go_a_way1, MisterSheep
Old 05-26-2019, 03:19 PM   #20805
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Installed my new jdl uel headers! No issues whatsoever.
Gonna clean up all the dirt down there then wash the car and go for a drive!
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS13_ For This Useful Post:
humfrz (05-26-2019), JonAvalon (05-26-2019)
Old 05-26-2019, 04:31 PM   #20806
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Final installation of the wing (before paint) Finished..
First..
We welded up the holes in the trunk
Cut out small steel panels and molded them with a huge socket to fit the curvature. Low amperage and pulse rate. the skin of the trunk is easy to melt through
after they were drilled out we placed the wing on the trunk and took alot of measurements..
Alot
we trued it up to the corners of the trunk and rechecked them vs raw left to right measurements. and then cross measured the holes.
Late night so no one measured the actual distanced for mounting holes and of course no one has a template for this so we just eyeballed the exact front to rear measurement.
That took the better part of the evening. so I had to tape them up and wait for another free period
While I was home I painted the bare metal parts. I love me some self etching primer, and then follow on top with 2 step primer sealer. it dries so fast. it doesnt look bad from a distance but the trunk needs sculpting. this car is more for use than looks anyways. I might ducktail it later. who knows
Not the first time I took a rattle can to OE paint.... sadly wont be the last.
The third and final trick to this was the underpaneling braces. that attaches the wing from the skin to the inner skeleton, which is the bracing for the wing. not super Race-car, but its what subaru deemed good enough and the TCR cars run this set up per rules.
A 1 and 1/8th hole saw centered around the wing holes did the dirty. slow and methodical though this is thin steel so it just cuts like butter with a good hole saw
Then putting the tabs in place and drilling more holes ( this was a rather holy experience)
Final assembly and one last check for body straightness. leads to this!
Back Half looks like a BRZ Ts ( anyone got brembos to sell me?)
how She sits today
the final thing I need is
iF you look towards the left there is a rubber trunk stopper on the skin, i have the hole for it but no part number, yet
Almost done gents. Hope this helps with the next kid who stupidly spends alot of money for no reason
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
new2subaru (05-26-2019)
Old 05-27-2019, 12:47 AM   #20807
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
"iF you look towards the left there is a rubber trunk stopper on the skin, i have the hole for it but no part number, yet."
Are you looking for number 2 in this diagram?
https://parts.olathetoyota.com/auto-...omponents-scat
fx1mark is offline   Reply With Quote
Old 05-27-2019, 12:54 AM   #20808
DarkSunrise
DarkSunrise's Avatar
"But does it baby?"
Yes, yes it does. Barely.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
humfrz (05-27-2019), Ultramaroon (05-27-2019)
Old 05-27-2019, 11:24 AM   #20809
KDad2
KDad2's Avatar
Drives: 2013 Raven
A few mods this weekend:
Mishimoto radiator
Mishimoto fan shroud
Mishimoto low temp thermostat
Mishimoto radiator cap
Mishimoto liquid chill
Mishimoto chill coolant
Toyorad fill neck
Samco hoses
Beatrush bottom panel
Hella horns
Sent from my SM-N960U using Tapatalk
KDad2 is offline   Reply With Quote
The Following 3 Users Say Thank You to KDad2 For This Useful Post:
humfrz (05-27-2019), new2subaru (05-27-2019), Ultramaroon (05-27-2019)
Old 05-27-2019, 02:04 PM   #20810
Clutch Dog
I believe so one of the other guys gave me the part number from his ts. Thanks for the input
Old 05-28-2019, 12:54 AM   #20811
jflogerzi
jflogerzi's Avatar
Originally Posted by DarkSunrise View Post
"But does it baby?"
What seat brand and model?
2013 Series 10 FRS #553
Old 05-28-2019, 01:14 AM   #20812
humfrz
Looks like this one.
pa-pa-humfrz
DarkSunrise (05-28-2019)
Old 05-28-2019, 01:18 AM   #20813
DarkSunrise
It was given to me by a family member so not sure, but I think it's a Cosco Scenara Next DLX.
https://www.walmart.com/ip/Cosco-Sce...QaAsk8EALw_wcB
If you're thinking about getting one, note that I had to roll a towel to fill the gap between the carseat and the bottom cushion. Even then it's got more play than the Maxi Cosi Pria 85 Max we have in our GTI, but it's good enough for short drives around town with the kid.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
jflogerzi (05-31-2019)
Old 05-30-2019, 03:09 PM   #20814
MJones_RB
MJones_RB's Avatar
Finally installed my pedals. Such a PITA.
MJones_RB is offline   Reply With Quote
The Following 3 Users Say Thank You to MJones_RB For This Useful Post:
Cheeky (06-07-2019), Clutch Dog (05-30-2019), Conman (06-02-2019)
Old 05-31-2019, 07:26 PM   #20815
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
WHAT DID YOU DO TO YOUR FRS TODAY?
Installed a tow hook ring -just for the look-
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
MJones_RB (06-03-2019)
Old 06-02-2019, 12:06 AM   #20816
humfrz
I gave my FR-S its semi-annual washing.
YES, it was a big deal - for me. -
Questions: Do you agree that one doesn't have to dry off the lower half of the car, just let it drip dry?
Do you agree that if the water still beads up on the car, it doesn't need waxing?
If you agree, let's hear from you, if you don't, just shut the fuck up -
humfrz
Old 06-02-2019, 12:18 AM   #20817
Clutch Dog
humfrz
I dry off the complete car. my dad taught me from a young age to go over inch by inch when washing the car. not so much for cleanliness but you get the best sense of whats goin on with the car when you are up close and personal with it like that.
I only wax the car twice a year. between wax coats i just use the instant detailer. so yes if it beads up its fine
I also have the ceramic coating so it might be different there
humfrz (06-02-2019)
Old 06-02-2019, 12:44 AM   #20818
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
New summer tires, oil+filter, cleaned out the air filter, etc.
And @Ultramaroon's clutch slave cylinder swap. Very pleased with the result.
http://www.ft86club.com/forums/showthread.php?t=77390
Tires are Yokohama Advan Sport V105. I'll have to drive a bit more to give an opinion on them, but they were pretty cheap at tire rack in stock size.
Spuds is online now   Reply With Quote
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Clutch Dog (06-02-2019), humfrz (06-02-2019), Ultramaroon (06-08-2019)
