Old 04-02-2013, 05:17 PM   #197
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by jamesm View Post
no boost controller at all? not even a manual? with no gauge! that's nuts.
Not necessary to have a controller if you want to just run at the wastegate spring which is what the base tune supports. Not having a controller actually minimizes complexity.
That being said, I would always want a way to dial in boost. Personal preference.
Old 04-02-2013, 05:19 PM   #198
2forme
Originally Posted by Foobar View Post
2K!? I know cheapskates and you sir are no cheapskate!
Sent from my Nexus 4 using Tapatalk 2
I was speaking within the context of a built motor swap. LOL. I haven't even bought a header yet because I'm not sure they are worth the money yet...
If it were me, I'd have fought with the dealer until a new motor was put in and then limped to someone who knows how to install a damn kit. Or have Tut come down and get a bit dirty myself.
Old 04-02-2013, 07:42 PM   #199
jamesm
not having a controller would suggest that no one had to take the time to actually set the boost. i.e. it was probably never even checked, let alone monitored.
Old 04-02-2013, 07:51 PM   #200
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
a controller wont let you lower the boost, so it's not required at all if you're running a 5.8psi spring.
JP is offline   Reply With Quote
Old 04-02-2013, 11:15 PM   #201
86pro
Drives: frs
FA20club will set you up proper. Never been lead wrong and i must say one of the best if not the best in reaching your goal safely. My car runs really great and soon will be running in a way different class. I feel safe with them knowing the dedication towards making our cars leaders in the modified segment. Two thumbs up!!!!
86pro is offline   Reply With Quote
Old 04-02-2013, 11:18 PM   #202
Visconti
Drives: 05 STi
This is the problem I ran into when Visconti was tuning my car. I went from having perfect AFRs to leaning out at WOT. His solution was to install two O-rings instead of one and he had the part number to buy them from NAPA. I pulled my pump, installed the two O-rings and put it back together and my AFRs went back to perfect.
yup
Visconti is offline   Reply With Quote
Old 04-02-2013, 11:32 PM   #203
mad_sb
Drives: 2013 Asphalt FR-S
so is the current assumption that it went lean at 6psi and det killed it? Or do we think the manifold reference line got kinked or failed in some way. Or...........
Old 04-03-2013, 12:04 AM   #204
Cheddar
Saving them pennies...
Hmmm interested in finding out the PCF (part causing failure)
Cheddar is offline   Reply With Quote
Old 04-03-2013, 12:34 AM   #205
Noob4Life
86 Noob
Drives: Firestorm FR-S
Well he said the car is getting picked up from yoda and getting a built engine do I doubt well know anytime soon if at all. Hopefully fa20 club looks into it and finds out the cause just for reference.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
Old 04-03-2013, 01:59 AM   #206
ft_sjo
Drives: GT86
yup
Since when is wedging two o-rings together considered proper installation?
Old 04-03-2013, 02:26 AM   #207
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I now know what to title a thread as in order to have the most views, thanks!
But in all seriousness, sorry for your loss man, it seems like @FA20Club.com is going to hook you up witha nice built block setup though! Best of luck to you!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-03-2013, 11:07 AM   #208
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
this...
Huehuecoyotl is offline   Reply With Quote
Old 04-03-2013, 11:10 AM   #209
2forme
You've apparently never seen MacGuyver.
He would have used a rubber band, some gum, a paperclip, and a corn husk.
The Following User Says Thank You to 2forme For This Useful Post:
ftc~brz (04-23-2013)
Old 04-03-2013, 11:10 AM   #210
Visconti
Drives: 05 STi
Originally Posted by Huehuecoyotl View Post
this...
Back in 2008/9 when we started using this size pumps !
-John
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 05:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 05:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 11:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 10:24 PM
