Old 08-10-2020, 01:29 AM   #197
tomm.brz
Drives: brz 2017 hksv2
me too but then i also brought that ground directly to the - pin in the rear o2 plug, and then it fixed
Old 08-10-2020, 04:25 AM   #198
airrick
Drives: TRD R.S. 1.0 FRS
i feel like im not understanding what you did. you wired the brown wire to the negative pin on the rear 02 plug? Would i even be able to do this when my rear 02 plug is being used by my flex fuel kit?
you got any pictures?
since you have the same WB gauge, what range does the ecutek numbers actually "show". Mine is 11.40-17.06 so yea something is off for me.
airrick is offline   Reply With Quote
Old 08-10-2020, 07:17 PM   #199
airrick
new problem. EBSC doesnt work now.
I might have to give up on this endeavor. I have a turbo on my setup and since splicing into the evap (CPC) input, it had disabled my EBCS. I can't go higher than wastegate pressure now.
anyone else had this problem and fixed this? i might just undo everything since its messing with my boost controller.
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
