Old 04-09-2018, 05:17 PM   #2017
fika84
fika84's Avatar
Originally Posted by ATL BRZ View Post
@fika84 appears to have installed it with a temperature sensor, but I'm not sure if he has data available yet!
I DO! Not track data yet, but spirited driving I've seen between 140-160F.. Really excited to get on the track and see if I get close to 200F+ Haven't made up my mind on cooler routes yet until I get this information!
The fluid I'm using is Torco RTF and it doesn't look like I want to go over 212F by the looks of the viscosity levels... I don't know if that's really the case though..
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
ATL BRZ (04-09-2018)
Old 04-09-2018, 05:19 PM   #2018
fika84
fika84's Avatar
New high capacity billet diff cover just showed up. Increases oil capacity from 1.16L to 1.7L with baffles and ports for a cooler. Not bad for only $68 shipped! Got this one in raw finish knowing that I might have to grind down a couple of the fins to clear the 3" Dezod exhaust.
You and me both! I had to grind for the 3" Perrin to clear it.. and even with long hangers it's pretty much right up against it.. No rattles, but I'll keep an eye on it.. just don't want the exhaust to cook the diff!
Old 04-09-2018, 05:30 PM   #2019
Pat
Pat's Avatar
Drives: 2023 BRZ
Oh that's right, now I remember seeing fika's post. Street data is nice, but let's face it: a part like this isn't exactly that beneficial unless you're really pushing it. Track data is going to be much more telling.
The Following User Says Thank You to Pat For This Useful Post:
Old 04-09-2018, 05:37 PM   #2020
fika84
fika84's Avatar
You got it! You and I will have to drive down to HPR soon then!
The Following 2 Users Say Thank You to fika84 For This Useful Post:
ATL BRZ (04-09-2018), Pat (04-09-2018)
Old 04-09-2018, 07:19 PM   #2021
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
IMO that RTF fluid seems pretty much on the limit of "acceptable" for the diff, viscosity wise. Hopefully the cover & increased capacity helps it stay cool!
I'm interested to see the data, the cover should help a decent amount mostly in fluid capacity, I think.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
ATL BRZ (04-10-2018), fika84 (04-10-2018)
Old 04-10-2018, 12:53 AM   #2022
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Step your game up
http://performanceracingoils.com/mil...-crx-75w90-nt/
The Following User Says Thank You to ATL BRZ For This Useful Post:
fika84 (04-10-2018)
Old 04-10-2018, 09:34 AM   #2023
fika84
fika84's Avatar
Hey I'm always looking! This one is no bueno for me due to this - "Note: Does not contain friction modifiers. For plate type Limited Slip differentials use CRX LS 75w90 NT."
What diff are you using?
Old 04-10-2018, 09:35 AM   #2024
ATL BRZ
ATL BRZ's Avatar
I'm using the stock Torsen diff. If you have a real LSD, then you can use this version: http://performanceracingoils.com/crx-ls-75w90-nt/
fika84 (04-10-2018)
Old 04-10-2018, 09:48 AM   #2025
fika84
fika84's Avatar
Well it looks like that's next up on the list! I'm using the MFactory LSD.
Old 04-10-2018, 09:51 AM   #2026
fika84
fika84's Avatar
Do you rock Miller Oils for engine oil as well?
Old 04-10-2018, 09:52 AM   #2027
fika84
fika84's Avatar
Are you thinking for the stock diff though? Or for a mechanical LSD as well?
Old 04-10-2018, 10:23 AM   #2028
ATL BRZ
ATL BRZ's Avatar
Yes, I've been running Millers Oils for years. It's the most durable race oil on the market with the most friction reduction.
More info here: http://performanceracingoils.com/about-nanotech/
fika84 (04-10-2018)
Old 04-10-2018, 10:45 AM   #2029
fika84
fika84's Avatar
Sold!
Old 04-10-2018, 09:07 PM   #2030
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I was thinking for the gears, not the LSD itself. Sorry for the confusion
The Following User Says Thank You to DocWalt For This Useful Post:
fika84 (04-10-2018)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
