#197 |
Drives: 2013 BRZ Limited
I have a 2013 BRZ but want to put 2017+ OEM headlights on it. My question is about the DRL.
2013-2016 use the DRL LED strip in the front bumper, 2017+ use the boomerang in the headlights for DRL. What would happen when I use 2017+ headlights in my 2013? Would the DRL be the LED strip in the front bumper and also the boomerang in the headlights or which one would be the DRL?
#198 | |
Drives: 2013 WRB BRZ Limited
The bumper running lights would work only as DRLs. If you want you can use a harness to make either or be on al the time or during specific circumstances. What do you want them to do? -B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | Suparu (12-14-2019) |
#199 | |
So the 2017+ headlights’ boomerang will only work as parking lights like the 2013-2016 headlights do, unless I use a harness to enable the boomerangs for DRL? That sounds spot-on unless I have a change of heart and go for the 2017+ front bumper. Dual oil coolers in the fog light spots of a 2017+ is an enticing idea, I’d definitely want to use the boomerangs as DRL in that case.
#200 |
Drives: Q5 + BRZ + M796
I went with a 2017 bumper, vlands which are plug n play, OLM vertical DRLs and Morimoto HIDs, and I couldn’t be happier. I decided to forgo fog lights for a cleaner look and because I don’t think they are entirely necessary. Considering my headlights are lower than fog lights on most trucks. Yes they are brighter than yellow fogs, but I also don’t see much fog or commute far.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Suparu (12-15-2019) |
#201 | |
-B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | Suparu (12-15-2019) |
#202 |
Drives: jrsc_brz
ill be doing the brz fog light repin today. i saw it first on this video. you swap the drl and fog pins with each other. it allows to have the boomerangs on with the fogs, no drl/no headlight. you basically send power to the fog when it otherwise would have been powering the drl. its going to look like this, and ithink its mean.
[ame="https://www.youtube.com/watch?v=iHC-O4qNcFM"]https://www.youtube.com/watch?v=iHC-O4qNcFM[/ame] they walk through how to here: [ame="https://www.youtube.com/watch?v=uDqU6VsbO1A&t=398s"]https://www.youtube.com/watch?v=uDqU6VsbO1A&t=398s[/ame] |
#203 |
Upgrading all lights on my 2013 to white LEDs to have a more modern look. I have a series 10 which has HIDs stock already but the bulbs are OEM which means they are 4300K and 6 years old now. Trying to match 6000K. Anyone with HIDs which bulbs did you use? Also these only replace low beams correct?
2013 Series 10 FRS #553
#204 | |
Regardless I’d recommend either Osram CBI D2S bulbs Or Osram CBB D2S bulbs Either can be found from the retrofitsource. If you need help ordering let me know. -B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | jflogerzi (12-27-2019) |
#205 | |
#206 |
#207 | |
Drives: Scion FR-S 10 Series
#208 | |
I need to do some research Sent from my GM1915 using Tapatalk
#209 | |
Wheels for Brains
#210 | |
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 04:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 09:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
