Old 08-14-2014, 06:56 PM   #183
Dantical
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
file size is 1,21 MB (1.277.952 Bytes) - something must be wrong i guess?
edit: the patcher says :
Error at Byte 0X066344 <0xd6 expected, 0f8 found>!
Does this say anything to you ?
as i said i am a noob and i would never touch the tune,.. just want that patch for the Launch control and flat foot shifting,... :/
Dantical is offline   Reply With Quote
Old 08-14-2014, 07:23 PM   #184
steve99
see here for defs
http://www.ft86club.com/forums/showp...&postcount=186
links to defs in first post in this thread.
Old 08-14-2014, 07:26 PM   #185
steve99
The D00G roms are different structure to A01G or A00G so unless patcher is suited to D00G is not going to work.
Old 08-14-2014, 07:46 PM   #186
Dantical
see here for defs
thank you, but it is the ZA1JD00G
i have ZA1JA00G ,..
can i use the ZA1JD00G Definition?
- attached a Picture,.. hope it works
ok Steve99 - so it wonīt work until i get a right Definition for the ZA1JA00G - canīt find it anywhere :/
Old 08-14-2014, 07:51 PM   #187
Dantical
- canīt edit my post,..
or is there a way to get a update from my dealer and try again?
what came along with the ecuflash install was
ZA1JA01G.xml - does this work when i Change the Name and the 01 to 00 in the XML?
Old 08-14-2014, 08:52 PM   #188
steve99
No you need to match the correct definitions to each ROM type else you will be in trouble.
Read the First post (several times) and understand what you are doing else its not going to end well.
The Ecuflash defs are here link was in the first post
https://github.com/TD-D/SubaruDefs/t...20standard/BRZ
make sure you have the updated 32bitbase file
https://github.com/TD-D/SubaruDefs/t...standard/Bases
If it all looks to hard suggest you buy an Openflash Tablet their tunes have the Launch and Flat foot shift included and tunes are free and its very easy to use just plug and play $500 all up.
I'm not trying to be nasty but an OFT is cheaper than a new ECU.
www.openflashtablet.com
Old 08-14-2014, 09:33 PM   #189
Dantical
no Problem,.. i understand you,...
i am just wondering why i canīt save it as a hex,... the error code seems to be my Problem - no matter of that 2 Gimmicks....updated everything still no luck.
i think we will upload the original file into the ecu again,...
maybe pulling it down again will solve the Problem - but i donīt think so ,...
thank you anyway for your commitment if someone maybe has a solution getting the right hex file,... pm me
Old 08-14-2014, 09:38 PM   #190
Dantical
one further question:
are all original ZA1JA00G files the same ?
I mean downloading the ZA1JA00G from a stock car - und uploading it to my ecu ,.. will this work ?
propably my tuner messed the original file some how ?
Old 08-14-2014, 10:09 PM   #191
steve99
yes it will you can also update to A01G or D00G just need the def files for each.
you always get error message when you save an srf as bin or hex its normal
Old 08-14-2014, 10:26 PM   #192
Dantical
did not know that!
would you recommend updating ? to which one ? are These files hosted anywhere? what are the differences ?
- if this does not longer belong in here,.. then please hook me up with a pm
Old 08-15-2014, 02:26 AM   #193
steve99
did not know that!
All the rom (stock) are attached at the end of the very first post in this thread or just click the tactrix link below , You can use which ever one you like p probably A01G is best the defs are tried and proven and it has transient ignition retard fix for DI injector seal problems, D00G is latest one but very new defs
Old 08-17-2014, 04:31 PM   #194
steve99
Added ZA1JA03N MT Chinese ROM
Old 08-18-2014, 12:35 AM   #195
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
A01J and K have the transient ignition retard update as well. Curious what the 2015 roms changed
MFB is offline   Reply With Quote
Old 08-18-2014, 02:42 AM   #196
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Dantical - pm me, I'll help you patch it.
Td-d is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
