Old 06-29-2015, 02:09 PM   #197
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Originally Posted by teamturbo View Post
Where did you buy this? @sprintertrueno86
Ordered mine from autoanything -
http://www.autoanything.com/dash-mat...ashboard-cover
Took about 3 weeks since they're made to order.
You can order directly from Dashmat but it's more expensive. -
http://www.dashmat.com/products/suedemat.html
sprintertrueno86 is offline   Reply With Quote
Old 06-29-2015, 04:16 PM   #198
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Thank you! Mine is starting to come up a bit also, and just bought it in the beginning of the month!
The Twins make me smile
Old 06-29-2015, 05:07 PM   #199
teamturbo
teamturbo's Avatar
I see that it covers the speakers...what are your thoughts?
teamturbo is offline   Reply With Quote
Old 06-29-2015, 06:21 PM   #200
sprintertrueno86
Drives: 2018 BMW M2
No difference in sound IMO. The material is actually really thin and weighs like nothing.
Old 06-30-2015, 04:11 AM   #201
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
My new dash is doing it again. Just slightly, but its doing it.
Gotta take it in for a new HPFP, radio won't synch with phone, tail light condensation, rattles everywhere. Not really excited.
Coheed is offline   Reply With Quote
Old 07-02-2015, 08:52 AM   #202
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
dash mats and sunshades for your windscreen are a must. especially if you live in hot places like i do ('straya).
wtrxprs007 is offline   Reply With Quote
Old 07-19-2015, 04:53 AM   #203
Futaba
Futaba's Avatar
Drives: GT86
I had this issue with mine, I was able to fix it without glue or replacing the dashboard.
When I removed the air vent I noticed that the material and white foam were still stuck down just fine, but the thin plastic they are glued to had deformed a little from the heat of the sun.
What I did was remove the air vent, and duct tape the left and right sides (pulling the plastic down about 1cm each side), this made the center section with the tab for the vent go up a little, I left it like this in the sun all afternoon until it had cooled off in the evening, and removed the tape, reinstalled my vent and it retained its original shape (no more bulging on left and right and dipping for the tab in the middle).
I believe the problem to be the cold A/C air on one side of the plastic and the piping hot sun beaming down on the other, causing warping of the thin upper plastic, so what I did was take a oven proof cloth and placed it between the top of the vent insert and the upper plastic so that the temperature never gets to alternating extremes on the same material
Haven't had the problem since.
Also, to echo what everyone else is saying, get yourselves a good mirrored sun screen, not only will it reduce the risk of long term dash damage but you'll be less likely to need to put the AC on full blast the second you get in the car.
Futaba is offline   Reply With Quote
Old 07-29-2015, 02:57 AM   #204
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
How did you guys get dealer to fix? Mine just stared and said, "uhhh yuh uhhh its fine...we dun see eet.... uhhh yuh its fine, sir."
It's like a M shape.
Packofcrows is offline   Reply With Quote
Old 08-11-2015, 02:37 AM   #205
Futaba
Futaba's Avatar
Drives: GT86
I'm currently working on a glue-on solution for this that should fix it properly, wether your bulge is due to the plastic deforming or the foams adhesion failing.
Will update soon, attempting the solution on a friends BRZ later today.
Old 08-11-2015, 07:42 PM   #206
frs1986
frs1986's Avatar
Drives: red
I got an dash problem too.
Sent from my SM-N900W8 using Tapatalk
frs1986 is offline   Reply With Quote
Old 10-03-2015, 12:58 PM   #207
CJB
Drives: 2013 BRZ Premium MT
I've been using the Subaru sold sunshade (so it fits the window perfectly) since day 1, and my dash still warped above the center air vents. I'm a month away from being out of warranty and the dash is being replaced next week. I plan on selling the car within the next 6-months, partly because I don't have faith the replacement dash won't eventually do the same.
For anyone curious, supposedly approval is as simple as the dealer emailing pictures of the problem to Subaru of America and requesting approval for a replacement. Obviously this probably varies country to country, but at least in the US that's all it takes.
CJB is offline   Reply With Quote
Old 10-03-2015, 05:10 PM   #208
Pickleahoy
Drives: 10 Series #1617
Brought it up to the local dealer (nasty shaped M center of dash) to which the tech replied "oh that?, I checked it out and all the frs' on our lot have that". I asked the tech to walk me over to the "other" FRS'... the dealer had 0. Imagine his face of "oh fuck" when the salespeople said there were none after we walked quite a while trying to find one. Anyway, after showing him pictures on Google from cars that had a straight dash he said "alright, we will get you a new dash" and that was that.
Pickleahoy is offline   Reply With Quote
Old 10-04-2015, 03:01 AM   #209
wtrxprs007
wtrxprs007's Avatar
least you're getting a new one that easily. some dealers here in australia will just give you the "oh i've never seen or heard that" bs.
Old 10-04-2015, 02:13 PM   #210
frs1986
frs1986's Avatar
Drives: red
Im having the dash problem. Also im having a paint issue. Is all over the car. The more you wax the car the more evident see the paint issue.
86 rubber floormats denverizzles Scion FR-S / Toyota 86 GT86 General Forum 30 05-06-2013 05:10 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 10:09 AM
Anyone else smell rubber? pinoyplaya BRZ First-Gen (2012+) — General Topics 15 09-24-2012 03:40 AM
Both: EZ DIY Rubber Trunk Mat (FR-S Only) Calidrifter DIY (Do-It-Yourself) Guides 15 08-29-2012 12:59 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
