go_a_way1, MisterSheep
Old 09-28-2018, 10:33 AM   #19657
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
Originally Posted by itsAlex View Post
Wow that's quite a list of things you've accomplished considering its only been a few weeks! And thanks! I should have worded my previous post differently as it's actually an "OEM-style diffuser" and not an actual OEM diffuser.
My diffuser is basically a replica of the OEM diffuser, minus the carbon-fiber pattern as I believe the actual OEM diffuser has a carbon fiber look to it. Here in Ontario I managed to pick it up at a local shop for ~$100.
Ah gotcha. Yup been hammering down on the basic stuff quickly. Bought the car for the sole purpose of an LS swap as soon as possible and a daily driver in the interim so I don't have to drive my lifted F250 daily to work. Only buying parts that will be usable after the swap.
Axis2011KR is offline   Reply With Quote
Old 09-28-2018, 11:00 AM   #19658
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
I traded her in today, 14 FR-S with 46,000km for this 2017 Civic Type R #1505 with 14,XXX KM. It was a trade in, guy wanted a red one, so wife went and traded it in for a red one.
It was a hard decision leaving this chassis, i loved every second i was in the FR-S. I'd like to own another 86 in the future, only time will tell. But for now, the FK8 will fill my needs and hope the future is bright for me and the Type R.
I'd like to thank the whole FT86Club community for probably being the best forum out there
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline   Reply With Quote
The Following 6 Users Say Thank You to PDM 2 For This Useful Post:
Ashikabi (09-29-2018), Busybee (10-02-2018), HKz (09-28-2018), humfrz (09-28-2018), new2subaru (09-28-2018), notout86 (09-30-2018)
Old 09-28-2018, 12:32 PM   #19659
humfrz
I might actually give this a try, I have one of those bernzomatic propane torch kits:
You think that should be sufficient?
That should work. I suggest you have a helper, one to hold the torch and the other person to bend the pipe.
humfrz
Old 09-28-2018, 01:18 PM   #19660
humfrz
Well, good on ya, PDM 2.
I hope you can handle all that POWER -
humfrz
PDM 2 (09-28-2018)
Old 09-28-2018, 03:11 PM   #19661
2018Asphalt86
Drives: 2018 Toyota 86 Base
Performed 7.5k service.
I used Eneos Sustina with oem Subaru filter and installed the Fumoto quick drain valve so future services will be quicker and less messy.
2018Asphalt86 is offline   Reply With Quote
Old 09-28-2018, 03:16 PM   #19662
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Unwrapped the M85 diff to be painted! 3.73 final drive here I come! Can't believe this diff is 90lbs. A lot of wire brush in my future to get this crap off..
Old 09-28-2018, 05:03 PM   #19663
MCTeeJ
MCTeeJ's Avatar
TOM's! Found a one month old set off of FB for a good deal.
MCTeeJ is offline   Reply With Quote
Old 09-28-2018, 07:56 PM   #19664
humfrz
DANG! What does it look like on the INSIDE?
Was it buried in a Louisiana swamp?
Oh, hell, just hit it with some flat black paint - call it textured - no one will ever know.
humfrz
Old 09-28-2018, 07:58 PM   #19665
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
put a circular wire brush on a drill and it will go much faster.
https://www.harborfreight.com/wire-w...-pc-60475.html
fx1mark is offline   Reply With Quote
Old 09-29-2018, 12:01 AM   #19666
DarkPira7e
DarkPira7e's Avatar
That's exactly what I did. I found that I had a brass wire brush drill attachment on hand and used that.
@humfrz and I used black rattlecan just for you
The Following User Says Thank You to DarkPira7e For This Useful Post:
humfrz (09-29-2018)
Old 09-29-2018, 12:05 AM   #19667
Ashikabi
Ashikabi's Avatar
It is aha, I've tried adjusting the rubber things that hold the hangar hooks but it still stays slightly crooked, idk why... I believe the exhaust pipe may be bent?
My exhaust hung crooked too
Old 09-29-2018, 01:17 AM   #19668
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Added 15mm spacers to my 18x9 rear wheels and 12mm spacers to my front 18x9 wheels: making them +27 rear & +30 front. Now they sit right
They are also the correct OD. The universal spacers I was running are slightly bigger OD, which looks stupid. The front spacer is now the same size as the brake rotor hub.
I LIKE TIRES!
Old 09-29-2018, 05:38 AM   #19669
Roth
Roth's Avatar
Drives: 2013 Gt86
Finally replaced all the interior plastic trim with the black "jdm style". A little nice touch. Bought all the parts from amayama japan
Roth is offline   Reply With Quote
The Following User Says Thank You to Roth For This Useful Post:
MJones_RB (10-01-2018)
Old 09-29-2018, 11:59 AM   #19670
jflogerzi
jflogerzi's Avatar
Installed a new head unit. Still need to run the mic and replace the OEM one. Also did not realize they tied andriod auto setup to the parking break... So I will need to run the wire to the hand break... Uggg first time doing this. But highly recommend ordering from crutchfeild as there pre wired harness is awesome. SQ is the same as stock unit. Need to mess with the equallizer.
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Dadhawk (10-03-2018), MJones_RB (10-01-2018)
