07-03-2014, 10:51 AM | #197 |
Wondered the same thing as to using the GL-5. Redline has a 75/90 that is a GL-4...........GL-5 is supposedly not friendly to brass blocking rings.
The Shockproof seems to not have any GL ratings that I could find on their site in the tech. info. section. Does the bottle have anything on it? |
07-03-2014, 02:58 PM | #198 | |
Drives: 2010 WRX (sold) 2013 brz
MT90 gl-4 with 1 quart of Lightweight Shock Proof . Sorry guys made a mistake on the other post. It is the gl-4 |
07-03-2014, 03:01 PM | #199 | |
Made a mistake on the other post. This cocktail was suggested for me to try by many subaru enthusiast since it is popular on the 5 speeds to fix synchro issues. In my case it fixed the similar problem that many people have with the wrx. |
07-03-2014, 03:01 PM | #200 |
07-03-2014, 03:02 PM | #201 | |
MT90 gl-4 with 1 quart of Lightweight Shock Proof . |
The Following User Says Thank You to Rocket.BRZ For This Useful Post: | xxBrun0xx (07-03-2014) |
07-03-2014, 08:29 PM | #202 |
07-04-2014, 03:17 AM | #203 | |
Drives: 2014 FR-S 6MT Monogram Series
07-08-2014, 07:03 PM | #204 | |
Drives: GT86
I'm considering to try this. |
07-11-2014, 12:11 AM | #205 | |
That One Guy
Drives: White 2017 BRZ
So my question is this: Should i go with motul or redline since i live in phoenix? The reason i bring in phx into the picture is because it is so effing hot here (maxed out around 110-120 Fahrenheit (43-49 C)). Which viscosity or brand is better for hotter weather? Also, if i change the tranny and differential fluid, will i need to buy these washers? Anything else (specific) i will need to change the tranny and differential? This will be my first time changing these fluids on a car. Last edited by Daedex; 07-12-2014 at 12:54 PM. |
01-09-2015, 05:22 AM | #206 |
Drives: 2013 frs
Sorry to bump up a old thread but I looked in the manual and for the manual transmission oil and diff it says only to inspect every 7.5 miles ..anyone have a replacement milage ?
Thanks in advance |
01-09-2015, 07:00 PM | #207 |
Turning is for Nerds
Drives: 35 characters is not enough
"lifetime fluid" I believe, which usually means it is a good idea to change out right after the warranty period ends on a street driven car.
01-09-2015, 07:01 PM | #208 | |
Drives: fast
Mini Coopers Misrepresent 'Lifetime' Transmission Fluid, Lawsuit Claims http://abcnews.go.com/Business/mini-...ry?id=20579484 |
01-09-2015, 07:12 PM | #209 | |
I totally agree though that one should change both as a maintenance item. |
01-09-2015, 09:32 PM | #210 |
Drives: 2013 frs
Similar Threads | ||||
DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
What transmission fluid are you using? | Chillz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 04-06-2013 10:45 PM |
Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
