Old 11-06-2013, 08:17 PM   #197
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Agreed.. Flashed 1.33 and felt the typical squishy pedal and awful shift timing.. All will pass after 50 miles
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 11-06-2013, 08:17 PM   #198
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Boofneenee View Post
So,.. I flashed the latest beta and drove to and from work. Thus far I can say that I am really not happy and would prefer to flash back to the prior beta. The prior beta pulled like a train, was snappy and the tq dip disappeared sooner as I rev'd the car.
It is a strong possibility that perhaps my car has not had time to read the ecu but I drove about 20 miles total.. to and from work. I tried to open her up a few times just so the car could experience it and learn.
I dont know what is going on between 1k to 2k but it is not a smooth rev and almost bucks slightly.
If the newest beta tune 1.33 is safer than the prior then I will accept that.. did they reduce the timing or something? if its not safer at all and the prior beta is just as safe then I may flash back.
thoughts? ill give it another commute to work.
You can so a file comparison between the two map versions. I think you will see nothing that explains what you are feeling as the mapping is not very different. Perhaps you just need to let your car adapt after the flash?
Old 11-06-2013, 08:26 PM   #199
Norkoastal
Norkoastal's Avatar
Originally Posted by toysub View Post
New to the OFT. Is it better to run v1.31 or v1.33beta for the first go-around (no-headers installed).
Considering Shiv has the car, I would say the latest and greatest will usually have most the intended changes wanted to be made. I can't feel a huge difference between the two files yet, however that doesn't mean the file itself isn't better mapped/tuned for future improvements.
We are lucky that we get new candy each week while everything gets sorted out and perfected. Imagine the grins on our faces when E85 and the electric supercharger are tuned together with OFT..
CO>CA Cartel
The Following User Says Thank You to Norkoastal For This Useful Post:
toysub (11-06-2013)
Old 11-06-2013, 08:51 PM   #200
Shiv@Openflash
Drives: 2013 FRS
After a flash, you NEED to let the car idle for a 45-60 seconds. If you drive away immediately, VVT will be disabled and the engine will feel laggy and unresponsive. Exactly how garful described. It will eventually wake up after some driving but during that time it will suck. It's pretty obvious when this happens. Best to just let it idle for a bit after for flash. Do not press the throttle at all during this process.
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
autobrz (12-03-2013), garfull (11-06-2013), Garrett@Openflash (11-07-2013), jamesm (11-06-2013), NorCal_Guy (11-07-2013), normancw (11-06-2013), sonnydelight (11-07-2013), Trac Toy (11-06-2013), troek (11-06-2013)
Old 11-07-2013, 01:16 AM   #201
BRZ Fanboi
Drives: WRB Limited BRZ
Talking
I take everything I said back. I am loving 1.33b! My car has woken up. I am not sure why there is such a drastic increase in performance between 1.31b and 1.33b but i am not complaining lol. I think more has changed from A00C to A01C than we realize...
BRZ Fanboi is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ Fanboi For This Useful Post:
Garrett@Openflash (11-07-2013), Shiv@Openflash (11-07-2013)
Old 11-07-2013, 02:46 AM   #202
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by jeebus View Post
I do have a question about the Knock Detection RPM range table. Should this go up to 7650 since our redline has been raised?
Knock sensors are notoriously inefficient at high RPM, so there's not much point.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
jeebus (11-07-2013)
Old 11-07-2013, 02:47 AM   #203
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why don't you get rid of the dead pedal before you drive it away!?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-07-2013, 10:23 AM   #204
jeebus
Drives: 2015 Mustang GT (on order)
What map does your car take? A00, A01, etc?
jeebus is offline   Reply With Quote
Old 11-07-2013, 10:37 AM   #205
Norkoastal
Norkoastal's Avatar
What is the exact procedure for this? Ive tried a couple key on, gas mash, key off routines that were posted without success..
CO>CA Cartel
Old 11-07-2013, 11:00 AM   #206
cnk
Drives: '13 DGM BRZ Limited
Turn on car, don't start engine. Depress and release gas pedal 10-20 times. Turn off car. Start car as usual.
cnk is offline   Reply With Quote
Old 11-07-2013, 11:30 AM   #207
Kodename47
Kodename47's Avatar
Drives: UK GT86
^^^ This. My original magic figure I was given was, for some reason, 7. I always do 10. Must be depressed and released fully. That's why it takes a while when you drive, think about how often you fully take your foot off the pedal AND floor it in any one given drive cycle
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-07-2013, 12:21 PM   #208
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
How does pressing and releasing the gas pedal when the car is off help the ecu to learn? I was under the impression the car uses an analysis of exhaust fumes to determine calibration. What am i overlooking?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-07-2013, 12:29 PM   #209
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
When the key is ON, the ecu is ON.
SloS14 is offline   Reply With Quote
Old 11-07-2013, 12:51 PM   #210
Norkoastal
Norkoastal's Avatar
What is the time sequence of all these steps? I know some cars have time requirements with throttle relearn procedures.. The steps above didnt work for me this go around when I flashed (my throttle already corrected so this would be good to test for the next flash)..
CO>CA Cartel
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
