#2073 |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Those are 22mm MO fittings (Metric O-Ring) and not designed for copper crush washers. Did they not supply a torque spec for those fittings? According to a manual I wrote a while back, the ORB fittings on a Setrab core should be torqued to 29.5 ft-lbs and you should be using a wrench on the Setrab core to prevent that torque from ripping the fitting off of the core. Furthermore, the o-rings need to be lubed prior to installing the fittings to prevent them from galling and/or bunching up. Also be sure to use a wrench to support the MO fitting when installing the AN fitting as well.
#2074 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Got it all installed.. Kit yesterday, injectors today.. Just waiting for a map to limp up to the dyno on Thursday..
#2075 |
Drives: 2013 Scion FRS
Looks clean! Did you leave the blast shield off on the drivers side over the injectors or did you make it fit? Mine is still off and I can't tell if yours fit on or not.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#2076 | |
I'm researching now the torque capacity and longevity of the automatics.. I see them holding 400+ hp and 350+ torque but can't find out if they are still running that.. Oil coolers are crazy expensive lol..
#2077 |
I put my own tran cooler together and just installed it. I'm in it for ~$350 with the gauge. I didn't install a pump though - waiting to see if that's needed.
#2078 |
We still get the discount on the oil cooler if we bought the kit, right? I still need to pick one up.
#2079 |
Planning a diy?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2080 | |
#2081 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
BTW: We have another "Twisted Sister's Run" on 10-11. Hope you can make it this time w/ SC installed.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#2082 |
@Sithspawn is rocking the install and data in much more detail. Follow this thread for some great upcoming information:
http://www.ft86club.com/forums/showthread.php?t=61498
#2083 |
I'm doing R&D on a transmission cooler right now. Full data logging and analysis before and after with discussion of results.
#2084 |
Drives: 2013 Black FR-S
#2085 | |
Drives: Kraftwerks BRZ
Just give us a call so we can either extend the code so you can order at your own convenience over the web or we can simply extend the same deal right then over the phone! |
#2086 |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
