked for my monogram.
http://www.ft86club.com/forums/showp...98&postcount=1
Changes setting so that when you walk near the car, both doors are unlocked instead of just driver.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 10-12-2014, 03:40 PM   #199
quality_sound
Drives: '15 BRZ Series.Blue
Originally Posted by ericmpena View Post
I don't think this was mentioned, but in the same menu where you set up the Gear Indicator, there is also an option that says S-On/Off.
S-On = Tachometer needle will shoot up and back down when car is started.
S-Off = Tachometer needle will not move when car is started.
Also, if you're in a BRZ Limited then you will need to set the alarm manually if the dealership did not do it for you:
1) Get in the car
2) press the start/stop button two times, with makes the car to be in the start position (all your dash lights light up)
3) Lock the car with the physical button on the door
4) Press the unlock button on the door and open the door while still pressing the unlock door button.
5) Still pressing the unlock button, wait about 10 seconds, the car will beep once for activated and twice for deactivated and the information panel in the cluster will say either "AL on" or "AL off"
I just tried this on my Series.Blue and nada. It's a '15 if that matters. I waited probably 30 seconds and it still didn't work. I wonder if it's because I pulled the HU.
quality_sound is offline   Reply With Quote
Old 10-12-2014, 03:53 PM   #200
quality_sound
Originally Posted by azian_advanced View Post
-The base & premium stereos (not sure about the 2014MY stereosl) are capable of wiring steering wheel controls (Mode, Vol Up, and Vol Down). The owner's manual says so and the dealer troubleshooting guide shows which pins in the harnesses do what. I can send the document to whoever is willing to take up this task.
If there was a steering wheel available with switches I'd do this in a heartbeat.
Old 10-13-2014, 12:03 AM   #201
BlackMonarch
Drives: Red BRZ
Originally Posted by Sailors14FR-S View Post
the whole fuel economy shift indicator thing... best feature ever... I love when I see that little ^... I get a good laugh every time i gun right past it!!!
Holy shit, that's what that is? It engages almost immediately after I shift in to a gear and apply the fun pedal. I figured it was just letting me know I upshifted...
TIL
BlackMonarch is offline   Reply With Quote
Old 10-13-2014, 12:14 AM   #202
TIL
Just for jokes try shifting when it tells you. I did once and it was hilarious. I am sure you get great mileage but sooooo boring.
Old 10-13-2014, 12:20 AM   #203
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
I thought it was a recommended point to shift so I did. Now for 1 less gallon per mile, I get to apply fun pedal a lot more
904FRSlow is offline   Reply With Quote
Old 10-13-2014, 01:33 AM   #204
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
On the BRZ there's a rubber button right between the tag lights, directly under the emblem. Here's a picture of it on my dirty car:
Unless the FR-S trunk is different, I think the "handle" he's talking about is the recessed area for the tag lights. Just press the rubber doofus and the trunk will pop without you ever having to touch your key fob.
On the other hand, I prefer to use my key fob, because the less I have to touch my dirty road-grimed trunk lid, the better.
Feel for the correct spot, and up she comes
GhostRai is offline   Reply With Quote
Old 10-13-2014, 08:22 AM   #205
Reign
Armchair Philosopher 9000
Reign's Avatar
Drives: Release Series 1.0 6MT #114
I also tried to turn on the alarm with this method on my FR-S RS 1.0 and was not able to get it working either. Through sheer happenstance, what I found out to work for me was:
1. While holding down the driver side unlock button, open the door by pulling the handle.
2. Continue to both hold down the unlock button AND continue pulling the door handle all the way for 10 seconds after the door has been opened.
3. Hear horn sound once and and the dash will say "AL on"
I should warn you that if you want to turn your alarm on and off multiple times in one sitting, that it may not always register and to keep trying.
Reign is offline   Reply With Quote
Old 10-14-2014, 08:14 AM   #206
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
For the people who didn't realise the screwdriver was reversible.
Go put it back where you found it, you probably shouldn't be using tools...
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 10-14-2014, 01:39 PM   #207
MrAnthonyC
Antagonist
MrAnthonyC's Avatar
Drives: 2014 Scion Fr-S (Firestorm)(stock)
If you put a cute girl in the front seat, and her cockblocking friends in the back seats, the back seat discomfort delivery system will activate and cause them to abandon their friend.
Check, and mate.
MrAnthonyC is offline   Reply With Quote
Old 10-16-2014, 12:36 PM   #208
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
The ignition key, OMG guys it works both ways. I'm not emberassed to say this is the first time I considered this function. Yes sir, not embarrassed at all.
Originally Posted by paulca View Post
Has anyone mentioned Hitler yet?
Hot Lava is offline   Reply With Quote
Old 10-16-2014, 01:57 PM   #209
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I turned this feature on about 2 days ago and have been shifting when the indicator flashes almost every time. My avg fuel economy has dropped by .1
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-16-2014, 01:59 PM   #210
I didn't do it long enough to see any impact on fuel.
Felt to much like I was playing a really sad version of Guitar Hero trying to hit shifts at the brief arrow that flashed up!
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
