#2017 | |
Drives: Subaru BRZ 2017 (almost)
Sent from my Nexus 6P using Tapatalk |
#2018 |
Grip>Drift
Drives: FRS
Need some advice! 18x9.5 with 255s how much negative offset can I run? I'm pretty low but I've been on 17x9 with 245 and I'm running -28 offset. The 18x9.5s I just got are -38 but I don't want to keep switching spacers all the time, can I run -23 F and -28 rear without rubbing on the fender like mad? I have -3 F camber too.
I have ARP studs and 5,10 and 15mm spacers but I don't want to shuffle them around when I go back in forth between my 17 and 18" set-ups. Sent from my iPhone using Tapatalk
#2019 | |
I'm on 18x9.5 +34 on 255/35 with around -2.9f/-2.7r camber. I rub on the bumper tabs on the rear and front clears. If you can rephrase the question with what tire size you plan to run, maybe I can give a better example. But for 9.5's, mid to high 30's and low 40's positive offset it what is needed without extreme(4+) camber. |
#2020 | |
Drives: 2013 BRZ black
![]() I run -3.0deg square on my square set of 17x9+35 WedsSports on 245/40. These are currently my dailies/track set. Soon to be track only with 255/40 R888r's Heres some shots of what I have to play with. I can come in as much as 1.5" on the rear before making contact with the E-brake cable or fender liner and about 1.25" up front on the Ohlins. I dont think I will have any issues with fitment unless someone wants to chime in. ![]() ![]() ![]()
#2021 | |
Drives: 2013 Ultramarine FR-S
#2022 | |
In the back, I already measured (see pics above) and should plenty of room. Ill be running close to zero camber so it shouldnt come anywhere near the coilover. Im trying to stay out of contact with the fender with this offset basically. Think a +40 would be better? ![]()
#2023 |
Drives: '13 BRZ Limited
Really need help, I have 265/35/18 Federal RSRRs in the rear on a 18x9.5+30 wheel, its rubbing the fender A LOT. I'm on Tein Flex Z with no LCA or camber bolts, my car is dropped. Do i need to raise or lower the car to make them fit?
#2024 |
Raising the car may not help. When I was still on OE control arms, -2" ride height gave me -2.5deg natural camber. Going up to -1" ride height made my natural camber -1.7deg. I would think you would still be eating your fender. Better solution may be adj lower control arms to add more negative camber.
#2025 | |
#2026 | |
![]() Sent from my Nexus 6P using Tapatalk Last edited by nima314; 11-30-2016 at 08:24 AM. |
#2027 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i can't stress dialing in some camber enough. +30 is quite aggressive for that tire to be practical in my opinion. i was running +40 with same specs and that was tight fitment. You should roll your fenders to gain some clearance if you'd like and then pull some more camber all around. or go to a 255/35 tire. you can also raise it a bit to help elevate some rub. |
#2028 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
No problems here, but I guess my setup isn't as aggressive as yours. 17x9 +35 with 255/40 tires on Tein Monosport with minimum drop (.5" I think?). |
#2029 |
Drives: 2013 BRZ Limited
Finally joining the club!
SPECS: Rays Gramlights 57xtreme Front: 18x8.5+45 w/ MPSS 235/40/18 Rear: 18x9.5+40 w/ MPSS 265/35/18 Factory alignment specs Lowered ~1" front, ~0.75" rear (due to tire rubbing in rear, need to add a bit more camber) ![]() ![]()
#2030 |
Drives: 2014 Subaru BRZ
I have a question regarding the size of tires I'll get.
Im planning on buying another members ambit re02. I have 1" lowered springs and stock struts. I like a little meaty tire but also doesnt want to have issues on rubbing. What is the best tire setup I should go for? Appreciate it. Sent from my SM-N900W8 using Tapatalk |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
