#197 | |
Drives: FRS :D
if anthing going bigger in displacement would be moving into the past when we had crazy big motors like 7.3 and what not. the future of cars is smaller lighter and fuel efficent. also your comparision is kinda void as you compared a type r to a si than a mustang to a mustang. Lets compare a 97 mustang to daves ITR and you will see the mustands 4.6 V8 was rated for 215hp (upped to 225 in 98 then 260 in 99) while the ITR was rated for 200 and was much much faster on track stock than the mustang. I will not discredit the improvement of the mustang but when you go from a crappy design that hasnt been changed for a number of years to a brand new engine than yes its a massive improvement. Lets do a more fair comparsion how about 90s si vs now si there is no 97 si so I will used a 95 as well as a 98 the 95 si was rated for 137 and the 98 si was rated for 160 and now the si is 201 and please note that you compared a sportscar to a commuter car as well. I did a quick search and found the best time I could for a mustang around the ring and while it is only the 05 4.6 v8 it had a bunch of mods and the best time I found was 8:49 which is slower than a factory type r and that just shows you driver and handeling do more for you than power also if I wanted to use a terrible agurment about comparing cars of the same I could of always said well if you look at the GTRs back then to the GTR now thats a massive improvement from the 90s or brought up the fact that the z went from 300hp with the 300zx to 331hp with the 370 and thats a 21 year jump with a modest hp increase also i could of same to be most fair we should compare the original fb motor to the ft86 fb motor which the original is rated for 145 and the ft86 is rated for 200HP thats a massive improvement on a engine that has been out since 2010 either way tho the saying remains true fast cheap reliable <-- you can only choose 2 |
#198 | |
Drives: 2010 Evo X MR-T
the best idea is for TRD and STI parts. a la carte options for those who want to pay, and nothing for those who dont... not a huge stretch since TRD parts are already available for scions. all subaru has to do is rebrand them STI... |
#199 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
A lot of the cars you just mentioned comes from which country Mr.Jay? If you want me to play fair then how about this then. Compare Daves car to the DC5 type R and you will see the improvements aren't there either. The DC2 type R is pretty much superior to its sucessor. You know this but you're being naive as hell. Im not against Japanese sports cars but I am also not naive to notice the changes in most of them. I also never said that all Jap cars are like that. The 300zx from the 90's was much more expensive than its sucessors. It started at 40+k for the turbo model. The base model was closer to a 350z in price and had only 220 hp.
#200 | |
I weighed it on a scale, don't know what to tell you. Removing the sunroof will lower the center of gravity, but adding in the carbon roof will retain rigidity. Aside from that, I'll be running a cage for more rigidity. There is no non-sunroof model, they all have the glass. Only a select few that were produced in low numbers don't open the glass, but still has it. |
#201 | |
Drives: FRS :D
Actually I don't know this and you don't know this there is no such think as a dc5 type r in north america and I was using example unlike you were comparing 2 cars of the same model from different generations as oppose to 2 cars from different classes from different generations which makes no sense at all I'm no defending the lack of improvement I just wont be judge and jury on something I actually don't know if you want to play fair than start making fair camparsions instead of just assuming I'm defending what you are attacking when really I'm just breaking down what you say and pointing out that its a flawed rebuttal btw I love this you ask where the cars are from then talk about palying fair by mention a USDM car and comparing it to a JDM ONLY car that you never driven and really know nothing about. I have driven a K20A powered Type-S and while I wouldnt say it was better than a ITR cause it wasnt the motor and transmission were a massive improvement over the USDM type-s so i can only imange what it would of been like given the entire suspension setup between the USDM type s and the JDM type R are different |
#202 |
Site Moderator
Drives: Stuff
To be fair to Sub's point, Japanese reviewers stated many times that the DC2R was preferred over the DC5R, especially early on.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#203 | |
86 Member
#204 |
Drives: Subi
#205 | ||
Drives: 2013 DZE/01 (sold for MX5 ND1)
#206 | |
Drives: FRS :D
well the mustang is made here and the other cars are made in japan but thats the point you grip was about Japanese cars I would agree the DC2 ITR is a very special car IMO |
#207 |
Drives: tata nano
I would bite if they offered a 300hp car for less than 30k. It would be a good buy if they then built the engines for F.I. reliability/power like they built the 2jz supras. The power to weight ratio and mod potential would be insane.
#209 | |
Hot Lava
Drives: 2013 Scion FR-S, 1990 Miata 5MT
![]() - Jason
2013 Hot Lava Scion FR-S 6MT
#210 |
Drives: Ninja 650R
This is probably the most realistic estimate. Anything below is pure fantasy.
| Pictures of Scion FRS in a different environment | john | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 05-10-2011 05:46 PM |
| Report: Toyota FT-86 Sedan Version Coming | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 62 | 09-24-2010 10:45 PM |
| Report: Toyota FT-86 will move up in price and age demographic | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 201 | 06-02-2010 04:36 AM |
| Report: Baby Toyota FT-86 also in the works | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 05-17-2010 08:41 PM |
| Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! | Nemesis | Scion FR-S / Toyota 86 GT86 General Forum | 128 | 02-19-2010 12:36 PM |
