Old 02-20-2018, 05:02 PM   #1989
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I'm curious to find out what the root cause of your failure was.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
ATL BRZ (02-20-2018)
Old 02-24-2018, 12:42 PM   #1990
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Two of the most critical parts of keeping the new build reliable. Top is a oil baffle plate from Moneyshift Racing to keep the oil in the pan under high cornering loads. Bottom is the high-capacity oil pump from Reimax Japan.
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (02-25-2018), SkAsphalt (03-12-2018), Teseo (02-24-2018), Tristor (03-02-2018)
Old 02-25-2018, 10:27 PM   #1991
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Is there finally info proving/disproving the Reimax gears? I saw a lot of conjecture about them but stopped following the details
Old 02-26-2018, 10:01 AM   #1992
ATL BRZ
ATL BRZ's Avatar
The original Reimax offering was just a stronger OEM sized pump gear. This is a new product that is a bigger gear with a spacer that increases the entire pump capacity and discharge volume, which should help with high RPM pressure. Results and data remain to be seen, however, there are many motors already running this kit.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (02-26-2018), Tristor (03-02-2018)
Old 02-26-2018, 03:51 PM   #1993
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Awesome, the big metal piece makes a lot more sense now. Thanks for the explanation!
Old 02-27-2018, 04:57 PM   #1994
ATL BRZ
ATL BRZ's Avatar
Pics for reference.
The machining required is minimal. 2mm on two dowels on the pump cover.
And the gear/spacer installed on the timing cover without the pump cover
DocWalt (03-01-2018), Ganthrithor (03-11-2018), JimmyMac (06-11-2018), Lust (03-12-2018)
Old 03-02-2018, 03:31 PM   #1995
ATL BRZ
ATL BRZ's Avatar
2017 bumper swap is happening!
Got a great deal on it in stock at a local dealership. I have the mustache and the rest of the stuff required for the swap on the way. I'll be adapting my existing brake ducting to the '17 fog housings, and trimming the grille off the separate mustache piece. I'll also be selling my current splitter and getting a new one from Verus as they have a specific model for '17 bumpers.
I've also ordered the ONLY Blitz oil cooler kit for the 2017 bumper headed to North America this month! I decided to part ways with the modified Perrin kit I have. I actually recycled the core as it's too risky to possibly run with bearing junk in it, so the lines and sandwich plate will be sold to someone else who can buy a new core for them.
I love everything about the Blitz kit, though. The shroud that directs airflow, the position off to the side to allow my intercooler but not invade my brake cooling hoses, the braided steel hoses, and a thermostatic plate with two ports for pressure and temp sensors! Very excited about it.
Lastly, I'm bringing the motor down to Mazworx next Friday!
DocWalt (03-03-2018), DustinS (03-02-2018), Lust (03-12-2018), Teseo (03-11-2018)
Old 03-11-2018, 06:22 PM   #1996
ATL BRZ
ATL BRZ's Avatar
The motor is now down at Mazworx and the rebuild has begun!
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (03-11-2018), Lococholo84 (03-12-2018), Lust (03-12-2018), pgranberg11 (03-12-2018), Teseo (03-12-2018)
Old 03-12-2018, 02:42 PM   #1997
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
OOo very interesting that your shop kept the stock compression ratio on a full engine build.
My shop was adamant that I lower it to 10.5.
What are the benefits of keeping the stock CR ratio?
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 03-12-2018, 04:18 PM   #1998
ATL BRZ
ATL BRZ's Avatar
Higher CR needs less boost for the same power, less boost means less heat generated. Bonus points for better off boost throttle response. I run E85 exclusively so there is nothing to worry about at 12.5:1.
Lowering the CR just makes the turbo more laggy and requires more boost to make the same power. It may be good for people with 91 octane as their only option, but I suppose I'm lucky to have access to much higher octane fuel.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Teseo (03-12-2018)
Old 03-14-2018, 10:03 AM   #1999
Proseph
Drives: Supercharged 2016 CBS BRZ
Mind telling us the cost of the "17 bumper and the rest of the parts to put it together? Thinking about doing this myself.
Proseph is offline   Reply With Quote
Old 03-14-2018, 01:07 PM   #2000
ATL BRZ
ATL BRZ's Avatar
For the bumper itself, this online retailer (Subaru Parts Warehouse) wanted an additional $250-$300 just to ship it, so I found one in stock at my local dealership for around $250 after tax.
Proseph (03-14-2018), TheStig85 (03-14-2018)
Old 03-14-2018, 01:10 PM   #2001
TheStig85
Drives: 2013 Subaru BRZ
Did you cut out the mustache? Or is it removable?
Sent from my Pixel 2 XL using Tapatalk
TheStig85 is offline   Reply With Quote
Old 03-14-2018, 01:13 PM   #2002
ATL BRZ
ATL BRZ's Avatar
The mustache and grille are a separate, removable piece for the '17+ bumpers. I have it now and will be cutting the grille off and installing just the mustache, so that portion will look similar to before but cleaner.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
