Old 08-07-2013, 03:41 AM   #197
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Originally Posted by retrosmiths View Post
One of them needs rotation (see double side lines).
Right side, check bulb seating.
How do i rotate
And ok ill check the passenger bulb
FR-Shadow is offline   Reply With Quote
Old 08-07-2013, 10:34 AM   #198
Yruyur
Yruyur's Avatar
Rotation instructions would be great. My alignment has settled since the install and his looks great.
Sent from a Motorola DynaTAC 8000X
Old 08-07-2013, 04:26 PM   #199
retrosmiths
Drives: Scion FR-S Whiteout
Uhh..I forgot, if it's the retroquick set for our cars you wont be able to rotate, not without opening up the headlights and adjusting the shields.
Sorry. Mini H1s aren't meant to be full performance, 100% aligned projectors.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 08-07-2013, 04:29 PM   #200
retrosmiths
If you still want to rotate it, here's a quick and dirty breakdown:
Open up the headlights.
Remove the projector lens.
Widen the holes of the metal shield.
Hand-adjust against a wall.
Screw the projector lens back tight to retain new alignment.
Put everything back together.
Will take you about 5-6 hours. At night.
2013 Scion FR-S
Old 08-07-2013, 04:33 PM   #201
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Great Advice! No thank you, lol
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-08-2013, 07:06 PM   #202
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
@FR-Shadow - Your alignment looks pretty good. As @retrosmiths mentioned, the MH1s aren't going to be perfectly aligned. Mine taper off to the extreme ends of the beam, but it's not worth my time to make them perfect. If I do end up cracking the headlights open again, Im replacing the projectors with something else entirely.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-08-2013, 09:03 PM   #203
retrosmiths
^ "aren't"
2013 Scion FR-S
The Following User Says Thank You to retrosmiths For This Useful Post:
civicdrivr (08-08-2013)
Old 08-08-2013, 09:18 PM   #204
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ "aren't"
Sometimes my fingers can't keep up with my brain. Fixed.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
Old 11-24-2013, 08:33 PM   #205
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by civicdrivr View Post
I finally got around to getting the headlights aimed properly.
Tools Needed:
-Tape (painters tape is preferred since its easy to see, but all I had was duct tape)
-Measuring tape (one that is at least 25')
-Phillips head screwdriver
-Wall and flat, level ground (I find that loading docks are perfect for this)
-Night
The basics: The DOT standard for aiming lights is simple. Park the car on flat, level ground 25' from a wall. Measure the height of the head light from the ground (use the little dot in the headlamp lens to measure from), subtract 2", and line up the uppermost portion of the cutoff with that number.
For example: The headlight in the below picture 26" from the ground. Therefore, the top of the cutoff should be 24" from the ground (when parked 25' from the wall).
The adjusters youre looking for are these:
Passenger side:
Driver side:
The screwdriver goes between these two slots:
Remember the old saying - righty, tighty, lefty, loosey? Well, righty in this case raises the beam, lefty lowers it.
And its as simple as that.
Color band at ~100'
Overall, these projectors are very impressive given their size and price point. The highbeam impresses me most. Unfortunately I was unable to snap pics of that as I was being questioned by cops.
what do u use to keep DRLs, but open/close projector flap? if i just tap the wires into the hi beam the flap opens wen my DRLs come on
lbroskee is offline   Reply With Quote
Old 11-25-2013, 04:22 PM   #206
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
That's correct. The flap on the bixenons opens when the DRLs come on, but the HID bulb itself doesn't receive any power. I've run it this way for the past 33k miles without any issues. Once you power the low beams, the DRL shuts off and the bixenon flap closes. Turn the high beams on, and the halogen bulbs power on as well as the bixenon flaps open.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
lbroskee (11-25-2013)
Old 02-17-2014, 01:18 AM   #207
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
Does anyone know what this connection is? It came attached to the harness, the wired that plug into the car's low beam connection. Is that the wrong adapter?
Techfl3x is offline   Reply With Quote
Old 02-17-2014, 01:20 AM   #208
lbroskee
lbroskee's Avatar
mine had that too. if I'm not mistaken its the non plug n play style and needs to b wired to power and ground
The Following User Says Thank You to lbroskee For This Useful Post:
Techfl3x (02-17-2014)
Old 02-17-2014, 01:33 AM   #209
Techfl3x
Techfl3x's Avatar
I took it off but the two connectors aren't compatible (low beam cable from harness and low beam cable from vehicle). Did you end up tapping directly into the vehicles low beam positive and ground wires?
Old 02-17-2014, 05:35 AM   #210
lbroskee
lbroskee's Avatar
We threw it out and got the correct cable to make it PnP. Not sure y they automatically send this crap out, but i wanted it to b fully reversible
Techfl3x (02-18-2014)
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 10:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 08:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 04:16 PM
