Old 01-26-2014, 02:28 AM   #20735
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
What stereo is it and i can tell you what goes where.
sent from your mom
It's the BRZ stock navi. The Fujitsu Ten Limited unit. Model number FA632US
^GT5 Replay Photo Mode^
Old 01-26-2014, 02:29 AM   #20736
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
If you don't think "Damn, what a sexy ass car" every time you walk past your car, you bought the wrong one.
Just got home from hockey. What a sexy ass car.
Old 01-26-2014, 02:30 AM   #20737
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
^ Lol....I still park at work and always look back at mine...
Pscylo is offline   Reply With Quote
Old 01-26-2014, 02:31 AM   #20738
Lischynski
Weendog
Lischynski's Avatar
You n me both. I can't not look back at it, every. single. time.
Old 01-26-2014, 02:45 AM   #20739
captain_jack
captain_jack's Avatar
So im missing something then, that should be a plug and play as eclispe uses toyota plugs. Let me put it this way. In the 10 pin harness there is a brown wire(pin#9) next to a pink(pin#8) that is the amp turn on wire that needs be powered up while stereo is on.
sent from your mom
Old 01-26-2014, 02:50 AM   #20740
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I thought the power antenna lead on the aftermarket harness when to the black wire that's connected as a separate harness to the antenna harness. The harness adapter has a blue wire that is doubled into a pin beside it, and then a blue wire extending out from it, so basically it puts 2 signals from just one input. The blue wire is labeled "power antenna" on the wire itself. The Sony HU, of course, has the blue/white wire that's tagged with a label sticker as "remote turn on". I'm familiar with this, as it is used to wire directly to the remote turn on input on aftermarket amps. The aftermarket harness doesn't have a blue/white wire for remote turn on... at least not one labeled as such. So, I bet that doubled over line on the metra harness is for both powered antenna and remote turn-on from the remote turn-on lead from the Sony HU. Attached is a picture of the wiring harness layout of the Sony XAV-701HD. The sheet also has instructions on powering the remote antenna if there is one, but the harness from Sony doesn't have a dedicated powered antenna lead.
Also, the Metra harness had a orange/black lead for "Dimmer gnd". I'm guessing (most likely correctly) that this is just for HU's which receive the dimmer input from dimmer ground, not dimmer (+). Haven't had one yet that did that, though (since I've owned a car, I've owned 4 aftermarket HU's: 2 JVC's, a pioneer, and now this Sony). No biggie, just another item I noticed.
But I'll try this. It'll be nice to have SOME extra bass (though muddy and crummy) until this coming Saturday when the JL Amp, JL sub, JBL components, and JL 4" coaxials go in.
I think it was supposed to be left unplugged though, as the metra harness didn't have provision to fit this one. It's more than just remote amp turn on, as there's several pins there that are wired to something. Curiosity is definitely getting to me on what this particular harness is for. I'm pretty certain on what all the stock HU monitors and where it gets its data, and all those sources and outputs are accounted for (geo location and speed from the gps, radio from the antenna and it's powered wire, device input from the usb/aux-in cable, standard speaker and power harnesses, xm radio input from xm antenna in).
Maybe it's for connecting to the ecu for speed input, and for some reason it needs quite a few wires to determine that, just so it can say 'screw you' to dialing or texting or even getting to your contact list when the wheels are moving.
There's a thread somewhere that shows the back of the FR-S and BRZ head units. Though they are different, they use the exact same plugs, just arranged differently, and it shows what all is what. This might be it, I haven't dug through it yet.
http://www.ft86club.com/forums/showthread.php?t=9269
oldpueblo is offline   Reply With Quote
Old 01-26-2014, 02:52 AM   #20741
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Originally Posted by Lischynski View Post
Attachment 64920
Ill admit ever break I have I go out just to stare
Shad0ez is offline   Reply With Quote
Old 01-26-2014, 02:52 AM   #20742
SirBrass
SirBrass's Avatar
So im missing something then, that should be a plug and play as eclispe uses toyota plugs. Let me put it this way. In the 10 pin harness there is a brown wire(pin#9) next to a pink(pin8) that is the amp turn on wire that needs be powered up while stereo is on.
sent from your mom
The metra harness that was sent to me as an adapter had 2 harnesses, which I successfully wired up: a 5 pin, and a 10 pin.
I'm not sure the adapter harness colors matched the wires they were adapting to, so I wasn't looking at the actual harness itself (the cables don't pull out of the opening that far, and being all bundled together and tied off down the line to the interior, it's hard to get a good look at all the wires there going into which pins), so I don't know if that's it or not. I can only tell you what the metra harness had. And I forgot which harness had the doubled over wire (linking 2 pins together) for the powered antenna-labeled lead.
It's late, but there being church tomorrow and that this will keep bugging me till I do something about it, I'm going to go out and crimp the remote lead to the blue wire on the adapter harness and we'll just have to see what happens. I'll see if I can identify the wires the blue wire connects to on the OEM harness. If it leads to a brown wire, we're golden I suspect.
But the mystery harness is, after looking at the linked NASIOC thread in the thread that was just earlier linked, the factory 28-pin harness.
Here is the pin-by-pin description of that harness (this was the droid I was looking for!): http://forums.nasioc.com/forums/show...28&postcount=9 (do note, this is for the Imprezas, so the aux-in isn't handled here in the BRZ, but in the USB/Aux-in plug that is single cable leading from the usb/aux-in assembly)
28-pin SWC/aux/mic harness
1 .. 14
15 .. 28
(orientation: viewing pins on car's factory plug, wires pointed away from you)
Code:
1 [NC]
2 Reverse Gear
3 Illumination Dimmer Cancel ("Bright" mode)
4 Mic 5V power supply to mic amp (separate wire)
5 Mic Audio Input + (twisted w/ pin 19)
6 Mic detect (car ties this pin to chassis ground, does not connect to mic module)
7-10 [NC]
11 [NC] (Ground for aux enable)
12 [NC] ("SG" ?)
13 [NC] Aux Video Input (+) [may not be present on most Subaru HUs]
14 [NC] Aux Video Input shield/ground [may not be present on most Subaru HUs]
15 [NC]
16 [NC]
17 VSS
18 [NC]
19 Mic Audio Input - (twisted w/ pin 5)
20 [NC]
21 SWC1 Audio (Seek, Volume)
22 SWC2 Mode & Phone
23 SWC Common
24 [NC] {SW3 on some Toyota HUs}
25 Aux enable
26 Aux audio Right
27 Aux audio shield/ground
28 Aux audio Left
Old 01-26-2014, 02:56 AM   #20743
captain_jack
Yes the blue ant plug wire and the metra 17-1761 blue wire go to the sony's blue with white stripe wire.
sent from your mom
Old 01-26-2014, 03:12 AM   #20744
SirBrass
SirBrass's Avatar
sent from your mom
cue Mr. Burns: "Excellllllent"
Edit: Und zat vurked.
Surprisingly, the audio quality went up a notch. The bass doesn't sound near as bad as with the stock HU. I'm starting to think that the stock sound system isn't really all that terrible in the audio department... it's just terrible and clunky in the DSP area, and the interface has much to be desired (but is leaps and bounds above the stock Clarion units Subies normally come with.... ). Mirrorlink audio just SUCKED previously. I'll have to see if it sounds cleaner now (doubt it, as before the USB and BT audio sounded just fine without the amp being turned on, but the mirrorlink audio just sounded.... crackly, like it was clipping the digital audio just a tad before it hit the DAC).
This new HU is definitely a VERY good upgrade (Sony XAV-701HD) for the price. But I wouldn't spend $500 on a new HU like this just to keep it wired to the stock audio system. I have a feeling I'm going to really like what better speakers, amp, and an actual subwoofer can do for this car. That's when this HU's DSP capabilities will come into play, I think. I've heard negative things about Sony's car audio products in the past, and I still wouldn't use their amps, subs, and speakers when there's much better available (same with Pioneer, though their Champion series amps can't be beat for the price they go for).
Old 01-26-2014, 03:56 AM   #20745
brenesk91
brenesk91's Avatar
Drives: 2013 SS BRZ
You know you bought the right car when you turn it on, and it returns the favor
brenesk91 is offline   Reply With Quote
Old 01-26-2014, 06:52 AM   #20746
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
This weekend's project has arrived.
Old 01-26-2014, 03:02 PM   #20747
NinjaRxMan
NinjaRxMan's Avatar
Me and @ChandlerSwyng at Import Face off. Name:  uploadfromtaptalk1390766506686.jpg
Size:  97.1 KBName:  uploadfromtaptalk1390766524485.jpg
Sent from my SGH-T999
Old 01-26-2014, 03:46 PM   #20748
BobbyBlue86
BobbyBlue86's Avatar
Drives: Subaru BRZ
Well, one of my wheel bearing is going out. Making the most horrible noises while on the freeway... >.<
BobbyBlue86 is offline   Reply With Quote
