Old 03-26-2018, 06:22 PM   #2003
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Teardown pics are here! Diagnosis is a bent connecting rod.
The crud in the cylinders is from when I removed the direct injectors and what had collected on top fell down in there. I originally thought it had spun a bearing, but luckily that did not happen, or the rod breaking and windowing the block! The bearings look pretty good, actually, considering the abuse I put them through!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (03-27-2018), Teseo (03-26-2018)
Old 03-26-2018, 10:36 PM   #2004
Teseo
Drives: frs
MRT performance on youtube Bret talk in depth about bending rod if you are interested
The Following User Says Thank You to Teseo For This Useful Post:
ATL BRZ (03-27-2018)
Old 03-27-2018, 09:58 AM   #2005
ATL BRZ
ATL BRZ's Avatar
I've watched several of their videos! Good stuff!
Old 03-28-2018, 01:04 PM   #2006
ATL BRZ
ATL BRZ's Avatar
Heads and block getting prepped for hot tank cleaning
Block will also be sand blasted.
Old 03-28-2018, 01:22 PM   #2007
Teseo
Drives: frs
You will paint the block afterwards?
Old 03-28-2018, 02:01 PM   #2008
ATL BRZ
ATL BRZ's Avatar
No
Old 03-28-2018, 02:11 PM   #2009
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
man you're so lucky you didn't blow a window through your block... I wish mine didn't so I could have saved a ton of money... hope everything is going smooth. can't wait to see this when it's all done.
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
ATL BRZ (03-28-2018), Weapon86 (05-26-2018)
Old 03-28-2018, 02:30 PM   #2010
ATL BRZ
ATL BRZ's Avatar
lol for real!! I was expecting to see my crankshaft trashed with a spun bearing and I actually purchased a new one to have ready, now I get to return that and get $500 back!!
Thank you!!
Old 03-28-2018, 02:37 PM   #2011
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Thank you!!
Old 04-03-2018, 07:03 PM   #2012
ATL BRZ
ATL BRZ's Avatar
Blitz Oil Cooler kit just arrived!
The packaging was superb and the quality is outstanding! The core is huge for a 12 row, bigger than my hand!
That's blue protective film over the ducting pieces, they're not anodized.
The Following User Says Thank You to ATL BRZ For This Useful Post:
DocWalt (04-08-2018)
Old 04-08-2018, 03:38 PM   #2013
ATL BRZ
ATL BRZ's Avatar
Heads have GSC valve springs installed
Case halves cleaned and blasted
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (04-08-2018), DustinS (04-09-2018), PR138 (04-08-2018), TheStig85 (04-08-2018)
Old 04-09-2018, 04:03 PM   #2014
ATL BRZ
ATL BRZ's Avatar
New high capacity billet diff cover just showed up. Increases oil capacity from 1.16L to 1.7L with baffles and ports for a cooler. Not bad for only $68 shipped! Got this one in raw finish knowing that I might have to grind down a couple of the fins to clear the 3" Dezod exhaust.
DocWalt (04-09-2018), fika84 (04-09-2018)
Old 04-09-2018, 04:44 PM   #2015
Pat
Pat's Avatar
Drives: 2023 BRZ
That looks great. And what a value! Does anyone have data on how well it cools relative to stock?
The Following User Says Thank You to Pat For This Useful Post:
ATL BRZ (04-09-2018)
Old 04-09-2018, 04:59 PM   #2016
ATL BRZ
ATL BRZ's Avatar
Originally Posted by fika84 View Post
Definitely serves it's purpose! For the price it works great.. I didn't want to buy the Greddy or Cusco and then have to cut it up.. plus this part doesn't require R&D like a header..
@fika84 appears to have installed it with a temperature sensor, but I'm not sure if he has data available yet!
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
